Re: Riena Widgets :: Code Snippets [message #574440 is a reply to message #10437] |
Fri, 05 September 2008 10:12  |
Jose Carlos de Missias schrieb:
> I saw, that: Riena's TableRidget this is not supported out of the box.
> And Elias confirmed. There are plans to give this support, such as JFace ?
we are currently in the process of implementing ridgets for the widgets that we need most. I can currently not tell you
when editable cells are supported. You can still create a view and use SWT directly for that particular part of your
application without ridget support. I mean to can use of ridgets and widgets. That is a very good design I agree but it
will be quit a while until we have each and every widget covered.
Or you can create a contribution that adds this feature. :-)
FUDForum. Page generated in 1.35315 seconds
