Home » Eclipse Projects » Eclipse Platform » transparent pngs in 3.0?
transparent pngs in 3.0? [message #111033] Wed, 13 August 2003 22:32 Go to next message
Originally posted by: ians.rgbcoolege.com
Do transparent .pngs work in any 3.0 builds?
I use 2.1.1 and my transparent .pngs have a black or white background instead
of transparent. (in buttons, in tables, everywhere..)
Re: transparent pngs in 3.0? [message #112957 is a reply to message #111033] Wed, 20 August 2003 08:45 Go to previous messageGo to next message
Is it a transparent PNG (a particular RGB value is defined to be the
transparent value) or a PNG with alpha information? Alpha transparency is
not supported in buttons etc. If you're not sure, please open a PR and
attach your PNG file. As a workaround, GIF can be used to avoid this
confusion as this format only support transparency, not alpha.
Re: transparent pngs in 3.0? [message #113162 is a reply to message #112957] Wed, 20 August 2003 12:21 Go to previous messageGo to next message
Is alpha transparency support planed to be added? I would jump in squares
if I can use it ;)
Martin (Kersten)
Re: transparent pngs in 3.0? [message #113992 is a reply to message #113162] Thu, 21 August 2003 11:33 Go to previous messageGo to next message
Originally posted by: steve_northover.ca.ibm.com
Open a bugzilla report with the PNG or nothing will happen.
"Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> wrote in message
news:bi072j$q4$1@eclipse.org...
is
> if I can use it ;)
> Martin (Kersten)
Re: transparent pngs in 3.0? [message #114049 is a reply to message #113992] Thu, 21 August 2003 12:08 Go to previous messageGo to next message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=41812 ;)
Re: transparent pngs in 3.0? [message #270050 is a reply to message #114049] Fri, 03 September 2004 12:31 Go to previous messageGo to next message
The dupe of the above bug [1] has been "New" for over 12
months, so if anyone else out there gets the transparency
problem and needs full Alpha-PNG support, please VOTE for
[1] it and it may get on the radar of things that are desired.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=35040
Re: transparent pngs in 3.0? [message #270507 is a reply to message #270050] Tue, 07 September 2004 17:57 Go to previous message
It's up to 22 votes (#11 in rank).
"rich boakes" <rich.boakes@port.ac.uk> wrote in message
news:cha5ut$i61$4@eclipse.org...
The dup of the above bug [1] has been "New" for over 12
Previous Topic:Feature export
Next Topic:NoClassDefFound
Current Time: Sun Jul 27 01:33:03 EDT 2025
Powered by FUDForum. Page generated in 0.08438 seconds
