Home » Eclipse Projects » Remote Application Platform (RAP) » cannot change textboxes with Selenium
cannot change textboxes with Selenium [message #111278] Wed, 05 November 2008 08:39 Go to next message
Hi all,
I want to test my RAP-Application (RAP Version 1.1.1) with Selenium. The
"type" Command as well as the "keyPressed" or "typeKeys" Command doesn't
work. I can see the text is in the textfield visible, but text.getText
returns still "". You can try with the Controls-Demo for RAP in the
Button-Tab:
defaultButton.addSelectionListener( new SelectionAdapter() {
public void widgetSelected( final SelectionEvent event ) {
String message = "The text You entered: " + text.getText();
MessageDialog.openInformation( group.getShell(),
"Information",
message );
It seems that the modify/change-Listener doesnt't work. (Safari and
Firefox (Version 2 and 3)).
There is an old message with the same problem:
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg02368.html
but the answer (using Qooxdoo Simulator) doesn't work for text input (only
for simulating mouse-clicks)
Re: cannot change textboxes with Selenium [message #111420 is a reply to message #111278] Thu, 06 November 2008 05:05 Go to previous message
Originally posted by: rherrmann.innoopract.com
Michael,
from looking atthe code in TextUtil.js, there are several listeners
attached to the qx text widget to ensure that the server-side is
updated with user input. See _doAddListener in line 95.
Did you check whether one of these listeners is called?
HTH
Rüdiger
Michael wrote:
> Hi all,
> Button-Tab:
> "Information",
> message );
> (only for simulating mouse-clicks)
Previous Topic:CCombo support in RWT?
Next Topic:RAP, Selenium and Extension Points.
Current Time: Sun Aug 31 10:36:50 EDT 2025
Powered by FUDForum. Page generated in 0.03455 seconds
