Home » Archived » Visual Editor (VE) » Error trying to set new file into editor - NullPointerException
Error trying to set new file into editor - NullPointerException [message #110970] Wed, 16 November 2005 13:30 Go to next message
I'm getting this error on two projects, but one other works fine. All
projects were built with a prior release of Eclipse and VE. I tried
VE1.0.xx, but still getting the error. I Googled this as much as I could,
without success as to a resolution. I'm getting a tad nervous, as one of
the projects is getting active again.
Re: Error trying to set new file into editor - NullPointerException [message #110995 is a reply to message #110970] Wed, 16 November 2005 13:35 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Try the following (we want to clear out any caches):
1) Open a VE and then close it. Make sure there are NO VE's open at all.
2) Clear the .log file (use the ErrorLog view and the "Delete Log" button).
3) Projects->Clean...->Clean ALL projects radio button
4) Wait for build to finish
5) Try opening the VE again.
If you still get errors, please send us this new log.
> could, without success as to a resolution. I'm getting a tad nervous,
> as one of the projects is getting active again.
Rich Kulp
Re: Error trying to set new file into editor - NullPointerException [message #111016 is a reply to message #110995] Wed, 16 November 2005 13:47 Go to previous messageGo to next message
As requested:
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:38.15
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.NoClassDefFoundError: java/util/regex/Pattern
org.eclipse.jem.internal.beaninfo.common.FeatureAttributeVal ue. <clinit>(FeatureAttributeValue.java:170)
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.fill(M odelingBeanInfo.java:809)
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.sendPr opertyDecorators(ModelingBeanInfo.java:623)
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.send(M odelingBeanInfo.java:550)
at java.lang.reflect.Method.invoke(Native Method)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:317)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:221)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms(REMMethodProxy.java:178)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:102)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:98)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeC atchThrowableExceptions(REMMethodProxy.java:231)
org.eclipse.jem.internal.beaninfo.adapters.BeanInfoDecorator Utility.introspect(BeanInfoDecoratorUtility.java:215)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:762)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:429)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:416)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:637)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEStructuralFeatures(BeaninfoClassAdapter.java:1184)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEStructu ralFeatures(JavaClassImpl.java:394)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getProperti es(JavaClassImpl.java:1308)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allProperties(BeaninfoClassAdapter.java:1313)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllProperties(BeaninfoClassAdapter.java:1192)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getAllPrope rties(JavaClassImpl.java:1349)
org.eclipse.ve.internal.java.codegen.java.rules.ThisReferenc eRule.useInheritance(ThisReferenceRule.java:114)
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.create ThisIfNecessary(TypeVisitor.java:115)
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.visit( TypeVisitor.java:238)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:512)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:417)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:835)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:917)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:575)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1920)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:38.78
!MESSAGE
+++ Warning +++: Wed Nov 16 10:42:38 PST 2005 Feature
"java.awt.Component->bounds" did not have a type set. Typically due to
override file creating feature but property not found on
introspection/reflection.
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:38.93
!MESSAGE
"java.awt.Component->location" did not have a type set. Typically due to
!MESSAGE
"java.awt.Component->size" did not have a type set. Typically due to
!MESSAGE
"java.awt.Component->componentOrientation" did not have a type set.
Typically due to override file creating feature but property not found on
!ENTRY org.eclipse.jem.beaninfo 4 0 2005-11-16 10:42:38.265
!MESSAGE Exception thrown.
!STACK 0
java.io.EOFException
at java.io.ObjectInputStream$PeekInputStream.readFully(Unknown Source)
at java.io.ObjectInputStream$BlockDataInputStream.readShort(Unk nown
Source)
at java.io.ObjectInputStream.readStreamHeader(Unknown Source)
at java.io.ObjectInputStream.<init>(Unknown Source)
org.eclipse.jem.internal.beaninfo.adapters.BeanInfoDecorator Utility$ProxyIntrospectCallBack.calledBackStream(BeanInfoDec oratorUtility.java:351)
org.eclipse.jem.internal.proxy.remote.REMCallbackThread.run( REMCallbackThread.java:276)
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:38.328
!MESSAGE
+++ Warning +++: Wed Nov 16 10:42:38 PST 2005 Project (Employee Self
Service Update)-Beaninfo:err>
IWAV0123E --------- UNCAUGHT EXCEPTION ---------
java.lang.Error: java.beans.IntrospectionException: IWAV0010E Cannot
find at least the write or read accessor for property
focusTraversalPolicy. IWAV0147E Cannot create the PropertyDescriptor for
org.eclipse.jem.beaninfo.vm.BaseBeanInfo.throwError(BaseBean Info.java:837)
org.eclipse.jem.beaninfo.vm.BaseBeanInfo.createPropertyDescr iptor(BaseBeanInfo.java:473)
org.eclipse.ve.internal.jfc.beaninfo.ContainerBeanInfo.getPr opertyDescriptors(ContainerBeanInfo.java:557)
java.beans.Introspector.getTargetPropertyInfo(Introspector.j ava:374)
at java.beans.Introspector.getBeanInfo(Introspector.java:324)
at java.beans.Introspector.getBeanInfo(Introspector.java:106)
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.intros pect(ModelingBeanInfo.java:189)
java.lang.Error: java.lang.NoSuchMethodException:
getFocusTraversalPolicy IWAV0007E Cannot get the method
getFocusTraversalPolicy.
org.eclipse.jem.beaninfo.vm.BaseBeanInfo.createMethodDescrip tor(BaseBeanInfo.java:313)
org.eclipse.ve.internal.jfc.beaninfo.ContainerBeanInfo.getMe thodDescriptors(ContainerBeanInfo.java:492)
at java.beans.Introspector.getTargetMethodInfo(Introspector.jav a:710)
at java.beans.Introspector.getBeanInfo(Introspector.java:326)
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:38.453
!MESSAGE
!STACK 0
org/eclipse/jem/internal/beaninfo/common/FeatureAttributeVal ue
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.sendBe anDecorator(ModelingBeanInfo.java:579)
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.send(M odelingBeanInfo.java:548)
!ENTRY org.eclipse.jem.beaninfo 4 0 2005-11-16 10:42:39.203
!STACK 0
Source)
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.234
!MESSAGE
!STACK 0
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEvents(BeaninfoClassAdapter.java:1221)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEvents(J avaClassImpl.java:1314)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allEvents(BeaninfoClassAdapter.java:2260)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllEvents(BeaninfoClassAdapter.java:1229)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getAllEvent s(JavaClassImpl.java:1336)
org.eclipse.ve.internal.java.codegen.java.EventsParser.getAd dSignitures(EventsParser.java:64)
org.eclipse.ve.internal.java.codegen.java.EventsParser.analy ze(EventsParser.java:97)
org.eclipse.ve.internal.java.codegen.java.EventsParser.addEv ents(EventsParser.java:133)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.analyzeEvents(JavaBeanModelBuilder.java:346)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:437)
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:39.250
!MESSAGE
+++ Warning +++: Wed Nov 16 10:42:39 PST 2005 Feature
"javax.swing.JComponent->nextFocusableComponent" did not have a type set.
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.296
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:39.296
!MESSAGE
"javax.swing.AbstractButton->mnemonic" did not have a type set. Typically
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.328
!MESSAGE
+++ Warning +++: Wed Nov 16 10:42:39 PST 2005 Project (Employee Self
find at least the write or read accessor for property transferHandler.
IWAV0147E Cannot create the PropertyDescriptor for transferHandler.
org.eclipse.ve.internal.jfc.beaninfo.JComponentBeanInfo.getP ropertyDescriptors(JComponentBeanInfo.java:1446)
java.lang.Error: java.lang.NoSuchMethodException: getTransferHandler
IWAV0007E Cannot get the method getTransferHandler.
org.eclipse.ve.internal.jfc.beaninfo.JComponentBeanInfo.getM ethodDescriptors(JComponentBeanInfo.java:1186)
!ENTRY org.eclipse.jem.beaninfo 4 0 2005-11-16 10:42:39.343
!STACK 0
Source)
!STACK 0
Source)
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.343
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.390
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.500
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.562
!MESSAGE
find at least the write or read accessor for property UI. IWAV0147E Cannot
create the PropertyDescriptor for UI.
org.eclipse.ve.internal.jfc.beaninfo.JPanelBeanInfo.getPrope rtyDescriptors(JPanelBeanInfo.java:133)
java.lang.Error: java.lang.NoSuchMethodException: getUI IWAV0007E
Cannot get the method getUI.
org.eclipse.ve.internal.jfc.beaninfo.JPanelBeanInfo.getMetho dDescriptors(JPanelBeanInfo.java:89)
java.beans.Introspector.getTargetMethodInfo(Introspector.jav a(Compiled
Code))
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.609
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:39.625
!MESSAGE
"javax.swing.JLabel->displayedMnemonic" did not have a type set. Typically
!MESSAGE
"javax.swing.JLabel->labelFor" did not have a type set. Typically due to
!ENTRY org.eclipse.jem.beaninfo 4 0 2005-11-16 10:42:39.687
!STACK 0
Source)
!STACK 0
Source)
!STACK 0
Source)
!STACK 0
Source)
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.718
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-11-16 10:42:39.718
!MESSAGE
"javax.swing.text.JTextComponent->text" did not have a type set. Typically
!MESSAGE
"javax.swing.text.JTextComponent->selectionEnd" did not have a type set.
!MESSAGE
"javax.swing.text.JTextComponent->selectionStart" did not have a type set.
!ENTRY org.eclipse.jem.proxy 2 0 2005-11-16 10:42:39.765
!MESSAGE
find at least the write or read accessor for property navigationFilter.
IWAV0147E Cannot create the PropertyDescriptor for navigationFilter.
org.eclipse.ve.internal.jfc.beaninfo.JTextComponentBeanInfo. getPropertyDescriptors(JTextComponentBeanInfo.java:913)
Re: Error trying to set new file into editor - NullPointerException [message #111038 is a reply to message #111016] Wed, 16 November 2005 15:07 Go to previous messageGo to next message
What is your target java for the project. These errors indicates that it
is not at least 1.4. We need to be at least 1.4.
Rich Kulp
Re: Error trying to set new file into editor - NullPointerException [message #111060 is a reply to message #111038] Wed, 16 November 2005 15:34 Go to previous message
Rick,
Bingo. These projects where pointing to < 1.4. I swithed to 1.5.xx
and VE came up fine, except the layout (tabbed dialog) didn't display
correctly, but I will invistigate that before calling for help. Thanks
for the help.
Re: Error trying to set new file into editor - NullPointerException [message #611330 is a reply to message #110970] Wed, 16 November 2005 13:35 Go to previous message
Rich Kulp
Re: Error trying to set new file into editor - NullPointerException [message #611331 is a reply to message #110995] Wed, 16 November 2005 13:47 Go to previous message
As requested:
!MESSAGE
!STACK 0
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!STACK 0
Source)
!MESSAGE
!MESSAGE
!STACK 0
!STACK 0
Source)
!MESSAGE
!STACK 0
!MESSAGE
!MESSAGE
!STACK 0
!MESSAGE
!MESSAGE
!STACK 0
Source)
!STACK 0
Source)
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
Code))
!MESSAGE
!STACK 0
!MESSAGE
!MESSAGE
!STACK 0
Source)
!STACK 0
Source)
!STACK 0
Source)
!STACK 0
Source)
!MESSAGE
!STACK 0
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
Re: Error trying to set new file into editor - NullPointerException [message #611333 is a reply to message #111016] Wed, 16 November 2005 15:07 Go to previous message
Rich Kulp
Re: Error trying to set new file into editor - NullPointerException [message #611335 is a reply to message #111038] Wed, 16 November 2005 15:34 Go to previous message
Rick,
for the help.
Previous Topic:Error trying to set new file into editor - NullPointerException
Next Topic:eclipse 3.1 error when alterto JDK Compliance 5.0
Current Time: Wed Nov 12 11:33:47 EST 2025
Powered by FUDForum. Page generated in 0.05920 seconds
