Home » Archived » BIRT » Test sample birtengine : [...model.reportItemModel] is not found
Test sample birtengine : [...model.reportItemModel] is not found [message #110906] Wed, 18 January 2006 11:29 Go to next message
Originally posted by: xx.xxx.com
Hi all,
i'm testing API sample "birtengine" :
http://www.eclipse.org/birt/deploy/birtengine.zip
i've copy some *.jar and run the ant command "ant run
-Dreport=runreport.rptdesign -Dformat=-p"
to have the following error :
[java] 18 janv. 2006 17:07:56 org.eclipse.birt.core.util.BirtTimer
logTimeTaken
[java] INFO: Engine startup takes 234 Milliseconds.
[java] 18 janv. 2006 17:07:57
org.eclipse.birt.report.model.metadata.ExtensionLoader load
[java] GRAVE: Message:The extension point
[org.eclipse.birt.report.model.reportItemModel] is not found. Error
code:EXTENSION_POINT_NOT_FOUN
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask
createContentEmitter
[java] GRAVE: Error.OutputFormatNotSupported
[java] org.eclipse.birt.report.engine.api.EngineException: Le format de
sortie pdfnest pas pris en charge.
[java] at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.cre ateContentEmitter(RunAndRenderTask.java:81)
[java] at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:157)
[java] at org.eclipse.birt.demo.RunReport.run(Unknown Source)
[java] at org.eclipse.birt.demo.RunReport.main(Unknown Source)
I don't find issue. Have you got any idea ?
Denis.
Re: Test sample birtengine : [...model.reportItemModel] is not found [message #111010 is a reply to message #110906] Wed, 18 January 2006 13:07 Go to previous messageGo to next message
I had the same problem - I was setting my engine home to the viewer birt
directory - when I download the birt-runtime and pointed my engine home to
the Report Engine directory - everything then worked fine
Re: Test sample birtengine : [...model.reportItemModel] is not found [message #111483 is a reply to message #111010] Thu, 19 January 2006 06:48 Go to previous message
Originally posted by: xxx.xxx.com
got it.
tk
Previous Topic:bottomline is missing in pdf-output since RC1
Next Topic:PDF failed to open in IE
Current Time: Fri Nov 21 20:21:01 EST 2025
Powered by FUDForum. Page generated in 0.02739 seconds
