Home » Newcomers » Newcomers » tomcat plugin
tomcat plugin [message #112282] Wed, 26 October 2005 11:43 Go to next message
hi all
Is there a plugin so i can stop/start tomcat from the eclipse ide?
can someone tell me how i run tomcat as an ordinary appl from within
eclipse. I've read i need to put bootstrap.jar on the launch classpath -
where is this? and then pass -Dcatalina.home=<home install> as a VM arg and
start as app arg, but don't know where to do this from eclipse
can anyone help
many thanks
Re: tomcat plugin [message #112298 is a reply to message #112282] Wed, 26 October 2005 11:57 Go to previous messageGo to next message
Create an External tool launch short configuration for tomcat
Top Run menu>External Tools>External Tools...
Click New
Set the name to "Start Tomcat"
On the main tab set the location to your tomcat bat file. For example:
C:\jakarta-tomcat-5.5.9\bin\catalina.bat
On the main tab, in arguments add:
start
Press Run
For stopping tomcat create another launch configuration for tomcat
and set the arguments to:
stop
You can then start and stop tomcat using the external tools tool bar drop
down.
HTH
Darins
"plork123" <plork123@hotmail.com> wrote in message
news:djo87v$r09$1@news.eclipse.org...
> hi all
and
> can anyone help
> many thanks
Re: tomcat plugin [message #112309 is a reply to message #112298] Wed, 26 October 2005 12:17 Go to previous messageGo to next message
hi thanks for that
i get the error
The CATALINA_HOME environment variable is not defined correctly
This environment variable is needed to run this program
The system cannot find the path specified.
do i have to set something in the classpath environment variables
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:djo91i$s9e$1@news.eclipse.org...
> Click New
> start
> Press Run
> stop
> down.
> HTH
> Darins
>> hi all
> and
>> can anyone help
>> many thanks
Re: tomcat plugin [message #112352 is a reply to message #112309] Wed, 26 October 2005 13:54 Go to previous messageGo to next message
Originally posted by: weconsul.ptd.net
plork123 wrote:
> hi thanks for that
> i get the error
snip..
To run Tomcat 4.0 this is one of requirements. Set an environment
variable CATALINA_HOME to the path of the directory into which you have
installed.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: tomcat plugin [message #112400 is a reply to message #112352] Wed, 26 October 2005 15:11 Go to previous messageGo to next message
Sorry about that oversight.
You will need both CATALINA_HOME and JAVA_HOME defined.
see the catalina.bat file for full details.
Darins
"IchBin" <weconsul@ptd.net> wrote in message
news:djog11$6f7$1@news.eclipse.org...
> plork123 wrote:
> > hi thanks for that
> > i get the error
> snip..
> installed.
Re: tomcat plugin [message #112530 is a reply to message #112400] Thu, 27 October 2005 05:53 Go to previous message
Thanks - i've now got that working but i it dosemn't alllow me to add
project to the source so i can debug
news:djokdq$cj7$1@news.eclipse.org...
> Darins
>> plork123 wrote:
>> > hi thanks for that
>> > i get the error
>> snip..
>> installed.
Previous Topic:How do I add Window Preferences
Next Topic:eclipse javadocs
Current Time: Thu Aug 07 02:12:45 EDT 2025
Powered by FUDForum. Page generated in 0.08430 seconds
