Home » Modeling » GMF (Graphical Modeling Framework) » Getting desperate -- How do I get rid of the GMF Update error????
| Getting desperate -- How do I get rid of the GMF Update error???? [message #10101] |
Tue, 08 August 2006 14:31  |
Originally posted by: eclipse.incognitology.com
Hello, everybody:
Sorry if I'm posting this in the wrong place, but I haven't been able to find
an answer to my problem anywhere.
When I try to update Eclipse, I get the following error:
Network connection problems encountered during search.
Unable to access
" http://download.eclipse.org/technology/gmf/update-site/relea ses/site.xml".
Unable to access site:
[Server returned HTTP response code: "404 Not Found" for URL:
http://download.eclipse.org/technology/gmf/update-site/relea ses/site.xml.]
Please note that this is with GMF disabled in Manage Configuration. Since the
Update Manager dies on this error, it's impossible for me to check for any
updates. Disabling GMF appears to have no effect, so it seems I'm in a bit of
a bind.
I've tried downloading GMF from the site and copying it directly to my eclipse
directory, but that's no help. Since the Eclipse wiki admonishes me not to
remove plugins and features, I'm beginning to run out of options.
\features\org.eclipse.gmf_1.0.0.v20060627-1200\feature.xml has the URL in
question in it -- can I change it there? If so, what's the correct URL?
I think it's unlikely that I'm the only one getting with this problem, but
since I don't see too much about it in the newsgroups or on the web, I'm
thinking it's an easy fix, and that I'm making some kind of noob error.
Help?
Thanks!
Greg
| Re: Getting desperate -- How do I get rid of the GMF Update error???? [message #11430 is a reply to message #10101] |
Tue, 08 August 2006 23:19   |
Originally posted by: khai.n.situvista.com
No you're not; alone I get the exact same message when I test it just
now. I think this might be because GMF have been moved around lately.
There were a few conversations about this in the newsgroup but the
suggested 'fix' given in those are not working either.
If you're really stuck why not install a fresh Eclipse then install all
the extra modules like EMF, GEF, GMF, etc... separately by downloading
the latest released versions?
That's what I did when 3.2 officially came out instead of updating my
existing installation.
-- Khai --
Greg Gomez wrote:
> Hello, everybody:
> find an answer to my problem anywhere.
> Unable to access
> Since the Update Manager dies on this error, it's impossible for me to
> check for any updates. Disabling GMF appears to have no effect, so it
> seems I'm in a bit of a bind.
> eclipse directory, but that's no help. Since the Eclipse wiki admonishes
> me not to remove plugins and features, I'm beginning to run out of options.
> in question in it -- can I change it there? If so, what's the correct URL?
> but since I don't see too much about it in the newsgroups or on the web,
> I'm thinking it's an easy fix, and that I'm making some kind of noob error.
> Help?
> Thanks!
> Greg
| Re: Getting desperate -- How do I get rid of the GMF Update error???? [message #11467 is a reply to message #11430] |
Tue, 08 August 2006 23:30   |
Some more info... you can start fresh and use "Callisto Discovery Site"
which I have not used but others seem to have used it to get everything
including GMF with success.
Alternatively, Artem Tikhomirov suggested using this URL if you want to
update GMF directly:
http://download3.eclipse.org/technology/gmf/update-site/rele ases/site.xml
-- Khai --
> -- Khai --
> Greg Gomez wrote:
>> Hello, everybody:
>> to find an answer to my problem anywhere.
>> Unable to access
>> admonishes me not to remove plugins and features, I'm beginning to run
>> out of options.
>> URL?
>> web, I'm thinking it's an easy fix, and that I'm making some kind of
>> noob error.
>> Help?
>> Thanks!
>> Greg
| Re: Getting desperate -- How do I get rid of the GMF Update error???? [message #11875 is a reply to message #10101] |
Wed, 09 August 2006 08:52   |
There is a bug open on this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=152808
It's due to our migration from /technology to /modeling and will be solved
by having restoring a duplicate set of updates in /technology until it's
safe to remove.
Sorry for the inconvenience.
Rich
On 8/8/06 2:31 PM, in article ebala2$b25$1@utils.eclipse.org, "Greg Gomez"
<eclipse@incognitology.com> wrote:
> Hello, everybody:
> Unable to access
> a bind.
> Help?
> Thanks!
> Greg
| Re: Getting desperate -- How do I get rid of the GMF Update error???? [message #13101 is a reply to message #11467] |
Wed, 09 August 2006 10:45   |
Originally posted by: vcciubot.uwaterloo.ca
Callisto doesn't seem to install the source code for GMF.
> -- Khai --
>> -- Khai --
>> Greg Gomez wrote:
>>> Hello, everybody:
>>> Unable to access
>>> out of options.
>>> URL?
>>> noob error.
>>> Help?
>>> Thanks!
>>> Greg
| Re: Getting desperate -- How do I get rid of the GMF Update error???? [message #13187 is a reply to message #11430] |
Wed, 09 August 2006 11:54  |
Khai, Rich, Vlad:
Thanks so much for your responses.
Ultimately I just removed my entire eclipse dir and started all over again.
FYI the URL
doesn't seem to be valid, either.
In any case, I think I'm back in business.
Thanks again!
Greg
> -- Khai --
> Greg Gomez wrote:
>> Hello, everybody:
>> Unable to access
>> out of options.
>> URL?
>> noob error.
>> Help?
>> Thanks!
>> Greg
Current Time: Sun Nov 09 15:24:36 EST 2025
Powered by FUDForum. Page generated in 0.03585 seconds
