| Re: [ANN] Report Designer Plugin for Eclipse [message #10574 is a reply to message #10541] |
Wed, 19 June 2002 22:46  |
Originally posted by: eric_to_jeff.hotmail.com
For the org.xml.sax.driver problem and xerces SAXParser class
can not found when use jdk1.4, we will fix it in next release.
For the moment, if you use jdk1.4, you can try to copy xerces.jar
to JRE_HOME/lib/ext(java.ext.dirs) directory.
Now we should organise the directory structure because we will use
maven(http://jakarta.apache.org/turbine/maven/) to manage our project.
When we finish it, we will putting the whole source into the CVS repository
on sourceforge.net.
"Eugene Bekker" <ebekker@powervision.com> wrote in message
news:3D10BD8F.90504@powervision.com...
> Looks very promising! Is the code in the ReportDesignsrc.zip file
> current? At first glance it looks like it's not up to date with what
> the plugin in the screenshots.
> Do you plan on putting the whole source into the CVS repository on
> SourceForge?
> Also, when I try to open up the the ReportEditor, I get the following
> error message: "System property org.xml.sax.driver not specified"
> And then the the Design editor comes up but doesn't function.
> In order to eliminate the error, I had to put xerces.jar into the
> classpath, and manually specify the sys prop to Xerces' SAXParser when
> starting up Eclipse. Is this the way it's supposed to be? I'm
> currently running Eclipse on a Linux system using Sun's JDK 1.4 (initial
> release, not the latest .0.1 release). I even tried putting the
> xerces.jar directly into the plugin lib folder and adding a library
> reference to it in the plugin.xml file.
> Eric Sun wrote:
> > Hi all,
> > we have developed an Eclipse 2.0 plugin for the JasperReports
> > (http://sourceforge.net/projects/jasperreports).
> > It is based on Graphical Editor Framework (GEF).
> > The goal of the project is to develop a Eclipse plugins that
> > make it easier for Java developers to create a JasperReports XML file.
> > It will provide a visual tool for the report design work.
> > The project's homepage is http://jeez.sourceforge.net/
> > You can download the plugin from the project summary page
> > http://sourceforge.net/projects/jeez/
> > Regards,
> > Eric
FUDForum. Page generated in 0.05944 seconds
