Home » Archived » BIRT » SEVERE: Report engine can not create pdf emitter
| SEVERE: Report engine can not create pdf emitter [message #110499] |
Tue, 17 January 2006 13:04  |
i need some help.
I'm trying to generate a pdf file, but the following error occurs.
SEVERE: Report engine can not create pdf emitter.
Report C:/Program Files/Apache/Tomcat
5.5/webapps/BI/Documentos/estat.rptdesign
run failed.
org.eclipse.birt.report.engine.api.EngineException: Report engine fails to
creat
e extension to handle this request.
The software that i'm using are:
Windows XP SP2
Eclipse 3.1.1
BIRT 2.0.0
EMF 2.1.*
GEF 3.1.1
I hope that someone can help me.
| Re: SEVERE: Report engine can not create pdf emitter [message #110794 is a reply to message #110584] |
Wed, 18 January 2006 07:06   |
Originally posted by: carvalho.humberto.almedina.net
--------------060103060005040007090802
Thanks for your help,
First I have to say that i'm using a Birt viewer and the Birt engine API.
If i use the viewer engine and then choose to print to pdf, this works,
but when i try to generate a pdf file from a rptdesign file using the
engine API, the error occurs
I think that I have all the required files in the right place, I
followed the instructions of the following url
" http://www.eclipse.org/birt/index.php?page=build/install.htm l"
iText.jar is placed in "plugins\org.eclipse.birt.report.engine.pdf\lib"
In my application, the engine directory points to the viewer root
directory. I have also tried using the 'Report Engine' directory of the
runtime distribution, with similar results.
In attachment I send a java file that i think that could be the problem...
I'll wait for your answer..
Humberto Carvalho
Jason Weathersby wrote:
> Can you upload the Stacktrace?
> Also verify that you have the other required files under the proper
> location, like the iText jar file.
> Jason Weathersby
> BIRT PMC
> "Humberto Carvalho" <carvalho.humberto@gmail.com> wrote in message
> news:51ff09d618a253c7540a8c0018bd62e5$1@www.eclipse.org...
>> Hello,
>> i need some help.
>> run failed.
>> creat
>> Windows XP SP2
>> Eclipse 3.1.1
>> BIRT 2.0.0
>> EMF 2.1.*
>> GEF 3.1.1
>> Thanks
name="Conversor.java"
Content-Disposition: inline;
filename="Conversor.java"
package pt.almedina.reports;
* Example command-line utility to generate BIRT reports. Shows the basics
* of integrating the BIRT report engine into a simple Java application.
import java.util.Collection;
import java.util.HashMap;
import java.util.Iterator;
import java.util.Map;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IHTMLActionHandler;
import org.eclipse.birt.report.engine.api.IParameterDefnBase;
import org.eclipse.birt.report.engine.api.IParameterGroupDefn;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.IScalarParameterDefn;
import org.eclipse.birt.report.engine.api.ReportEngine;
import org.eclipse.birt.report.engine.api.ReportParameterConverter;
* Runs a BIRT report and writes the output to a directory.
* RunReport report-name -[h|p] [-i] param=value
* -h HTML (default)
* -p PDF
* -i Display report info.
* param=value Set parameter "param" to the value "value".
public class Conversor
static String REPORTENGINE_URL = "C:/Program Files/Apache/Tomcat 5.5/webapps/Viewer";//c:/reportengine";
static String IMAGE_URL = "C:/Program Files/Apache/Tomcat 5.5/webapps/BI/Documentos";
// Command-line main to parse arguments described above.
public static void main(String[] args) throws EngineException
int i = 0;
if ( i >= args.length )
System.out.println( "Nao foi especificado qualquer relatorio" );
return;
String reportName = args[i++];
String format = null;
boolean showInfo = false;
// Stoare parameter values into a hash map to later pass to the
// BIRT report engine.
HashMap params = new HashMap( );
for ( ; i < args.length; i++ )
if ( args[i].charAt(0) == '-' )
char flag = Character.toLowerCase( args[i].charAt( 1 ) );
if ( flag == 'p' )
format = HTMLRenderOption.OUTPUT_FORMAT_PDF;
else if ( flag == 'h' )
format = HTMLRenderOption.OUTPUT_FORMAT_HTML;
else if ( flag == 'i' )
showInfo = true;
else
usage( );
return;
else
// Get a parameter value. Note, this example code only works
// for string parameters. If you have date or number parameters,
// your application should parse them, then put the corresponding
// objects into the hash map.
String arg = args[i];
int posn = arg.indexOf( '=' );
if ( posn == -1 )
usage( );
return;
String param = arg.substring( 0, posn );
String value = arg.substring( posn + 1 );
Object put = params.put( param, value );
run( reportName, params, format, showInfo );
public static void usage( )
System.out.println( "Sintaxe:\n java RunReport rptName [-h|p]\n param=value ..." );
// Example function to run a report given the report name, parameters and
// output type. The output is put into a file in the same directory as the
// report itself.
public static void run( String name, HashMap params,
String format, boolean showInfo ) throws EngineException
// The EngineConfig is used to set up engine-wide configuration
// information.
EngineConfig config = new EngineConfig( );
// The Engine home is the location of the BIRT engine runtime.
// M3 Note: Use the report engine installed as part of the BIRT web app
// used to preview reports. Alter this path to the location of your
// Eclipse installation.
config.setEngineHome(REPORTENGINE_URL);
// HTML reports can have embedded images or charts. Set up the configuration
// required to write these into a directory in the output directory.
// The HTMLCompleteImageHandler is one provided by BIRT for this purpose.
// Your application can create a customized version to provide alternative
// ways to handle images.
HTMLEmitterConfig hc = new HTMLEmitterConfig( );
HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler( );
hc.setImageHandler( imageHandler );
config.setEmitterConfiguration( HTMLRenderOption.OUTPUT_FORMAT_HTML, hc );
// Create the report engine itself. This engine can be used to run
// multiple reports.
ReportEngine engine = new ReportEngine( config );
// Open the report design.
IReportRunnable report = null;
try {
report = engine.openReportDesign( name );
} catch ( EngineException e) {
System.out.println("ERRO: PT.ALMEDINA.REPORTS.CONVERSOR.RUN\n EXCEPTION: "+e);
if ( showInfo )
showReportInfo( engine, report );
// Create a task to run the report and convert the output to HTML
// or PDF.
if ( format != null )
parseParams( engine, report, params );
IRunAndRenderTask task = engine.createRunAndRenderTask( report );
//HTMLRenderContext renderContext = new HTMLRenderContext();
//renderContext.setImageDirectory(IMAGE_URL);
HTMLRenderContext renderContext = new HTMLRenderContext( );
renderContext.setImageDirectory( IMAGE_URL ); //"image"//$NON-NLS-1$
HashMap appContext = new HashMap( );
appContext.put("PDF_RENDER_CONTEXT", renderContext );//EngineConstants.APPCONTEXT_PDF_RENDER_CONTEXT
task.setAppContext( appContext );
//task.setContext((Map) renderContext);
HTMLRenderOption options = new HTMLRenderOption( );
options.setOutputFormat( format );
String output = name.replaceFirst( ".rptdesign", "." + format );
options.setOutputFileName( output );
task.setRenderOption( options );
String str = params.toString();
//task.setParameterValues( params );
// Run the report.
try
task.run( );
catch (EngineException e)
engine.destroy( );
// Display properties of the report and the list of report parameters.
static void showReportInfo( ReportEngine engine, IReportRunnable report )
// Display some of the general report properties.
// See the ROM Design specification for a list of properties.
System.out.print( "Report Name: " + report.getReportName() +
"\nTitle: " + report.getProperty( "title" ) +
"\nComments: " + report.getProperty( "comments" ) +
"\nDescription: " + report.getProperty( "description" ) +
"\nAuthor: " + report.getProperty( "author" ) +
"\nCreated By: " + report.getProperty( "createdBy" ) +
"\n" );
// Display the list of report parameters with their groups.
// Parameters defined outside a group appear inside a default, unnamed
// group.
IGetParameterDefinitionTask task = engine.createGetParameterDefinitionTask( report );
Collection params = task.getParameterDefns( true );
if ( params.isEmpty() )
System.out.print( "This report has no parameters.\n" );
return;
Iterator iter = params.iterator( );
while ( iter.hasNext( ) )
IParameterDefnBase param = (IParameterDefnBase) iter.next( );
if ( param instanceof IParameterGroupDefn )
IParameterGroupDefn group = (IParameterGroupDefn) param;
System.out.println( "Parameter Group: " + group.getDisplayName( ) );
Iterator i2 = group.getContents( ).iterator( );
IScalarParameterDefn member = (IScalarParameterDefn) i2.next( );
showParam( task, member, " " );
else
showParam( task, param, "" );
// Show information for one parameter.
// Release 1 supports only scalar (single-value) parameters.
static void showParam( IGetParameterDefinitionTask task,
IParameterDefnBase defn,
String prefix )
IScalarParameterDefn param = (IScalarParameterDefn) defn;
System.out.println( prefix + "Parameter: " + param.getName( ) );
System.out.println( prefix + " Display Name: " + param.getDisplayName( ) );
System.out.println( prefix + " Type: " + param.getDataType( ) );
System.out.print( prefix + " Default Value: " );
// The default value is an expression. Evaluate it.
Object value = task.getDefaultValue( param );
System.out.println( value == null ? "none" : value.toString( ) );
static void parseParams( ReportEngine engine, IReportRunnable report, HashMap values )
System.out.println("ENTREI!!! VALORES: "+values);
if ( values.isEmpty( ) )
return;
Collection params = task.getParameterDefns( false );
Iterator iter = values.keySet( ).iterator( );
System.out.println("VOU ENTRAR NO WHILE!!!");
int xxx = 1;
System.out.println("WHILE: "+xxx);
String name = (String) iter.next( );
IScalarParameterDefn found = null;
Iterator i2 = params.iterator( );
while ( i2.hasNext( ) )
IParameterDefnBase param = (IParameterDefnBase) i2.next( );
continue;
if ( param.getName( ).equals( name ) )
found = (IScalarParameterDefn) param;
break;
if ( found == null )
System.err.println( "Parameter " + name + " not found in the report." );
continue;
String value = (String) values.get( name );
// ReportParameterConverter cfgConverter = new ReportParameterConverter( "", Locale.getDefault( ) );
// Object obj = cfgConverter.parse( value, found.getDataType( ) );
// values.put( name, obj );
values.put( name, value );
--------------060103060005040007090802--
| Re: SEVERE: Report engine can not create pdf emitter [message #110862 is a reply to message #110794] |
Wed, 18 January 2006 08:05   |
Humberto,
I just tried your sample and it worked fine.
I set my home to "c:/myruntime/report engine".
Below is a directory listing of the report engine directory. Notice I added
iText.
12/31/2005 11:50a 77,586 birt-oda.jar
12/31/2005 11:50a 956,273 chart-engine.jar
12/31/2005 11:50a 30,117 commons-cli-1.0.jar
12/31/2005 11:50a 37,754 commons-codec-1.3.jar
12/31/2005 11:50a 132,596 core.jar
12/31/2005 11:50a 569,702 dte.jar
12/31/2005 11:50a 870,507 engine.jar
12/31/2005 11:50a 71,513 flute.jar
11/29/2005 05:41p 1,145,105 itext-1.3.jar
12/31/2005 11:50a 699,081 js.jar
01/15/2006 11:33p 1,552 libs.txt
12/31/2005 11:50a 3,316,129 model.jar
12/31/2005 11:50a 80,541 oda.jar
12/31/2005 11:50a 69,367 odaconsumer-helper.jar
12/31/2005 11:50a 137,063 org.eclipse.emf.common_2.1.0.jar
12/31/2005 11:50a 144,460 org.eclipse.emf.ecore.xmi_2.1.0.jar
12/31/2005 11:50a 639,778 org.eclipse.emf.ecore_2.1.0.jar
01/04/2006 04:48p <DIR> plugins
12/31/2005 11:50a 14,526 sac.jar
01/04/2006 04:48p <DIR> samples
12/31/2005 11:50a 43,275 scriptapi.jar
01/18/2006 11:00a 0 test.txt
12/31/2005 11:50a 161,563 Tidy.jar
Jason
"HC" <carvalho.humberto@almedina.net> wrote in message
news:43CE2F39.9030104@almedina.net...
> Thanks
> Humberto Carvalho
>> Jason Weathersby
>> BIRT PMC
>>> Hello,
>>> i need some help.
>>> run failed.
>>> to
>>> creat
>>> Windows XP SP2
>>> Eclipse 3.1.1
>>> BIRT 2.0.0
>>> EMF 2.1.*
>>> GEF 3.1.1
>>> Thanks
> * -h HTML (default)
> * -p PDF
> int i = 0;
> return;
> if ( flag == 'p' )
> showInfo = true;
> else
> usage( );
> return;
> else
> if ( posn == -1 )
> usage( );
> return;
> param=value ..." );
> // report itself.
> // information.
> configuration
> try {
> EXCEPTION: "+e);
> if ( showInfo )
> // or PDF.
> // Run the report.
> try
> task.run( );
> engine.destroy( );
> "\n" );
> // group.
> return;
> else
> String prefix )
> HashMap values )
> return;
> int xxx = 1;
> continue;
> break;
> continue;
| Re: SEVERE: Report engine can not create pdf emitter [message #111037 is a reply to message #110862] |
Wed, 18 January 2006 13:34   |
I've tried what you said in your last e-mail, but the result was the
same.
In my last e-mail I didn't told you that if I try to generate a pdf file
or a html file in either cases the error occurs, and not only when I try
to generate a pdf file.
One thing that I saw comparing your list files with my Report Engine
files, is that model.jar in your Report Engine it's bigger than mine.
The other files i think that are identical.
I think that this isn't the problem, but I don't know.
Humberto Carvalho
> Humberto,
> iText.
> Jason
>> Thanks
>> Humberto Carvalho
>>> Jason Weathersby
>>> BIRT PMC
>>>> Hello,
>>>> i need some help.
>>>> run failed.
>>>> to
>>>> creat
>>>> Windows XP SP2
>>>> Eclipse 3.1.1
>>>> BIRT 2.0.0
>>>> EMF 2.1.*
>>>> GEF 3.1.1
>>>> Thanks
>> * -h HTML (default)
>> * -p PDF
>> int i = 0;
>> return;
>> if ( flag == 'p' )
>> showInfo = true;
>> else
>> usage( );
>> return;
>> else
>> if ( posn == -1 )
>> usage( );
>> return;
>> param=value ..." );
>> // report itself.
>> // information.
>> configuration
>> try {
>> EXCEPTION: "+e);
>> if ( showInfo )
>> // or PDF.
>> // Run the report.
>> try
>> task.run( );
>> engine.destroy( );
>> "\n" );
>> // group.
>> return;
>> else
>> String prefix )
>> HashMap values )
>> return;
>> int xxx = 1;
>> continue;
>> break;
>> continue;
| Re: SEVERE: Report engine can not create pdf emitter [message #111051 is a reply to message #111037] |
Wed, 18 January 2006 10:48   |
Humberto,
What version of BIRT are you using?
Are you getting a stack trace?
Also are you using Eclipse or something like Ant to build your class?
Jason
news:43CE8A3E.60607@almedina.net...
> Hello,
> I've tried what you said in your last e-mail, but the result was the same.
> files, is that model.jar in your Report Engine it's bigger than mine. The
> Thanks
> Humberto Carvalho
>> Humberto,
>> added iText.
>> Jason
>>> API.
>>> problem...
>>> Thanks
>>> Humberto Carvalho
>>>> Jason Weathersby
>>>> BIRT PMC
>>>>> Hello,
>>>>> i need some help.
>>>>> run failed.
>>>>> fails to
>>>>> creat
>>>>> Windows XP SP2
>>>>> Eclipse 3.1.1
>>>>> BIRT 2.0.0
>>>>> EMF 2.1.*
>>>>> GEF 3.1.1
>>>>> Thanks
>>> basics
>>> * -h HTML (default)
>>> * -p PDF
>>> int i = 0;
>>> return;
>>> if ( flag == 'p' )
>>> showInfo = true;
>>> else
>>> usage( );
>>> return;
>>> else
>>> if ( posn == -1 )
>>> usage( );
>>> return;
>>> param=value ..." );
>>> and
>>> the
>>> // report itself.
>>> // information.
>>> configuration
>>> purpose.
>>> alternative
>>> hc );
>>> run
>>> try {
>>> EXCEPTION: "+e);
>>> if ( showInfo )
>>> // or PDF.
>>> // Run the report.
>>> try
>>> task.run( );
>>> engine.destroy( );
>>> report )
>>> "\n" );
>>> // group.
>>> return;
>>> else
>>> String prefix )
>>> HashMap values )
>>> return;
>>> int xxx = 1;
>>> continue;
>>> break;
>>> continue;
| Re: SEVERE: Report engine can not create pdf emitter [message #111469 is a reply to message #111051] |
Thu, 19 January 2006 06:25   |
--------------050008050901040404000204
Jason,
I'm using:
Windows XP SP2
Tomcat 5.5.12
Eclipse 3.1.1
BIRT 2.0.0
EMF 2.1.*
GEF 3.1.1
The Report Engine and the Viewer that I use came in the
birt-runtime-2.0RC1.zip from BIRT download page.
In attachment I send you a zip file with 2 files that I think you asked for.
Humberto
> Humberto,
> Thanks
> Jason
>> Hello,
>> Thanks
>> Humberto Carvalho
>>> Humberto,
>>> added iText.
>>> Jason
>>>> API.
>>>> problem...
>>>> Thanks
>>>> Humberto Carvalho
>>>>> Jason Weathersby
>>>>> BIRT PMC
>>>>>> Hello,
>>>>>> i need some help.
>>>>>> run failed.
>>>>>> fails to
>>>>>> creat
>>>>>> Windows XP SP2
>>>>>> Eclipse 3.1.1
>>>>>> BIRT 2.0.0
>>>>>> EMF 2.1.*
>>>>>> GEF 3.1.1
>>>>>> Thanks
>>>> basics
>>>> * -h HTML (default)
>>>> * -p PDF
>>>> int i = 0;
>>>> return;
>>>> if ( flag == 'p' )
>>>> showInfo = true;
>>>> else
>>>> usage( );
>>>> return;
>>>> else
>>>> if ( posn == -1 )
>>>> usage( );
>>>> return;
>>>> param=value ..." );
>>>> and
>>>> the
>>>> // report itself.
>>>> // information.
>>>> configuration
>>>> purpose.
>>>> alternative
>>>> hc );
>>>> run
>>>> try {
>>>> EXCEPTION: "+e);
>>>> if ( showInfo )
>>>> // or PDF.
>>>> // Run the report.
>>>> try
>>>> task.run( );
>>>> engine.destroy( );
>>>> report )
>>>> "\n" );
>>>> // group.
>>>> return;
>>>> else
>>>> String prefix )
>>>> HashMap values )
>>>> return;
>>>> int xxx = 1;
>>>> continue;
>>>> break;
>>>> continue;
Content-Type: application/octet-stream;
name="logs.zip"
Content-Disposition: attachment;
filename="logs.zip"
UEsDBBQAAgAIABdYMzQtB4d18gAAAM4CAAAXAAAAY2F0YWxpbmEuMjAwNi0w MS0xOS5sb2e9
kM9OwzAMxu+T9g5+gqwZXSUihASiSEMCpDJxz1pTWUudKHHfn2yFAxQ4ASf/ +WT/7E+fr+4s
r9ZFUYEuzKY0WoOPvcLWUUio9hRFtT6iGoWcus7ljgaM4Hx/THb2gLxcbB9u Hw3U3BMjJLFR
xgCStQRVqeGenKOErecuqeVCz6nrObWzYhWeVioaglM3uTEhtrmEC2KSy3f2 UfxwQIIxfIk6
m6MiBp/DG8wGmoDNyFfcNcgdxp1NB4hj/vWpfq6b2kBzGoJpCFrLwF6gjWgF IXQvgAOJYPz8
sDZFYcrNL9tc5tU/2TxRq/+w+VvUX9v8ClBLAwQUAAIACACHWjM0EVAT5PNV AQASfzUACgAA
AHRvbWNhdC5sb2fsXWtP48jS/n6k8x9a+2XmvCJ2EmDIoGW1DIF9QcCMCHuR JqNVx+4kZnw7
bhvIeXX++9vVbTtOSCAXty+ZXmmZxLGrnu6q6mv56e75p99/Q/fjgGCz0UJe MNKwj40x0Qwc
YttysUZDHISRr507A2KaxEQN1CNhaLkj5GIH/vEDMrSeTzIPix/++Q/UXV3+ WXyBye9aI0JD
EqChFyBKgkcSaM+OjQwmJmQIDo5WE214AdHOPDfElkuCT5gSJvzUNJExtmwT 9ULsmjgw/9ej
4VfbM7A9Zp++pdfP3RF77msC7FullbouMUIvAM3iE9N6BvUVG4rwykzvQ4mC 43Dik5P0qT3f
C8KTTrPTLElx8yNTfHl78Xltr7l0rdBiX/7DVHsu80rPIJQyd7Fc9LH5ATl0 DQPecg8GM5Ln
8Npi3siMyZR88iJ3asQe982vDPXht6oLT21yddu9TELXELdVXzyCEAKRAaFe FBiEfRii31nj
0GXPDyDK0F380x0ZfjVsTCkTRk4Wqco+tzfE4H+TM3jimgUkeM+JG9n2zC/z skQJtfgWLdF9
Ib7v/R/3bpNQI7B8kLjH68INT0A3MhPQ4RiHyMAuGhAU+SZv3pj5EcWPxPxv LIYank9SAb0x
ZrU4sEnyM47Ccfpr2vIkv/o4HEMYpnewf4d66DmspI2IgaHQtiZ3x+VJb15U e+KhG+KwG7M1
GZf9v9+UvZW9N7U3cR+twHMdBoZ9DoMJopbj2+QPbEekYorYiAi7VBMN9bU1 JMbEsMmiRvHm
E7uTd4T8U1xzCEYHN55J7BuQ9BWc8Js81eLmLfqXTZQKOyThQhfKNYlvexNt 7tZfW7j5gex3
5GGLveM84wkvL32FYDrJ+MYe4pHzgB+xZmPWJlyyR0Yk2EOP8PPJfnMPeQxE YJnkJAwi8k16
CZI6m/8usM+0fijTRq3TNsWlfrN1RdA6TVulPcQbs2kjJtm/LVYJWQdn39cd S2+iWozatxzE
b6L4jmDbWSgtgF9mbMPv/fWDcdg5xPIQwcRmaUVoS6Y/a8H5zfYG2E7bibdx UQ5MPCbGp9P2
iE0O4qBB797lDmNMjO8zo5isPaQVemaYlKmBQlAkck9eDhi+WuZsY5SMVRaP UfZGgRf5Z2xS
FJ409wLPJuLzwR7cEn/O3XXQtB7vmMqMZwMC9DP/C3848J8E6J/0X0rGAZ9a 5cNwsItZX1g+
EGyywYRcGLz3nMIAp0Q/87/wZ8Y9kM+mFE9eYE6vAFRajP+sAlT4z3KcBfjX KjAHXjh+szb3
KgI28LwZ04vvMVTuoHvy4uVl3zM7v3l7jY3Po+YGU7D6C0tvIJjGl5LeXZbQ Vad8s4MOJvSO
jCy+jixL2JrFTWWlpYUKsEkYjx+P0Sl/HN1zN9YPtUOt1S5QzwqVI4aVfCgZ r22nFSPGorPr
u/zaBtXOR5EZ2TBKROl4ET1Z4RiZnoNh+La5cTfTsqY1YiV/3VzDBNEyxfK0 aVGYDpkS5K1Q
C+zBR0K1P+Cf2Iz8EmusAlgG2oPyn0xrYtaogGDuji3VeoMHYoR8t+BkThm/ eY83qOdB4AV3
BHYKxNVcMVS66Fnjb172ZNcEpLBZz9AaMRjTL8foi9g04U3G/end/RZiu3xR J94FYJeiIHbU
eP2BdZq8C4SRfq47a/F07qvOxX+TNBetFJh0N0xoS20w8/14ukO2/ubsnOCM n8R7PCgt4qy5
hxYblp8d99kTowA76IJ9p33R//RF/4NY/8Of0mNZq7vEMny9yAB8w8i2J5md wEpizb0u+/BU
2pToqTNlIWsmGeLIDqsIvZ9A76fQ+2lTgWCRvMLOkWsJZvr9ZJkqM6wTSCsj KxlHgbiHNiH3
0In9SQY3nhnZcUemZ/xRTIGu2ufnp75vW8lWnOcSflEsO/LvfI61db1VHd9Z 7HCAL47P6Upl
DST7gfXIomLEgilRcu1hkwSV0rBsZ5CSEDZ9kb6g5Vw3NorQ8bKmMs0xjX/k rRofoqC4OayK
BpvbTWPhh31fGDHbHIVji65l28XyMqNQ2NVHAZs9UIsNPi1CUeihJy/4zuZO AREbsiu07/DE
0vZ9e6jo6vQO6X+ef2qwaaFuWwM9eawhepAHHADwFZCKzLn+E1dDBcB+LLnP JPdfSt4Af5xH
ERcCm+YVDt6/UYB/ba1nurwFLS/sxT7rVCxy6PFih8YtLsUinuN4Lm3AWlwU WjbN1SiLhMux
yyJNO2Iaw7NtFtOsv5ZinDnxUs0zp2tHDGTGOb6NlnYkw0Lz8qWaaF5ZzW1E wyAKc42bqUQp
dpiKr3bNz2oakTRR55T2QibEeZ94lO2NRpBvyKanPmEjIkJzKBnqERwYYygb H7fMjIZyEI/Y
JNk1kzJJLgtCjcYv6SQGuV7IDBa55h4rVRgFLk8/X3lG9qqqLmFTDrHtx+JB rBOL8aR4DEUu
GwSbFrTRGBYVXtGQjqmnOn5tdfY7h2Q/B6QFVckiz705vz/lARnv4FE9K1S4 gpa4wrU3inMg
6+fWJRZU+Xx5Pg8/8SvvMw8yMx88gJF5/ucQ25TUxqFfLUw+3ppRBEmyAfMU uQrBF75gsUDh
uUhk8nvhBXjE+bNBeNprEdGBIancPC4vKuDjdNljGHhODFNOIMy3e5BqApY9 uNqR4HirgIUE
TDEgVBCpIFJBpIKoGkH0Zr4OJJGfxHt1y3J38t3tKyTj5444XkhOTTMQF5cX M/8pTh1m7D+q
X8xtyuXjHEmqxL1tpmkS6NQwIieyReNyf92dZhKDOrqFZNQzsMvt/XOIR7Y1 +AWxZgzetuMv
5DyRwfppNUsUMNxcZrJeiGg0SPf7ttGQvEcKdYHepcuRsBsaeDbVQtt8J6UE 8WpnQ6Sn8IyS
vMq0XGdskpw0XWMWhI5nWkOLmGhh3aFWq3108KFz2D5oNpt5qZK5w1B9xLP7 lSXDnd2AdsPG
g/M8xdVpf2y324edKlbj/N5iWRUp8PStVsftx+/OwecGcefqsXl4VAFYw6CS sAgtFdYGSRqV
c7gHXAXLQmXxFUXWILe11n6MaX//qN3uHHRKa+TimsJ+UO3mLbPrW6WugbKh BonHOmXWX8bL
5jY2mb81tYMYXKtz1Om0mh+2qrg7EvGFAzYOOuMvam2bl9ZPJGnwhmIz17cK tntnZJ2Ucua7
c0nZ6YwEsrOPdX3V/Oy1Zhhbb4TyJAKedc/mpvzt9t7pX1/4xx3aBS2mlGoL dOkWaFJ8yv1Q
/nL1M4HscdbuPfsvTH3p+HZuy9VrpxvEyJ5dK/ZF7a+ba4HvLNt+7FjyQZHF VnFYsVSE2PhJ
2/vXpWvYkUlOn1h9LfCB3ILzNTB8a8V81MzQ1Lr33e4fG7cOy95eiploBYMY Z/DKvF/qRwPb
MtBlF/zmHVT9u8pqe/tV0j8DVvck+Bq/+LL+u6TakpdSf2CUD9RXCFWsLa19 zJf5Ku4i9QDJ
V68G2GU3/139sKsnXBu73xVaOWijMPRcqvBKwmtGji/ezw4mCrRs0CJpQUGW B5kAV5FCKwXt
0PNCouDKghtgh1ASKsCyAI8JrJ0ouHLgWq5JnhVaKWhtj0FTaKWg5TT7Cq00 tENs2QqwLMBh
QMjfzWbbjJM4+eeQ0FCVoLAS8DRyDXN2u2tvxFPDFfjiwAezr2wo9IWjT+lx FfpC0f87Yu1k
N3LYL6oAJRQA8uVs0rNG7mdX4S8ev3inS4GWCVqcC2QSm4TkNzgZSEEvGDqc u6OQF4sczplR
yItCXrOl+hqD5me7KczSMdds8b7GoG2LhrXs3GsNvI49e51x17FXrytuOClQ QZYNGf4qyBK3
ssSbSsm/CnexuKkCXgRwEsT/KNRSUSdvfFPNZHJ6/LMCXzB4vr7TTYtAVRlK LMO5+3juhvC6
sSpCeUW4wZbdA+KKOr10sZOFSF7Avrbc76oU5ZYCZt3Qxg7Y46oUZZWCiOZ1 oqAXCR1Wneo9
vtiNEtR6cLETBaj5sGJHilD3EcWulKHuo4ldKIMzDWeFvmD0QSaGFfyi4UeZ yFXwi4KPbSez
5HsH3xX6AtE/mAND4S4Qt2taCndxuB3ieMFEIS8SOf9LFWj5oLOdfh09pb74 Qa/GnsdUQS4C
MlGg5YOGPwqxfMRUQZYHOT4cI/lX4S4WN1XACwDu8oMGp58U9nKwUwV+TfA4 CsfEDeG0WIbl
NPstLsmth3oZ1gPEaQ+QRZEfEKpOR37jFNwLL3BmajW3I3AXnHbFT80gJsIu mrErGrL/HRKO
PRNdfL67WVGR2LnRbrCLR6ljCxphEgDn/Wyp4/u2L2Cl9DIDGgQFLMQ8B7mR MyABslwrtNhD
/xGHe3GLMFw1UPNbfFqBw35ll5E4GxYZnuOziHBD7inYHnmBFY4ddNM9rI+2 MyYWsuBMOIfp
Vb3V18Jkd7m49/9a+RQ8uYJWcFAjqZo66OlBNB0jOB6In45NAgrti4ni22ll hS+XKo5S6533
epefb3vwxkwd9JyxJ3ggGRENmVzRsTKj+1GYnhHHGgp+khaKj9KqqMKVzp+C Awg1G7sj7ZJ1
4dB15X/G1VTHLY+h9VS87hBNSQ6dt9wL1m7QsawwzE36sgNGLTZ8dQmaOQ3t eDuZ6LUh7t0s
r6Le0poytM3OOF6Mj2WpXXR8U07lPFn43xqTx1vMxqyjWOw1OJHLw/kTnMpX xmy2NoDSpvzq
tnuJXH5Xch5vdcS/PDUsCWqQh6fzVEQeYVhsxwhoxXTMLHJoGcNnjZ2eggxn o7nmvHYeRAKD
Up276niKCMdMh5Jtu5Oq5nWhdz0SorMxDrABX89dwwPjvlMY1sGw7rGsT/xG LT42RVhdYwhS
AIn+C/5bbuPngk5J3ra8+ZyLnMEC85DAxXapmGYnL8+c8IFN87U623hRSeRZ T542ODD6C7sI
lca6M37DrRdewHjw/NkgPvRyRRyhjVkv6prH5R2dnUz3xOKAnLPrp5P3z3xp Ikffh//u0lO+
RSHE381DPydY/KuJBhP04h6mAZnCNcixqAy4lA1cNjNupP+Bs3LXOZu6Drth U6eR4zZzjc9E
cgMqpgO704yK8hTbmOapUzWpRTapi9f1uG2p1hVnwPfE99qPJt8qYCHDx2JA qCAqKYgeMPVj
UjZoHq+ovyvRs7RkhYSNZO0qXnKKlyVrrumyyZp71MWIOxsT4ztf1PGCcrOq Kg/QGRDswqQH
nru2hsSYGDbJbA18CTw4AQ5h0zyDPL+vcSLbupsjezxL8CSvPZVvORUv3fm4 +cTu5PaIg0eE
k/iy3k7OJkrjPddX92WTqojv/fVwHw+aB/Iwid2ihOKDLpRrEt/2Jtrcrb+2 ms0BNtrr7TeC
6dPNxi4XHO9DTTeG2fSYGoHlQ7YfOEjDEZWhPTt2rmmsqb9ltayftVpfTK/k X06/H6PLJGdp
9Yy9ZYkAoqXJbD2i+ZLOusLQsgk6O+6zB0cBdhCbuxLaP+Xq+veewzSiQ+2Q P6Unafcr+8ky
mL2IH4k5jGx7gnyBmZiVhiyrZvvwVNp/ZXqpDHLWQvDpUIVL0E9K0E9L0J9v W5DL7F19x5FR
nrfGbDO4qyYym069yvgqq3ilYRbvKbeuzJrAzKZaxHGN0k6/BpL9wHpkgTNi YZcoSRfeq6Nh
WZYOJeEtvIahL2hxNwyYAlW9rLdMo07jH3lryAdBKG5Gq6JhZpKdzq/TFisc W3QtSy+Wlxn1
8vl6dikIVhievOA7Mq2Av0g1WaVDgCfe6hC2R4yuTu+Q/uf5p8bl7YVuWwM9 eawx0/M84ACK
sQJucQxCX2zR0Rm4/VhPn+npL9Wz9doJm/Fe4eD9aqXKYdlqZlGA78ro8fKY Hq+NadwpttY0
Iilv4ynt8Tzw94bnOJ5LG7Y3YpOIkcbGJz5hrk1obVY4kzJJLotYXEyUIdeD 13si19xjpUr2
m1fvaLdbXYxc1pqZFvT6GEaVpa0yFlQlizz35vz+lMdnckyNnhUqXEFLXOHa G11g3nbWz61L
LKjy+fJ8fuG2FDPzwQMYebQDWYHZwhSy+ZS/QrXfVFaSw1y7Zzm+DZY9uNqR 4HirgMUkORQC
QgWRCiIVRCqIqhFEKzK5zKzEbkPosvaSbiG8LoveJH275PlPfuowl082fu5t c/qS7qlhRE5k
i0i5v+6ihDsdQS3SLSSjnoFdDvHnEI9sa/ALYjHpwKt3yHLRExmsv3O4RAHD zWUma2GIRoN0
FVKKBj2Gn5Oma8zC0fFMa2gRs5DlR9RqtY8OOu2P7fbBUad45DPgsBs2Hpzn OVztwyJxie6v
b7U6bj/klxvwufGA52A1D48qAGsYVBIWcasAC5yLT6IbLa2ttfZjTPv7R+12 56DTbDarUFW0
1KrKxGGMCvtBFSKQtwyzS+TMjE3tIAbX6hx1Oq3mh2KtuKjZoqzRJyIPIs+K uyMRHx6H7Brc
ndc2Wj8RCGnNqJlrmlVmJ7N3f3p3Lz2dhvV8cyko6cAFclGOdX3VbJS1BiLL MkNiDjKRbghj
nGwioB8N2EgZXXZhKvIOBmzvKqttdQLNOH8gD6bMGdMqsDnxj+480O0io6Hr vchFN5YReHRC
Q+LQPXTpGpqud++7kF+NMlNc1Nb2df389t0O4Vvd0GDCm03zecvwzPoBvr+5 VqBfgv7z9O72
dcxxin+PGFFghZMzz7bZdBxCAnJaqW8ZlhdRFAU2LGnAuucx+kkfh46t/89P PJeMoHEY+mzI
wF/4pxHQQjs6HnhReMWu6DAajVwmO86K1YdWQEP9gQbNw/0kCaa9//eXi67m m0PERAoALTb9
qCX/846vGrJHLGMRHfTWa4ZbskJ/Ou1dnhVBz7x9QauoXpFEK5JoRRKtSKIV SbQiiVYk0Yok
egdJomcnCi8Hsoq3OX+a5E0n0nXDpVicK8jiPLvtUQatsUKwAIF0LuS6alQ0 cIoGTiV3Kho4
RQOn4kXRwMlhWZO0q1IXnPUjhZsZWhXNDbfBNLEoirgPH81me1BJijjSIgR3 5DLESSeHqxgv
3A9BCVcvNrjqE8HVmgNOEl1awcxvlSrFm+Rs+VK9lcHyVn2CN8Xtprjd5nyh cloUo1ulGN2K
IHPbmsft1XcoC2Nvqw1x29uWiV/kgqFC5MOz/F2ufO2zVIccKy1Vp0j2FMme IhxTJHuKZE/5
vCLZUyR7ajdP8YMpfjAVRCqIVBCpINphkr083pStE7WeYtVTrHo7zKpXOW66 DRepS+P4U1x6
iktPcekpLr3yufSkNLXL97QyDW6nIgyAu0H+p3j/dpH3ry6Uf3Ug0dtRjCrm oP5zJFiT6id1
wQnEdQpr/ljZ9zCiCmY+MK9u/mIjmefJjwpUFvfjg/PsA9yi+B93gcNSVhko D0XFxPlDbS0s
5d/8Eag3y2PdVISbinBTEW4qwk1FuKkINxXhpiLcVISbinCzkoSbFeTa/OFo NpeJR7AOBCLT
fTf2zHcU0fU4CSWL/8FIQkvlxlTKC6HnrJcyRQOqaEBV+rmiAVU0oCpeFA2o HHrNGjCAKvLP
6ViqaN7PalJ+HnSIOTisJOVni5C20TbkYYtdItF4DTPbBde+8jDiU949xPfx FgH4nf3eZV8G
bCC/h0a2N8D2Sfbit1zISyHhNjujmnJBndoOYa01lsMVmkivCnepbDzVIC+d lrIW7KXVgiuj
RkvmL90WffIeRSKnnxDY9DP48yT/3KBRki5uXXLNRGmF+T9LgFh3AlBWEw35 JKB5admEonOD
YClIjaICrRQV6HoWfJVxMl4pAADT18j5RQF6kz4qedkvFpMHi+RdUpeT9/Mo 9X8VQ7y5Bunm
0hpZ/PpjgVSbO0SJmpBb5GyWjFipNsnoqb1BaMNhnaTls/Y0P3PMCZVkjDkt NTeFgy07Lwsk
sqRUfCK87vU9of+2G2xU4vJOvQHqG/taU2sdNUa4MbDc3KyxkiY5tlpJdc0t 6Y3c3CInkSXF
Gonwutc35cP+vGo8lSanzlPxNa91n9h2/n31S6lSrPBSTc2t8UjYlM4KJw2T +I1WTCqTgz0W
yZVikUWKdsUmoefZlHM25W2VGcly7TKjarcs82iRJ4nmyYovwkZZfTU3FKtm WLhqtLWWdpSX
eV4IlWKUF1pqbopnKE1eJkiFSan6VLo6BUadAlO7EzEOTXPwgahDYNQhMMrl 1Rkw6gyYHzWV
O7egUKdXqNMrZBmXKZNKCvCZUx7k6DLw313aG4iQEH/XqNyccPCvJhpM0It7 mAZkioaFHIvS
w6Wsg8Mr9uy/FzkM//xHI/0PWkDeHp1N2yP23IYtkZy2aC50J7Vvlebdi5fS AAFSQoTJ8p7w
wCZSA3Fx9ymXEMTjV7pkKJQGgSeDgUQN4dQQTg3hsoHHJvFMmfzmZD0NK7I0 punQ29A0rpVT
XfYRUEtKrM6AUmdAbXkGlFjahjoqQhlzK85vJl8VDYxitOg3mKc0PeKC9Plh YYp0HLc7xWvU
py1Qqcr1O8IbtkINPAUC48ggpOVp1m/oqOTC65izStPyEehs5Gu5p/xL2ZVi DkpVrt9AnicT
UoGK0HusQzbCooCUfGziBmlDcIJcu3XQPjzodA72K4p1JkVnCvhj56AqgNOs 31arud/cP+wc
VeRAPnWk4hY5wFNrflDHK272OlppAbFmonFppl7v5aVqwlzx7ZVWq/Xx4LB9 0KwU9uRNp6rF
esln9P4/e//eHLetdYnD//+q5jvwmfgp50zFbEu2Y8c1mTq6xvJItketOKk3 Tp1ik+gWbTbZ
hxdZOp/+BcBLk2x2q0kCBAjsVMWW2hKxNjfW2hu3jbZnHEVHPqmux91v+6MM r0y+S2nb7d5d
v8PnEsFsPJCRJq7PX2Iq//xKjjtpC/DjvpR2XRwHbqVV6Fbawq16A2V056uy IPsx4dlkMk18
48q1wyB6iGK0jH4yLnzbnExOb07J3hyjtARoHJovJpOzD08Vwre/k/OwJn93 HA/SLKMBoKw3
8nwKXXJj24MiW3lycwbczMO2SdjOw2Y7T7+rJ3ttF5Guabj2Eq69hGsv4dpL uPYSrr2Eay/h
2ksFr73U+frJLgPaMWEaxwWUml3huF5MEHGTIbSetc79ZsWxtdZ2FiyfAjXp HjqT7KErLk77
nP3bZ/yhKjfTtbR3kHm0wTFVc8z7orHbOF6Z7/Afo/b2bpv4eXSIdmF6lPtp xz3P/7ckLZQD
GEc5gNLA3iPv0sPWxYj7YXY3MD8m8SqJ0+JYnJpZq1PWK7m0KVDsG8waSu+5 NQ2SP/QBd0zG
T3hEGf8RujG/mb0a5bk3xrcBKpk8ZbIp9GKr8lDL2Drhw5MN04YdiXBrfv+8 agMCpFCjq6hU
OPMGLVcefqvqEDS3aFhesmt1t7/CxI/dJTLzfdFmXntDHQduNXFYj3KHsb/i boUCyiuz8rZ1
c64h4NXRVii0A48ULCAr1DjpjvGwDDmfipIjylRP3W3moDVUeUOpDaeS2PXM d1Z0GzOt2tiy
tuluo0E/xjOluTFPxX6oLn7ar7Bp4Dk/xu3ChJ+YouRNKzo3+MtZcJ9vUVdx 9btqorAFbz4w
6qHOJWjmlo2MVnAg1I1t9e5D4nmfAuruoWels71z+UZKdUSjZtiwUsGp8XYC UQMBsjAiWXCD
rGg114WwjeRw1Cqwy6KBk2ymrUKKLTjFpvMbU3LBBvqEMy11YmTNsGFjJKfG 959argGA+Dje
FVv848X6e3oORh2Sbto2LE95tL/feu51+jcOphHuwHGk3nJu3UIxq7m8ULQb rmxDA7qs0nru
ppqAf8c1Lk2viOC49zMd+HJv5jiZz1GIHO4N/e5HyYpU70fOmW8HxGVDbNG/ 8IvtutxMbGI4
ym0zMV0iRG+5G/kCXmszh43jnKHs6+5C1lV29oaRolzNDcj+sXwHGAjqKiVt OwUGXD3eeZN8
zLUibg0z76on3zvNFDPm5gql/S7qRjjA7PEyO1/8zTtjtiJ15FgrpY6e7bZT zKo/LyztPP4u
SCL0DaHVupCSum5vMFas7zkC6rYLZAcw0Hl1dD4rba484at2iuU6Hyz9aF7F BAxXh+FnpFSd
8vwuWymW3TyQ9ON2GREwe3wTbe28XR1FgL/HP9uW7XC4oBscVKxSUDNQ6K4W diBaOZdsBHZt
pO6epdxAoc5lB6KVcy+DhVIH7BrNE+pYthB6bURLoUDcVS3P2iIl4GiVVq63 JAPg5PFn0V6w
MLE2T+kFourF4op5YmIxFwjdRLoCBdg7rh3DFx8H3u/KqxV6YuzKWg20k7bc +T+F7jIIHdfy
FNe8BkPFqR9HMO1zmC2AQA1HpIZUQT4jGz+bq0hxqK/XVLiEfn9iRTF3gadW Hc2iOLRseiEY
34bC0Hrg3sqHYJrYt2ceWmJWcH+D5XsijsJFMkijOC6fux4aIDZT8xgHxv3C c7r5fWnZYXBu
EWY/qBeZN20UE5T54WgfjzexQCge/7TCplef3HwP/G86cDq1VBZms0XDgt8p ImD5+FnuuCGp
FXyHzNP8K/UI3mCkGG5zAdLZ0QrXE9llrTSul6TOyC5kIPFjK6F64gU+ElF+ fp9+Bd1JpYyh
lBd+CoP7B5XDSN1W0UGEF54+NK9jAraPbUKe3F0y/LJeqd8oV7J/u43CZxc4 F+1vNa8AFftH
nx9QAcEjjjCIVun1Q+TkRvZdECpWLHi7oQKKB/ME08vpx1aEtHE8MVYq57ME 1LKa9G5QIPMq
bS1+xOHg7LGNAqYoHmgE0NB1rlB8Gzh4EPLkaDlzF0mQRAoW4mppuPCwMgS4 XoqzCyAo0Bjn
IYZTofQCuQXyUeja1R32J+mdqvh71W4RfMRcETcKDgRpf53ZCxaoy9iWyNK6 6mnZ80Elht5R
WbshS7Uj1I9ZKuyqUq5o2mrKdkQgJ+OdAm3wbfqQ9PeVJnnZUOEcZwtmv1Ws EEVBEtoof9J1
9r1qvt/PXjGrW8Ngar/StRsXSL5K06GPyBE4ezzDhabrbOfuQq1bgbFBw18K zKxRuBN4wDuB
1xN0F9i/FstV/QWK86B4FKUHJEmkn6SPmOTqOski6sRBcyvx4qj4F3NVnPQd DTFzi4VamnJo
Hd+efrXCt3PXQ28nJ28nn8JgEVrL/z58To6vRpOjFOVNsMRPx5++Ml9NvtPn 4n/zlgj3QasI
K547K1A/c9Dq2YH50sSP/69JV4OfMjC4am5E+1opnPAZLtjpfCH+2/PSJYvI PLuPsWQgZ31G
/cn6S8ZX1YkaNnS0e5DhgzBsm2fDL10ffUiWMxQy9/te2WvHVwHJ7Ogmq1p7 +ib4hnz3Pzpq
UWG6nHLEEF7jNhC6TMLD/XwkqUAKqjTWFTnX43sDMclhBdQsuwwWyh5sqNon tD6j8AMNVRwg
Q2PbdsS90NWZnyzJxEl1LyP2y8fdzdhBiExy/4WFxwl0C7X510n2j3+bf9GX cxtEMf66GIX/
TV5lfh8xfql/uf48+Lv45LOLvmfzcW+ND4FhJ1FM5oyKcGrMyRyaafxO59ay Qfn6gTadxEtS
Y0ywQl8r/lev/wyAqxJcHBlCOkv+3vqGv7LWP3J3YL4ENPKgqVWCN1zfjV38 oP9ghCaAkQXM
aSb263GuQUYxdKHpS9rulzwR/ZIlol/yKfQvDVPoYIBuBtyED9m6ZRIhnJeS bYb9digCfG3g
pyknwB4b7EG3POYL2dnMx8Vy5Sm84bHBWsHbHbkg6tcH9PG/XL4XW0twGyqY C1XxMrFd+gMe
H+85FpRvnCwcu7GlUh1538PYYRV+QED7U34PUMB4vowXMulRU/bqXJjxY78Y 8Q+walRWiT9G
p+y9MnuZLeOhOuG3z+wFD2KTQrEp97CRwUwXarDUxah6AKfFmTwwQLQB7HcV HuM2kcX3HrnL
wF+I2spTfoHG23W4p9tAjChbbTYB1nhh2QFOvVCMAFZbWELmvk/Iz2my+lHY Ksn8N0M8fbyv
i+dl8rpkax4UE4w4tFjxKFQH/K3gCJN6t5xnIKfbRFolOIEp2pvy6JSt4Dxb QXyC6pOsr8dS
vkAJL1PlrVDSZPFoS5TsuNnt0iX1fjyVL/jLTBR9rx9jGH2u88ugQGKrUGKb eSGtYW4U97K+
bd0lAPVwqIfV+ityH5/KSk8NFK3zTEH0UXkKBDRepXuZqUvxe4qQgts19zJX CnbzgdSb61VY
wHzI7uqhADAPg3nYqEB5r3IcoAaKVn5GINo698JfJbFat+3uMFK0k5kD6RPU CzAQylVcca5J
CzhZhWN16W2lF/4dBkA+UPpY3VZjRR2r4w6oy7G6raCA8TBCq4cAwDwM5qGT eNtLHMVTeGqi
+ASeKYx+6TuFAio//hn4Yn8Z0TD8ivLdMwpvCa9ZKnhTOCc0PbYJ1xAByyGX 2xR+QD0c6mEz
unP8BvDPqJzRZSaKzugYw+iT0WVQQOtB6ze7BKAeDvUQWr8iMwVhOmGgYM3L inliNJ4xhA5u
vQkRwl2blriIFPdxxVYJHM4FT7dzvttxQagf/+RNxbu6sF0mpsvIcmC40nsr Kr4GFysj4n7g
IPNDoOJSWt1CocLNHEUvyS7QAJPHdv9vduMW+21QTY2dhWEQDnwLcLmLTl1S lEB9eVrbKV6k
2GPpnG3U8IBYqZV2HE1viilLtfldtlQ8w3mg6cfxMiJguXIsX4WBjaJIeY5n dkrBcMZYevM7
wwPsVobdN8E35F8tQraDBNm4XbFSKLO5IOnM6woaYLUyrD65tcK0aJ+ylF6b KJTP7GH0mhNc
wwE2j2hS0A3M44cYHYWh9UDPNzMmbyvxyHcoaSAim6YKFRN+cDpnCJuQQFiU SRPev79J14Kx
4bG6s3dVM4UynA+UzuyuwgFmjyhlSGLXI2bZ38RkCWm/efL+/YnlearvG8vN lGDbGGsoPXcR
5XBAOxTbEppODaXXDKi+B7xkqgxbwDnA6cnyMiRg+tiyhLPlKn6gqQLPDUf7 TjervcggfnFB
jkUFUAmFToOe4GboTceHz43UyZEJGAoMPBWUCrjrx2EQrcjWmsA3f5/hdsk3 al28+pilwyor
fzTd/a6Hz+Xxt5iVvV2IILqOd7S9y6+XwWJhzTykB8Nza+VhOmtE7BifIwPm q3Qw87EsA7w9
tpNdH4JpYt+mxY2Hnm1p6E14DPMpvanzYYrUThyrpgqPKXzg9A4oVVigL4od 05hFcWjZ8dk9
spNY4Q3djdZKcGSDE6KeBzdqqID1arE+F3Q9WF+3VjzreSHqx/o6KmC9Wqz/ DWkS5kuGiuc6
BzD9aF4CBAxXi+HHQeAhy9crvG8xWjzzOQPrpwJbwIEiKLVOVJq8+U2f2bzf 5JrN+03O2bzf
YDZPPban6wiqEz21UgaOs0XCgt4pImC2Qrsp00+Wlh0GxlvcKdzYxY/5D70F 1YhiK4wxYBNQ
jQWV5dAe9vkq61+frwzPnYVW+GDEaLnyMKPwT32++tfCC2aW96/sH827JeAe HPeg9yLm1+Cd
WzYRGoXvRaxZKvheRE5oetyLWEME8VyBeP4XIlWz/jZy32bn47D2JD7ZqmfE Ae3ARt4LjKdN
ovQUhzXD8h/WP5a9ALBDTzuaox41zkgi0vkbQ16TLUbzJWIo35hW6NKHID4P En+9Ze2t8Xur
lwYvB17OGF9O4wtJ/zFEC5dsnKFjDTsgBcxjZAJcdeFanhd8v/Dxc5DxqxGH STqQwJme5Rsz
hBMq3KFxwuWmP4LjRG5UBMC1BX4TfLzDGus6xASaaWc21MAvrQfjw8cbkql6 ZBJwFaI7N0gi
QhL6oy7hAtgFdnWz65KOg3aa9N31PEIrIw3DhE+RHawwsebpk5Bjgj1gz3Z7 liiK8KgqMnDU
pjYYUXpvMYUeJPEqifGAabEg2Wb+wwBZfchWEgdkoGwE83kDZj+I6Y8sccKH m/DI8Jr+eNbT
8yyRPg5MAVMeW/yRZMgAqB5HhT+JEptcHDJPSB+j63bCIhmg2YXms4u+T1F4 h7vLW+NDYMRB
4M2CewP5MdYBl/Qlf+4uknTgDjDVg3mK5lbixQRajHE+ix9I/hm9xSPv+3hy Gy89gMkYJqtF
aazzJh4t+NHDcnUb+A/mdzT7HoTfTMeNVlaMHxiaGbLT4pNxrkp3MpXfsrQg OHu4Hv/aH/hv
UuDbtSPFnF01ToB7+QDYvnFwTyCwv2CsVWI6CQm4e3RlYpLlDIXnQYhH3rxv Ab83o7TDmLdx
vDLf4T+yHnSN/p2gaKQHSfYyjV9IGLD5lDcRXcDHo3n6AxvL7gxaOk0JTpqJ A1LglDDVXjPV
sGI8cnHeGh35yoOtKUqeidQ9ld90oEZGCuvxGnviis2q9rB0wBRrEDSP+v1P 8qeajq6aNrhn
+TS/Z1bVBAGyKGWS5j20A7w9jpx5i2+P6Am5T2Fw/6CUKJfsGlyRObTdYiZj AwMwdHTHmbFT
l4EfmdnWBPMyWLA++/SoMtBztHSvjfsf5Nyg+/h3/IlSItFs4uB6wRdGq1Df DAUUZGxXVd2E
CLEsVNzUxpVLp1LyAwy8p9/SRk8Cz0tP9Q/UTDSE4uaT002ZtmJLTU0mClhw 4gmj5YpEExRQ
3JGOqmpOzbYtaEDoJkvF8Zonmm70bkIELB/beuPvfpSsVgHZWvhxhXgtX7TR l3ypSQuJaTRW
pMpwBdRVaBpBgdaokVFkdQrxy9SA8VuMFcd4zoC6MX4LKGD82LKL9Fm8JjZo E6WfYNbOguzT
SSeBfsy75qrok/9gphncGyFdcU3Bp3PXQ28nJ28nmGCL0Fr+9+Hzc/xRNDmi j53cBEv8ZPzp
K/PV5Dt9ZlRsbt/o8ZugnzIAPTrItU7po9j8/fqSS1/Eujkp62Zuz8RJx2J8 O+ngrde6wlcr
fMumO3juLAf/7NA8MF+b+Nn/NWlhIIeerpZ5jauAX60IN1DsjXwf5bsiR18A catlgxQ85Nw6
bDNls82UHikrAJJzX/cxfu40q1ZbnMZ1ZHrcyS2yv5HHzYPQyA/Avf16iNDN wwr9il/UVeAk
HvrJt5bo18mkOBhX6NJP7w/Pzo5WK8+1aRr/qx/4iH5IeikK6ffqYFzOkOVH Zvp7l+4c2Q+2
hy7dKEY+7UdY28mxXlKu9uTW9Zy/0j70a27Xmb9wfVQ6bJj/wzuMuHTw8Ceb /HbrX6u/v9Lx
xb8ZWXiCf5l2watj/JPUKxmLUl6l35Qa5tduXuux6Xk4I4zI6dr8hWQ/+8+D V8j5+dUv/EB9
sJaldeao8bkOWnnBg1n70X8evLReWweH+2GjZ8aTlUl6QDqSxnhO6YMJIBz/ DWvd5w3HDRHd
k2PMLDy2svc9P7R5VBY3c+Q4Bu2gxkZ/y5/+t9G2744TT+6GrMHCE5Xv3xoX eW0G7Jt+D84U
Jg0CqUiWraycLTdIzmmcvP2SpZwGTTi/pAnnlzThNHC6SX9rkj3OvN/3ePI2 iNNybYNVihc5
0sLl8Ua/kN8qwlUpKJVQm1luLiH6bPjxJX/Ol6uzmyMy/vhSwm/42MFy9xTm hjyWl006qCv3
x13TqpsoJE/cJ3HKG90rcaJBr/cLHAHEfLqaQMyYW1Sdjkbw5FXo3mGWLDC/ 8kaKiXF5Wkhz
ouz5pUwrQjH+J2RMGjS1A0kGambzfZXkOsr+kcodTWeMTCdlaaEyYC7GyoU6 xbdu1MrDzc9b
J63p2Ls8q0MmC8g8Vil/3Uf18W98yT34pfDgl3Ye3IXWeH90bVQm5fJfe5Y3 QibmCPwuUSp7
8Bf84C+ND+494YEHqO+t8MfHTWAwzVQZwtMj1JNsOmuSzWWZ1PMs59OPommM H7L8MTud8Cw/
ncB2InuQGcnyLD1HW/JZ66xwOykTOCfTgD9hq/KZ7P2jaL/ZwMTHkuXQWru0 QmHLWcGDNy/e
vEIvmE3kc38lTT03T1UpWVys6ZO9Dt2Mr1sLNBT6vLg+37iMhN388itx8gKN /87rsjGDLBax
b3Ds60PsWDFEHZIduucuV+Sw2+Lle0XI8ZiBgxBmGBBAIiARkAhIJAeJ7izv DkXmZ/JXtoBG
P8oe8utPKyu+/XU9xUqmTn4tJlHarcG3mqftCT+YfUV2TCAYv65Rktq7v9If TtHVJszSf9lp
MfsBzxjG7/mSzY3nFMs1xpFtJ8vES9lxc3m6vuaNvMGox5ONqW35FOL/jq2F 587+j4F5uMT9
kdQPIcvZ7Rf6tjSAcdNn5nNfRpTMiulFLi1M0sWrwRqahJiMEV3a4t9k5hpG LV1aWGKWgePO
XeTsM3caUf2ozpRafvzs6/KezsAeHBy+fvnm8JfDw8NXbwbE1X5OF0M9OHjz 8udfXj7H/w0I
NY3fX9yDN/6XmH78jHz97KtVe4PPX72WANY8lBIW8mWARXoXnQV4dmAemgcv MkwvXrw+PHzz
8o0cHQtrk8hXVZKMDJW1CoWKRcl5tTl+7Mbn5stcHt68fvPm4PnPw3qxSWEj rPIoO9HF8MVd
o/TG2hh/Rn6axWLfl/xhZA+18Zzptq7SWuv05uj6hutWHrKlr7oLpsi+0rMF kz33JX1plU1t
26OC4jjdsEDWQ0mihr+M7NBd4a5hrJIZTvWNi1MyhnpKss6n0rb2+G7CP0Ic ylH4V7arof1e
QnP7vkS9gX6NVgBSP97lu7OzXdmZB8qbwKrj9+znWIzTpWv6PCAKHuI3Hyzx +JxcEVC/yi3K
dtyMoJnfsg6T3U9pOO4C4XyDnFcJfNJ9yB4Qy1sEoRvfLo2r01fjae0kP3RD lut3tit/K/jZ
p/RxP/5j75yI74P26KAtTz2JbYduk3tbTNbiQBIRiXGM7McjaR++/anpZPP0 bDq9+PhhShLq
MbRTnNKxEzxuWWYTxdjp5ELdiG62oUKRzqdns/ySNtiyggJZrmG5zrX9Wpt2 TezuEM85dWjW
zz3HuhHd8qIhs6dvG266K3r/eKUOy9t+zzT2Ti7pwsvkwOw5IP+18T8GO8GP ydKJoKx/TJgK
rXv/4fTC8OlP5dMX8jx+98GF8kFJdEfyRi9DEEnWxp6Xlq4njcgQznfqACib UhjQOr/W84MS
c9eL+ftZ4dbqzRlPj7N/PaffP4Xm2W+eSlcwzWKJstro6LdO7TZvkI1TvCFs uxJyzB5ssmSo
Cx9Ztgbb2YbcE7oerX6kY3GGfX97Kcy9mS5L8UvWVS6LPjLuMpfBd2vmIa5z KMNdB5yduBz5
7Za7bRoqHvBpFyLD0JGhHuHTcbs6+VFqz7BZEss2gRHiGJFpXDappVC0yCwa OFYwbRV4Iehc
WT2dvyb77XHGHCk4L1KyTcikCIf2Ww/XShhgrCbvWK1ZAPkufgf0k1M0TxsN w4Dvavt14sfu
kusFlqVfTPfHp9dMptuP8G+fZl+MXup2WjeI2A2AAJIEMRON9Hu+7GwKUye3 lusrmYRQy4Sl
IExb75SAUASQfsibflx45K15R+EiITvlh7ljmuyV4ZpwTGOyf+U4mc/53MK0 o95ZOoImpZJX
NPeOzOnRn2karlCxs2GshEpnj17Tk+/M5T17cI9IYV/zq3W/2nD1xXLlDcyy TWT3vpv1RfPP
q8sUH/MrBCWqMTik2cBDySoOZs7PtffPC9/2Egcdfcfvq6EP8M3oMzC0gpJz ZzqxY57enJ5+
5qEOwoYU9eyXCq5NHsAlQzoKQ+uBU5q0482lNVh+v75ME6grK7ZvydtUbmy2 zVAhQzV+YFo4
nWztVNjVuXkCHcwOwt4qqOScirDpFF4zKS5pf27hNOIRADCRIsdESscJsaoM gDMVcOZm0Aa3
yjvZmbqK+3bV2zheme/wH9n+mWv07wRFSuxD2mLaUBuSuDYPi44S7Uwa5dDd x10URwQRY/aM
CVjprSXC3FF4KNdkqsBhHU84HbOSJkiQl8iWlyimgI/2yiObxNCzOxQ+xERK FJaoJlMFShRP
OB0lqgkSSBRI1EDrKxeYOlZc2fZ68eH8I59aCHufqX1Li7r9+I+3RpgvYb01 /tpnpWv3j22b
q3hr3FjhAtH6Xvjzt8YH9D0yJtgZaVV8A//KW4MMut5OJt+/fzdt3yc3p/z9 0x7NNSUhRYMr
8ikpjYM/ol+nN9hW//nO8pL83z+Tr3dBe7Bug2BvcE3y87b54V+tb1YYW/nz 8KP//hu6C3QX
6C7QXbh1Fx73iq0r99G5s8g8TStuZ3Np479X7BEDh7lXbBAQMFUpaKryqxWt 8M/n89Hvo5Uq
7Nlq2SC04dw68IURX7aV3M+LvbWsQj3M405ukf2NlqILQuFXAY4B43KGLD8y 09+7dOfIfrA9
VKpwmt36YliOc0Kun/gru4axbZnXn+jlFb8yrA77NyMLixquV8f4J6lXMhal vEq/aV2Wtku7
WYXlnVWY8xeS/ew/f/n5zdyx+GFKS9/m25+jxuem92+YtR/95wy9PEB2uwrK xP9F+eRT+lyC
h9wuVC6TWtzlZxxfML1Vpehnxxftb1UZG5I975G6yO8f2P/2jTZ3SBH7qjdH kQuj9rhci/7W
JHtQ+ws46+CmiU3AzRNy2GCVIkWOhEDZvkV66VYRiErhpoTXzK5skgp3fofl 8cWX/PzMlxLm
FocyHktOJq1EhuODyhcB7ZMxHF/slStQoe/9uqQGVy52nnXm4kxPNIIn4zfx bBW6d5gLCyxK
eUPFYpdcrWyrlx+hOJ2ga5CbVtTg3sDmeyqpV5T9I5UxGsWNTPNkaaEyMiwG hYUOxbdu1Mqr
zc9b52fpILM8f0GGxeTyy1Kq1uO6zH19twtnPhImTZfupCYfpnDbxZz8xuTs Ab1H7HiEdV2s
7P5Yxzf5B4MX8P7oem24584mpMEwTu+77fwCyNWrpQexeBHvrfDHbUAZzBNV huB03+kkm4+a
ZJNRJn3tPF75jes89H/f+VO4vOz84SN/0zM3jJ8FjtX/bZefxOWNlxsY+Vu3 b3GMeYboOLX/
m68/jcvbrzcydg9kd3Tbnkvv5+7vhM0H8vHDZjuquCJwkI1tesHQGeVH8nVH uSVFHOLM7BU2
6YCdP8pP5OqOckOKeIOk5MmK/C47f1SfydUj1aYU8YkXLHA8XLBzSOmBXL1R amf0rghZpFDZ
Uzi99FCNlCl6tky82F3hTJDFK689jtO7r7Uycic4MYPenj2EywvPnj3y18xq aMZ5UKbMcGzu
JSw6dvEYLm+7ePrIX7ZLptLZDLQqj+Ly0istjPzFf2UwifyV3/zxVxWmjpeW 6/V/y/lTuLzn
/OFjf9OBg1i86vwxfN51/vSxv+xoRo7A9H/bxXP4vO7i8aN/39G/vYhusGDx 0isP4/TmK22M
/vXTc6kM3nz+HE4vPX/82N/3A+49z+zA9+k2hGek+WcvzOfmwetnC+vZzPUZ +GKvNvj4aa+m
R+5DJqu4PBdw1Vi7xVbgjhQlSxQ+u0XeikWAaH4mLyc0NDV2nyx8BsEifwqf 9549fOxvGj8B
2Z67wlkeWs7NdEHhX4cmk0X0x57OxzOPNKqYxxBdjrhfuryc1tDAIH5raFdF 13F1mwiXqeOu
iM1i5Po5fJwQKbIguUKex3JFcvN5XN7/ZjMj98O/E2zHf54dmK9Y7BWqP42L D+qNjNwDkWX3
f/HZQ7i87+zZY3/NduiuYmvlMnjZ5UfxeeXlFkb+4u+QF9hu/PDMQWRb38v+ 77/piVzc0NSQ
Kt6Ig8CLsFGHDP1ReSZfj1SaUssndy76zsUx5QcP4Z1ye2N3ETalKIPV3y+1 p/FxRq2RkXsA
v0pydvIZGXC+7u+Cjcdx8cFGKyN3wj2xpv/LLx7D5aUXT5f7ZT9+V2x9w/cq DFYojF0Uje8C
WL62KHSr6yvHmf2MxnOpa+tLjrOeYOY94TJYKHSb+GCGQpeX6x5j7OWXX4mP FygcfQXNsjGD
FM1k3+DY62QyI8XAZWXrqkfv0saOffleEW48ZuAwtZm5g9jLubgxTlcQprcc fpx9RTbLgsR7
XfPy2MuV5XIX8pCNMjrs73zJlWjMV74MqErDXf9CKYKfFXy3ZgxvsGlqpTl8 cm3yQ0A/OUXz
tNEwDEK+1xFCCgcpnLYp3EBXC5fkpF0Ld5Z3hyLzM/krKylMP8rexK8/raz4 9ldSc5PU0/u1
qKzXrgL5niU7e0IOaFpDGjd+XeOLCTb6wymuWv3E9F+2WMl+amMME3V5Hd4b zylq8BpHtp0s
Ey/l883lKX5y1hp5d1GPJxtT2/IpxP8dWwvPnf0fAyvHEve+yHB9UsK7fenj LQ1g3PSZeXpn
RMmsqDPJpYVJOpFN3tEQjeFuRTgwQFMnn6fDtDI582NaGHSY1ta1NIdqMAiG 8FcU2sO0MlDP
yFoasHfkLQ7aQ4pGB+slkyuLnv26swZqbxUP1tCAfTNtbODumTU6eA/N2x2u k+IWLW+JcP5u
Dd/isN2o3Orw/anSuoiOVQUgpIdN1tm60MYF9bsqAIFdsAZEaG+sYxHdMfHb oAPEQQP3GkiY
FloX17IgbpRaF0iMMgqhrKgAEUOJAkLg36EwCkRTYnKKHygaw28otBzxr+Iq WoiG8P/oMSc5
UKS3U4jGkqL4jdyEY8Xi+8h14svxXn6PhIfTiWWTyfJIPALB4bWEQoIwW0Yj RbitABIbdnMo
l8HC9Y/oN5KQiEAKklguTNYCkdUouUAh/8615IK0wMHpGnkkQLmBZNDCBEuA XJg8Fz/xNLAl
gxUFnmu7sSz93ZkJbVxwTE0BSBBOMyBSRNIci9ggilFc+Dj9jMUzZHJFCgXi h0jA1skUebhl
0UDSfSaReASCBaSEQgIVKaORQkoqgMTqSQ4FZwQJ2VgTSEKhyW8kd5IKTPSv j5ensiCiadwC
LcUgu8O/6pCMO6L3og/TaHa22xx8yS093zyModjIZzFarvB4Bg3X5HAteXjw bzNs7tKKYmMZ
OO7cRU7/Ur7GwcGLn1/9/Murn988f/5cPKzNa6QwwBdv3hy8+uVACoDFDRKS 4cqLfEnmz+xS
E1Go0lM5X9yDN/6XmH78jHz9bB5msA5fv3xz+Mvh4fNXryWAhSKhsNrclyqf cGxe2SsZxPJV
8RjawasXLw+f/ywFtIZimZLp25bC6pL2wtp1rJK9y/x2eulk+aslo/5tqWgn G0HyKveicGVO
JVjoST36og6KYPHi9eHhm5dy0LR0gczB88PnL37++ZcDOYQ4v8FTMl17tLC/ ZHg3a7nJNoxY
39glWQ8sXW4qmVOrN1NicK8O3hz8/Or5yxevZXBo9UowUV7dOrTwpRxa3OJn P5O3y+1585Vk
4rJRch17/c2bN69eH8rxVquVsiUPdU03okgGeX0/sqTDofyot4RcySE6M5tU 4M758uL54etf
DiUJyY0FzmUbfqyvN5EM2a7i17K9xEeu9JGM3jMXB29pFxJCOTOK4l5kyYCt Ky9jYC9f/vLm
Nc4SD96ImUCoBQ46o5vL3sGb15iykkycbpRtJ6HjJc6tX/bDd40SWpUoxp+R n94LInbgl7zY
y5eicguBnD/GxFiNlrCy6jAFtMr3bw2MykZpCaXpzdH1Tb+Hl55mp/9k/DU5 vvib1D4hn+Cf
SkJaNmdddYVMtr6dTPbqYf78S6sqKlRGanVyMMwpimn1F4eWMSf7SPCXaVob hMYqmXmubVyc
kmpPT0m1mafStkZasfDoK8zqBx05jmHfup5j5Dj+CHHHR+FfDppbiRf/XfzD GR22/ZX3uL8L
5O9wr/ur6H9/1y2iDtUV4tdoBfCY9vhnk8k08Y0r1w6D6CGK0TL6ybjwbXMy Ob05JaUvjVK1
LePQfDGZnH14qhC+/d2b58Iyd8ExYMzmlwFiL4ifcfKEwuyaCwDKrsLop9AN QkwhRWqM5uYM
WGWUbZNQZ5RNndGIDA0C37yyfGtR8PYaLVwcVklN0Vqty+zn+tW0lKjR84CM d0LsIPzi/GQ5
w6/V9d3Yxb/0nzR9oAMrDGoEzfyWJVFL/K/4Y8NxFwiPyvHYfxX4pOeSK5Es b0GIeLs0rk5f
jae1E/xYHCuQQ66v2dmu/K3gZ5/Sx/34j73nDvg+aI8OauevZgztTAmb3hbq iFOOiIiLY2Q/
Hkn78O1PTdV9ejadXnz8MCUTT2No5wT/BiWSnUQxfm56/AQ7fZXEWPTI5VNU KNIAlkVVSRts
WTKbJEMs69I3ltynHGrXxO4OccCpQ3d/bstXchlwLoV+HAQeslpepbA5QDJL 45zy2Cadnn1m
kIelt6lgdfeyt5i9OePV0cuT0+PXz3/55cXZ2fHx4fHp4clr/NfL1yevjl4f /wygRIMyCiRW
HIfuLImR8XT5cEbOuzw1vuOciJSWT/CHJ1Z4R37bvKVkjoN/5of2TB/FTwHg yAAerZDnOkEN
4tH156PLdx8BjBxgImTbVg1JmBeBiQCLDFiWDx+sJapieff71fHZ9c1HQCIe yYVTxXEAAIYG
8HvskpGzE4RVIJazxONqPNyh/wSgJAVFK9lV8dzaAKIliC1zTcStt7zmaZg9 fdu+HXeF/x0Z
J+UtOm/7PdPYe0We3lw1OTB77mz6tfG/Fj0Lxzr8crPHXpL369Nh+TFZ6Bl8 fXMcaIoJsPcf
Ti8Mn/5UvvdLnsdvbgHJezqVhtL+DXRHFhO8DEEkWRuttG+KfKfeNOVOCgDa ZdVutphGdjLG
PP0pdTtttzrk+4RMuq/fJDtxzWwrrvk5+zeycSPbtjH6vRAt7R1ks8TgmKoT 3PdFY7dxvDLf
4T9G7e3dNvHz6BDtwh4Y7nft7nn7fEvSwmX047iMvrSS65F36WHrYsT9KnU3 MD8m8SqJp3Sx
mlMza3XKeiWXNgWKfYNZQ+k9t6ZB8oe+Xh2T8RMeLcZ/hG7MbytHjfLcG+Pb AJVMnjLZFHqx
VXmoZWyd8OHJhmnDjkS4Nb9/XrUBAVKocaRQTc68yYoTq0PQ3KJhecmu1d3+ ChM/dpfIzI8H
m9fZF+o4cKuJw3qUO4z9FXcrFFBemZW3rZtzDQGvji6eZhU98N8eubiGrDjj pDvGwzLkfCou
OBi9Ru9n5iA6PRSU2nCKVlZ9Z0W3sTXzWAbdvaRiP6NBP8YzpbkxT8V+qC5+ 2q+waeA5P8bt
woTfgBN+j6zo3OAvZ8F9fhpZxdXvqonCFrz5wKiHOpegmVs2MlrBgVA3ttW7 D4nnfQqou4ee
lc72xeUbI9URjZphw0oFp8bbCUQNBMjCiGTBDbBRZBMo14WwjeRw1Cqwy6KB k2ymrUKKLTjF
pvMbU5dU/fiEMy11YmTNsGFjJKfG959argGA+DjeFVv848X6e3q6RR2Sbto2 LE95tL/feu51
+jcOphHuwHGk3nJu3UIxq7m8ULQbrmxDA7qs0nruppqAf8c1Lr1G5J847v1M B77cmzlO5nMU
Iod7Q7/7UbIi9wAj58y3A+KyIbboX/jFdl1uJjYxHOW2mZguEToLwyAc+QJe azOHjeOcoezr
7kLWVXb2hpGiXM0NyP6xfAcYCOoqJW07BQZcPd55k3zMtSJuDTPvqiffO80U M+bmCqX9LupG
OMDs8TI7X/zNO2O2InXkWCuljp7ttlPMqj8vLO08/i5IIvQNodW6SJK6bm8w VqzvOQLqtgtk
BzDQeXV0Pru/SnnCV+0Uy3U+WPrRvIoJGK4Ow89IYTrl+V22Uiy7eSDpx+0y ImD2+Cba2nm7
OooAf49/ti3b4XBBNzioWKWgZqDQXS3sQLRyLtkI7NpI3T1LuYFCncsORCvn XgYLpQ7YNZon
1LFsIfTaiJZCgbirWp61RUrA0SqtXG9JBsDJ48+ivYDcpLmYPkQxWqoXiyvm iYnFXCB0E+kK
FGDvuHYMX3wceL8rr1boibErazXQTtpy5/8UussgdFzLU1zzGgwVp34cwbTP YbYAAjUckRpS
BfmMbPxsriLFob5eU+ES+v2JFcXcBZ5adTQjtyDa9LIvvg2FofXAvZUPwTSx b888tMSs4P4G
y/dEHIWLZJBGcVw+dz00QGym5jEOjPuF53Tz+9Kyw+DcIsx+UC8yb9ooJijz w9E+Hm9igVA8
/mmFTa8+ufke+N904HRqqSzMZouGBb9TRMDy8bPccUNSK/gOmaf5V+oRvMFI MdzmAqSzoxWu
J7LLWmlcL0mdkV3IQOLHVkL1xAt8JKL8/D79CrqTShlDKS/8FAb3DyqHkbqt ooMILzx9aF7H
BGwf24Q8ubtk+GW9Ur9RrmT/dhuFzy5wLtrfal4BKvaPPj+gAoJHHGEQrdLr h8jJjey7IFSs
WPB2QwUUD+YJppfTj60IaeN4YqxUzmcJqGU16d2gQOZV2lr8iMPB2WMbBUxR PNAIoKHrXKH4
NnDwIOTJ0XLmLpIgiRQsxNXScOFhZQhwvRRnF0BQoDHOQwynQukFcgvko9C1 qzvsT9I7VfH3
qt0i+Ii5Im4UHAjS/jqzFyxQl7EtkaV11dOy54NKDL2jsnZDlmpHqB+zVNhV pVzRtNWU7YhA
TsY7Bdrg2/Qh6e8rTfKyocI5zhbMfqtYIYqCJLRR/qTr7HvVfL+fvWJWt4bB 1H6lazcukHyV
pkMfkSNw9niGC03X2c7dhVq3AmODhr8UmFmjcCfwgHcCryfoLrB/LZar+gsU 50HxKEoPSJJI
P0kfMcnVdZJF1ImD5lbixVHxL+aqOOk7GmLmFgu1NOXQOr49/WqFb+euh95O Tt5OPoXBIrSW
/334nBxfjSZHKcqbYImfjj99Zb6afKfPjSbHF0VA8dxZgfeZg1bPDsyXJn7w f026mvqUgalV
QyPay0qBhM9AwU5nCvHfnpcuVkTm2X2MxQI569PpT9ZfMr6kTtSAoaPdgwwc hGHbPBV+6fro
Q7KcoZC53/fKWzu+CkhjRzdN1drTN8E35Lv/0VGLCtPllCOG8Bo3gNAFEh7u 5yNJBVJQpbGu
xbke37uHSfYqoFrZZbBQ9khD1T6hlRmFH2Wo4gAZGtuGI+4lrs78ZEmmTKq7 GLFfPu5uxg5C
ZJKbLyw8TqCbp82/TrJ//Nv8i76c2yCK8dd4/P03eYn5HcT4df7l+vPg7+KT zy76ns3BvTU+
BIadRDGZJyoCqTEn82am8TudT8uG4+sH2nTiLknNMAG/Lvj/V6//DAA6XqBY 70M66/3e+oa/
stY/cndgvgQconDU6rgbru/GLn7EfzA2E2CIgXGaCfZ6ZGqQcQddFPqStvgl Tx2/ZKnjl3zS
+0vDpDdAVxv6TfiQrSgmEcJ5I9kA2G/vIABXFHiaEgLgMQAedLthvoiczT1c LFeewpsNG6wV
vNWQC6J+fUAf/8vle7F1/LahgtlIFS/y2qU/4PHxniFB+abFwrEb2xnVkfc9 jB1W4QcEtD/l
9wAFjOfL+IGnMmqaXp3PMn7sFx3+AfZIb4/4A2vK3uCyl9kyHl8Tfs/LXvAg EikRiXLfGhnA
dGkFi1yMqodcWpx7A+gKQy+3arxdR0S6V8GIsmVTEwCNBZAd4FwExQgA7QNI yHTvCfk5TSb8
C1slmfJliKeP93XxvExel2yan2KCtFuLSf5CdcDfSg2zqF/LGQZyus0jVcIS GKGZEY/OTwrL
pJVCJqjUxfqmJeVrXfAyVcZiF022jrbaxY7rwS5dUjTGU/mWuMxE0ZfDMYbR 5064DAqkq0qk
q9n7T0tgG8W1nm9bdwbAyxfvsMp+Ra5wU1nXqYGiVZ0piD6aToGAoqt0lS91 KX5PEVJwl+Fe
5krBbj6QenO9CguYD7ncOggAWn5oh40BlOUqqz41ULTOMwLR1rkX/iqJ1bqO dYeRop3MHEif
EF6AgcCt4hpxTVrAySqc/Uqvs7zw7zAA8oHSZ7+2Givq7Bd3QF3Ofm0FBYyH 8dha/AEtP7RD
p+y2lziKJ+zURPHpOlMY/ZJ1CgU0ffyz68WOMKJe+BXlO2AU3rJds1Twpm1O aHps460hApZD
5laWfMDLF++w+ds5th3/jMr5W2ai6PyNMYw++VsGBZQdlL3cGQAvX7xDKPuK zAKE6WSAgiUW
K+aJUXTGEDq49SZECHdqWnUhUtzHFVslcDgXPN3O2G7HBYF9/BMzFe/qwnaZ mC4jy4HhSu+S
qPgaXKyMiPuBg8wPgYrLZHULhQo3cxS9JLtAA0we24Wv2VVN7Dc0NTV2FoZB OPC1r+UuOnVJ
0QD15Wltp3iRYo+lc7ZRwwNipVbacTS9KaYs1eZ32VLxDOeBph/Hy4iA5cqx fBUGNooi5Tme
2SkFwxlj6c3vDA+wWxl23wTfkH+1CNkOEmTjdsVKoczmgqQzrytogNXKsPrk 1grTonrKUnpt
olA+s4fRa05wDQfYPKJJQTcwjx9idBSG1gM9qcyYvK3EI9+hpIGIbJoqVEz4 wemcIWxCAmFR
Jk14//4mXQvGhsfqzt5VzRTKcD5QOrO7CgeYPaKUIYldj5hlfxOTJaT95sn7 9yeW56m+byw3
U4JtY6yh9NxFlMMB7VBsS2g6NZReA6D6HvCSqTJsAecApyfLy5CA6WPLEs6W q/iBpgo8Nxzt
O92s9iKD+MUFORYVQCWUOPt5ghug1+4ePjdS90am5q3z1Esq164fh0G0Ihtp At/8fYbbJd+o
dcXpY5YOq6P80XT3ux4+l8ffYtbxdiGCWDresfUuv14Gi4U185AeDM+tlYfp rBGxY3yODJiv
0jHMx7IM8PbYznF9CKaJfZsWJR56bqWhN+ExzKf09syHKVI7cayaKjym8IHT O6BUYYG+KHYo
YxbFoWXHZ/fITmKFt283WivBAQ1OiHoe06ihAtarxfpc0PVgfd1a8aznhagf 6+uogPVqsf43
pEmYLxkqnuscwPSjeQkQMFwthh8HgYcsX6/wvsVo8cznDKyfCmwBB4qg1DpR afLmN31m836T
azbvNzln836D2Tz12J6uI6hO9NRKGTjOFgkLeqeIgNlK7J1MP1mSa+yNt7g7 uLGLH/Afem+p
EcVWGGOoJuCRE4/l0J70+SrrR5+vDM+dhVb4YMRoufIwc/BPfb7618ILZpb3 r+wfzbslIB4E
8aC3F+aX1Z1bNhERhW8vrFkq+PZCTmh63F5YQwSxetSx+i9EKl/9beRezc64 YdVJfLIBz4gD
2nWN3P/G0yY5eorDl2H5D+sfy0wHC3SwoDm6UbOMJCKdvDG0NVlhNF/7hfLN ZYX+fAji8yDx
19vO3hq/t3pd8Frgtcj/WhpfRfqPIVq4ZKsLHS/YASkwHiMTgKoC1PK84PuF j5+AjF+NOEzS
wQDO1izfmCGcFOGOi5MmN/0RrP65ORFA1gTyTfDxDiun6xDwNDfO0NdgL60H 48PHG5JbemRK
bhWiOzdIIkIG+qMu6fNgEVi0j0WXdJyy05jvrucR+hhpKCW8iexghQk0T5+E HBMsAUtyS5Yo
ivCoJzJw5KXojSi9D5iCDpJ4lcR4QLNYkPww/2EAqxpYK4kDMmw1gvm8Aa0f xPRHljhFww/3
yGCX/njWo/O8jj4OjNDeiNqiivCUHvA048GfRIlNrtaYJ6Qv0dUvAdEIcNRx fHbR9ykK73C3
eGt8CIw4CLxZcG8gP8bsdkmf8efuIkkHzQBw7ABP0dxKvJiAijHCZ/EDyQ+j t3jUex9PbuOl
BwAZAGS1eIsV28QZvB89LFe3gf9gfkez70H4zXTcaGXF+IGhmSE7LT4Z5+pt J1P5Ld8KgrOH
6/Gv/YH/JiWtXTtSzNlV4wS4lw+A7Zvn9gQC6/BjrZTSSUjA3aMrlZIsZyg8 D0I8YuZ97/W9
GaUdxryN45X5Dv+R9aBr9O8ERSM9TLGXafxCwoDNp7yJ6GI4HpfTH9hYwmbQ 0mlKcNJMHJAi
n4Sp9pqphhXjcYrz1ujIVx5sTVHyTKTuqfymwzIyRliPztgTV2xWtYelA6ZY g6B51O9/kj/V
dHTVtME9y6f5PbOqJgiQRSmTNO+hHeDtceTMW3x7RE+JfQqD+welRLlk1+CK zLTtzTs9cWqc
ri6xLfLbcsJkw1QQgtGdHMZOXQZ+ZGb7FMzLYMH6KNKjAkSPrNJtNu5/kHOD 7uPf8SdKaVGz
iYPLEl8YrTKKZiigIGO7A+omRIhlTeCmNq5cOmOTnzngPcuXNnoSeF56gH6g ZqIhFDefA29K
6BVb0WoyUcC6Fk8YLRc+mqCA4o508FZzarY7QgNCN1kqjtc80XSjdxMiYPnY ljV/96NktQrI
7sSPK8RrlaSNvuQrWlpITKOxIlWGK6CuQtMICrRGjYwiKwmIX6YGjN9irDjG cwbUjfFbQAHj
x5ZdpM/iNbFBmyj9BLN2FmQ7UDoJ9GPeNVdFn/wHM83g3gjpimsKPp27Hno7 OXk7wQRbhNby
vw+fn+OPoskRfezkJljiJ+NPX5mvJt/pM6PJ8cVGX9+E+5QB3BGBrXVEH8Xm 79eXXPof1spJ
WStzeyZOOv7i2zEHb73WCb5a4du+HcFzZznsZ4fmgfnaxE/9r0kL0zj0blUM a1zt+2pFuIFi
q+X7KN9kOfq6g1stG6TOIOfWYdfqgLtWo8Q3QzQnizJkpjyKw4Sshx/RU6NB SO5TbccWeiKu
eC3k8Np9jFucZoVoi8PBjkyPO7lF9jfyuHkQGvn5vbdfDxG6eVihX/ErvAqc xEM/+dYS/TqZ
FOf6sA7+9P7w7OxotfJcmw4PfvUDH9EPCStQSL9XAd1yhiw/MtPfu3TnyH6w PXTpRjHyaa/C
8YP0GlKP9uTW9Zy/0t76a27Rmb9wfVQ6H5n/wzuMtXRW8ieb/HbrX6u/OXri 8m9Gtp3gX6Yd
7uoY/yT1RMamlF/pN7RJfi3mJR2bnodzzIgc/M1fQvaz/zw4tF+8OHzND9QH a1larY4an+ug
lRc8mLUf/adz+BK9mO8HjZ5dT1YmcXo6HMdwTulzCR6cXBjWupsbjhsiurHH +BqtnqF7i8hE
1IKGlUO9uKkjxzFovzQ2ulm5hb+Ntt12vJhyl2SNFl6pfP/WuMirQ2A/9Xtw JjCp7qfqWLe0
cgreIKmtcfL2S5bZGjSv/ZLmtV/SvNbAWS39rUn2SPN+36PV22BOyzUXVilm 5EgNmdeb/UJ+
q4hZpchUQm5mAwJJLchGPF/Kz/pydXZzRAY/X0p2GD52OJusZtJRtAZ55DUt b4lC8tR9kpBy
w3ulIzSs9H6ZI4GZTy0TmBkRihLO0QiejN/Es1Xo3mH2LLDI5Q0VE9lytZJm IFkbpbwmQjH+
J2RMGqSqI3EGbGrz3ZXUMMr+kcoizR6MTENlaaEyUC3GqIVyxbdu1MrTzc9b 54rpeLo8U0Mm
AMjcVClt3Ccy4N/4knvxS+HFL+29uAtxPvwnIDbWewjwrjEse9SX7FG9JxXw sO+6WMf5cWMC
/B8MXsX7o2ujMu/4NYo9Mt3I4j3g533Jn8fiZby3wh8bwTKYJqtMCdAT5ZNs Om6SzcWZ9L3z
eOc53Vm+9/Izubz7cgNyv/+tazBH0TTGD1n+mJ1ieZafYmG7+DHIjHZ5ZYej Lfl6R1aTn1Sb
nJNp5J+wVfkayP4ZXL/Z5MTH4dGhxZdpoUtRs8oDvZGmjpuPmihXXJw+TPY6 mzW+Xi3QUOjy
wrp84yIk9vLLr8THCzT+S8jLxgyy1Mi+QVhdHHB1cYfquTgJJI59+V4Rbjxm 4CB8GQYEcAg4
BBwCDsnAoTvLu0OR+Zn8lS2L0o+yh/z608qKb3+tzu6TWbpfi/m6dlsqWi8T 9DQjmH1Fdkxg
GL+ukZJq0L/SH04R1uZn03951HL2A58xDOPzFcQbzylWD40j206WiZcS5eby dH2RH3mLUY8n
G1Pb8inE/x1bC8+d/R8DU3KJ+yYpN0M2LrRfvt3SAMZNn5nPfBlRMitmtLm0 QHrXMK1MyO4O
FA/a2OQEU+XboUkm+Jg1THZtkHZJvzKeVlp10CxZPEt7iRl7zlNO7WRywKql na/ycIAXd0j/
eDaYWbiBaICOSJqZkPLNnvXwKcTxyI4jE384VNO3yPOCP4LQc4ZsdWX5yBuy wXtymcLMilx7
oFYzyWfU0qWFU5hl4LhzFznGTj0xDg4OX798c/jL4etf3vzMo8mtTFw3/fLg l+dcrN3Z6OFz
Zo2yXGdcI/z5lxcvB0SYDnK+uAdv/C8x/fgZ+frZV6sK6/D5q9cyvbjK4uP6 5T0/fCHBy5uH
Ql/eNljIlwEW8R6dzn12YB6aBy8yTC9evD48fPPyzfNBCbr1VUWyvKrawih+ ac/Nlxm4gzev
37w5eP5zr3d2jdJb0rFOnpCfZrXj5Uv+QHJAyHjOdCtxadPR9Obo+ob7llGy rby6bbQYF6bH
5iZ77oH90mqct20zJ4rjdDcf2ZlBhpD4y8gO3RVOIYxVMvNc27g4JRM9T8l4 +Km0rT2+k/2P
EAcCFP6VbfVrv4fd3L0nHsDiFgAo8HBPJ2Tbm26C92PpNuNDfBIsV2F6jgvH khiFNyiKs/1k
YMEwFpTPOUcrMw32/xqNVqoFn5wOwv8DfkH4Y2ux8hIM17RvgyBCYIg8hszx c/DHYIlElrhz
MEJouPPJ/0GwAgvEWUD2yyDcnTCvA7BCrBVpKh7h54VxBGaINsNOQjd+ILtj YmTHyPmXicIw
CMEiqS1yfQfdg0VSW+QFGD5YJI1FWS6Z/gVWCLXCT5bk/0WCwygYIdII/H8c kHlpk+6tAjuk
saP4Cif9YI405hySeQla+mL8PU1RW+h+TbBFPluyHcNgjkTmrKeVZkHwDWyR zxYFpFlRY0K0
QlYM1shjzdKN7OyyHDBEHkOcB99akiOpcRiBORKZg/+4N+lJI2LHPRgihyEE wHUQWzECa+Sy
hnDenSUxqnwzehFQ3qzoNpnPPbBIMouQl4n28+eH+Gfd+HaJ4lTDwSh5jSJ3 3GDDosCPwCop
rZonvk1Oh4El8lhCRtqu7ca0s6VVdMAoqYxyfdtLHDTqHXYq2ZD9DXYItmMe hN9JiYPsb7BD
EjsCH4ENAm2gO0vJn2CBeAuCcLVAYIZYMxwrRhH9E0wQZ4IdeEEYkb9GvECh hhHkWpZZcJ9+
EaIo8WIwRgpjLI/8fwAGCDbgEAzYYsAfR9cfduPPrjGeZqc1TgKP3JtOqkKR S1+jlWu7QRIZ
SeiRIqWksvhb439O8sMdk+Jwx+R//U96ESAybuN49XYyIQVmTXIVux0sJ9Ys SOL3+JMJqQGW
+PhXs0tkJ3M3pCWow+evXuQXTh2++Nen81Nz5cwN/MgUzsGBebifS6wkvkV+ TJbXcUJ0VP4u
88+HwJi6/sJDU3fhf/QNWlvacCODFPqAMt2tynSfB+Gy8o5Z1ejeUT+N1i5D jmH5RsXZ9Oqy
JYpvA8c4/3h9tWdD2TXj2fXi2Tso37VaNT77OWZ2ytg89qqNjBDLS7A0/GQ5 Q6Hh5pdep1Xj
ouwyyxE081tWbmqJ/xV/bDjuAmH2keUaTBM/pv3G8hYBXWozrk5fjac1Up4I SyZmw+KRduVv
BT/7lD7ux3/sXWWR74P26KB2/mrG0A69gfZtcUEFTkkiIjOOkZ9Hl/bh25+a XrAxPZtOLz5+
mJISnWNo5wT/BiWSnUQxfm4abbHTV0mMRY9cLkiFIr1DJLvYRNIG97r0hyaE nuUvTHJDDcur
fZra+EA51K6J3R3iOacOzfq551g3olteNGT29G0FbF2c0/qoyPKo9r3t90xj j2HCRho7OTCf
82i2qSImTaf7N/hr438M7nc/JjfTCBxfjw1XIbXvP5xeGD79qbwes/yPL24l Qf6dGwY+Lc+K
/w8fcHwIJmTU91KJZvAvnN2jJb2WLFKmKfLyZlZIX+ChMk2RJl6Mvom8Yx/I 18xmkeY8BJM2
rPVUk4HuSEtehiSSrI3KXKxZigblCFCviY/fZhlJtfUsI35aoDFrzngK8PjD 2yv/39rIOK8R
3WoOv0tDOTZZHabdm9lkv5nV0s7aO8rPJ4zbda1M5OdOATDgFtgBb1Le5V91 CSSWN0CXUdMl
nR/8SGc/GVKD/HddXN2bGpFNpW4LqYxapd86xuzB2PgZ3ILhpI5Hb1NbyUdl 2pK5Nfxfce0g
xYyiyf/4/54V/5EeSvvLybq/4N/r2FP49JWaID1IlvRO09lRWXNyJeG1HDLU Ghn7kKFmzhBD
BuZNbkt0yB4j8x3+I2tRyUHDo0YOlf4MBAQyIWEDh7qHVaaRaPYAaUZGmv1y +5p3IbcfdW4/
xX25viZBl93TVDUCBHE00DTWGWlMvTksapaYCSyGTUP4ETJ7NY3JsPk4mc+5 baPb1nnUY6IY
EgL/BuMfTn0+8guTtUndt/lOrIt8+zZyfvwHoBgQRS0VBxR7oOCdS2aneLBI kiu0I2iRyRx6
rUnjaRZjjCty3NQx0gvLnwKSrkj2Spcyf5tnKYy0gXHmSY2m8EuQODW3LZMd s2eaLBkqc2XZ
GmSsQicsGxkHk5XCJys7q1m6jK6OpqX2DKtsLNsEfWOjb2xzQHJ+PUyHQiJT 0bHD2Eul7PXT
z7Noc1L/aJx6tY9l/JRryNabk4d9EEAuMcZcIhsjX6NoFfgRUmiSPzdp4Fl+ ts1CUiFjUjFF
WDxurdCyybdnvh0QbE8BSncorebbcEtFQ3k7Kky+bbeL/0wc/7Z3z0tsbx8S i3GfltgQik9W
fCvB8sDYYUixRFEnNe1kNnmAiHd5jf6dkKJ0p8lyhb8X6FU1kLTqYllDaTsq hOMGg/jHYY6N
7g7ADQ1D5B3PkN50A/OP0I35ldfDDaTbD7k1Uy6SbUW4GxaD6/fRKhtfj1NS 9rGMn7YM1zrM
VzCcr9ismlQE95Y1YYd53Am524GmHkEoRYXzseBczpDlR2b6e5fuHNkPtodK Jb8+pTXzDctx
Tsj1An9llebbVkD8iV5O8Cvjwol/M7KyKG94dYx/knonY1TKsfSbTlUbu7Sd 1T/dWSM1fzHZ
z/7zNbKd12/4YUprwl2jKEhC3CN23exQ+9F/ohdvXv5i84OWnzEpFaXb/Ogv SqmizONPBq1s
31Ah+M7yEvTrwfOfjABDCF0H/RqHCfpbCvyVoo6P2iClCZUKjhsmHAeBhx+a m0BgS2kFrdw4
XgfQUo0b8NMkO0dP/+xoQl4vmMh5USz4lMoDwf0dzSpn/Bw3RDYZmhjXHz/e ML0GJw8c7e+6
GRWMHVeXrL9/axR78Pe/3mJb1ew0MSjVATawcXa5hjYZ4CPj5O0X/LOL0FqS GSAUfTmiLXy5
CZa4EeOV+Yr+1iR7inm/9PohmyY2QTZPPO/ByO78QY5sKBm+vy/kt4p0spQ0 lsDi2Dy3Ei+W
B/R3mllFXwjjv1yd3RyROZYvJciGjz3IZpTRUlV4Pql8y84+if9eyT4NAb1f l8TQypWbsp5s
FAnmCJ6M38SzVejeYS4ssBblDRVTkXK1sq3+c4Ri/E/ImGxqjTRP33xDJdGK sn+k6kUDtpFJ
nSwtVKZ2ilmdQn7iWzdq5c/m560zsXSWqDz/SKa1vgfht1JSto+a49/4kjvu S+G4L//qD9N4
f3S9noT33Nkk/7VnYRDE5lcrJJjbhpzsgV/wA79sPLD3PJzlOO+t8MfdsBnM fFZmlOi2sPxG
w0k2vWpSF/duaUE3mFFZPIqm9O4esj10icehz7xggXPZhYmTrRXCHRVFo5kk z23ibEs6P503
hoWaXMmW+M5P2Kp8aWz/INlvgjrxsT
| Re: SEVERE: Report engine can not create pdf emitter [message #111700 is a reply to message #111469] |
Thu, 19 January 2006 12:19   |
Humberto,
When I ran the file you sent me I ran it from Eclipse using the JDT.
I copied itext to the Report Engine Directory
I added the jars from the Report Engine Directory to my build path.
Everything worked fine.
If the issue is in tomcat using the Web Viewer, I did the following to get
BIRT to work.
copied the Web Viewer Example directory to Webapps under tomcat.
Renamed it Birt-viewer.
Copied prototype.js to birt-viewer/ajax/lib
Copied itext-1.3.jar to
birt-viewer/plugins/org.eclipse.birt.report.engine.pdf/lib
Copied
axis.jar
axis-ant.jar
commons-discovery-0.2.jar
jaxrpc.jar
saaj.jar
wsdl4j-1.5.1.jar
to birt-viewer/WEB-INF/lib
Jason
news:dqnsv4$p59$1@utils.eclipse.org...
> Jason,
> I'm using:
> Windows XP SP2
> Tomcat 5.5.12
> Eclipse 3.1.1
> BIRT 2.0.0
> EMF 2.1.*
> GEF 3.1.1
> for.
> Humberto
>> Humberto,
>> Thanks
>> Jason
>>> Hello,
>>> same.
>>> The
>>> Thanks
>>> Humberto Carvalho
>>>> Humberto,
>>>> added iText.
>>>> Jason
>>>>> API.
>>>>> works,
>>>>> the
>>>>> problem...
>>>>> Thanks
>>>>> Humberto Carvalho
>>>>>> Jason Weathersby
>>>>>> BIRT PMC
>>>>>>> Hello,
>>>>>>> i need some help.
>>>>>>> run failed.
>>>>>>> fails to
>>>>>>> creat
>>>>>>> Windows XP SP2
>>>>>>> Eclipse 3.1.1
>>>>>>> BIRT 2.0.0
>>>>>>> EMF 2.1.*
>>>>>>> GEF 3.1.1
>>>>>>> Thanks
>>>>> basics
>>>>> application.
>>>>> * -h HTML (default)
>>>>> * -p PDF
>>>>> int i = 0;
>>>>> return;
>>>>> if ( flag == 'p' )
>>>>> showInfo = true;
>>>>> else
>>>>> usage( );
>>>>> return;
>>>>> else
>>>>> if ( posn == -1 )
>>>>> usage( );
>>>>> return;
>>>>> param=value ..." );
>>>>> and
>>>>> the
>>>>> // report itself.
>>>>> // information.
>>>>> app
>>>>> configuration
>>>>> purpose.
>>>>> alternative
>>>>> hc );
>>>>> run
>>>>> try {
>>>>> EXCEPTION: "+e);
>>>>> if ( showInfo )
>>>>> // or PDF.
>>>>> // Run the report.
>>>>> try
>>>>> task.run( );
>>>>> engine.destroy( );
>>>>> report )
>>>>> "\n" );
>>>>> // group.
>>>>> return;
>>>>> else
>>>>> String prefix )
>>>>> HashMap values )
>>>>> return;
>>>>> int xxx = 1;
>>>>> continue;
>>>>> break;
>>>>> report." );
>>>>> continue;
| Re: SEVERE: Report engine can not create pdf emitter [message #111736 is a reply to message #111700] |
Thu, 19 January 2006 13:13   |
Jason,
I have all the files exactly as you said in your last e-mail and even so
this don't work.
Humberto Carvalho
> Humberto,
> BIRT to work.
> Copied
> axis.jar
> axis-ant.jar
> jaxrpc.jar
> saaj.jar
> wsdl4j-1.5.1.jar
> Jason
>> Jason,
>> I'm using:
>> Windows XP SP2
>> Tomcat 5.5.12
>> Eclipse 3.1.1
>> BIRT 2.0.0
>> EMF 2.1.*
>> GEF 3.1.1
>> for.
>> Humberto
>>> Humberto,
>>> Thanks
>>> Jason
>>>> Hello,
>>>> same.
>>>> The
>>>> Thanks
>>>> Humberto Carvalho
>>>>> Humberto,
>>>>> added iText.
>>>>> Jason
>>>>>> API.
>>>>>> works,
>>>>>> the
>>>>>> problem...
>>>>>> Thanks
>>>>>> Humberto Carvalho
>>>>>>> Jason Weathersby
>>>>>>> BIRT PMC
>>>>>>>> Hello,
>>>>>>>> i need some help.
>>>>>>>> run failed.
>>>>>>>> fails to
>>>>>>>> creat
>>>>>>>> Windows XP SP2
>>>>>>>> Eclipse 3.1.1
>>>>>>>> BIRT 2.0.0
>>>>>>>> EMF 2.1.*
>>>>>>>> GEF 3.1.1
>>>>>>>> Thanks
>>>>>> basics
>>>>>> application.
>>>>>> * -h HTML (default)
>>>>>> * -p PDF
>>>>>> int i = 0;
>>>>>> return;
>>>>>> if ( flag == 'p' )
>>>>>> showInfo = true;
>>>>>> else
>>>>>> usage( );
>>>>>> return;
>>>>>> else
>>>>>> if ( posn == -1 )
>>>>>> usage( );
>>>>>> return;
>>>>>> param=value ..." );
>>>>>> and
>>>>>> the
>>>>>> // report itself.
>>>>>> // information.
>>>>>> app
>>>>>> configuration
>>>>>> purpose.
>>>>>> alternative
>>>>>> hc );
>>>>>> run
>>>>>> try {
>>>>>> EXCEPTION: "+e);
>>>>>> if ( showInfo )
>>>>>> // or PDF.
>>>>>> // Run the report.
>>>>>> try
>>>>>> task.run( );
>>>>>> engine.destroy( );
>>>>>> report )
>>>>>> "\n" );
>>>>>> // group.
>>>>>> return;
>>>>>> else
>>>>>> String prefix )
>>>>>> HashMap values )
>>>>>> return;
>>>>>> int xxx = 1;
>>>>>> continue;
>>>>>> break;
>>>>>> report." );
>>>>>> continue;
| Re: SEVERE: Report engine can not create pdf emitter [message #111806 is a reply to message #111736] |
Thu, 19 January 2006 15:26   |
Humberto,
Attached is an ant project with the code you sent me slightly modified.
Look at the readme and let me know if it runs the runreport.rptdesign.
Jason
news:dqoksg$k74$1@utils.eclipse.org...
> Jason,
> this don't work.
> Thanks
> Humberto Carvalho
>> Humberto,
>> get
>> BIRT to work.
>> Copied
>> axis.jar
>> axis-ant.jar
>> jaxrpc.jar
>> saaj.jar
>> wsdl4j-1.5.1.jar
>> Jason
>>> Jason,
>>> I'm using:
>>> Windows XP SP2
>>> Tomcat 5.5.12
>>> Eclipse 3.1.1
>>> BIRT 2.0.0
>>> EMF 2.1.*
>>> GEF 3.1.1
>>> for.
>>> Humberto
>>>> Humberto,
>>>> Thanks
>>>> Jason
>>>>> Hello,
>>>>> same.
>>>>> file
>>>>> try
>>>>> The
>>>>> Thanks
>>>>> Humberto Carvalho
>>>>>> Humberto,
>>>>>> I
>>>>>> added iText.
>>>>>> Jason
>>>>>>> API.
>>>>>>> works,
>>>>>>> the
>>>>>>> the
>>>>>>> problem...
>>>>>>> Thanks
>>>>>>> Humberto Carvalho
>>>>>>>> Jason Weathersby
>>>>>>>> BIRT PMC
>>>>>>>>> Hello,
>>>>>>>>> i need some help.
>>>>>>>>> run failed.
>>>>>>>>> fails to
>>>>>>>>> creat
>>>>>>>>> Windows XP SP2
>>>>>>>>> Eclipse 3.1.1
>>>>>>>>> BIRT 2.0.0
>>>>>>>>> EMF 2.1.*
>>>>>>>>> GEF 3.1.1
>>>>>>>>> Thanks
>>>>>>> basics
>>>>>>> application.
>>>>>>> import
>>>>>>> * -h HTML (default)
>>>>>>> * -p PDF
>>>>>>> int i = 0;
>>>>>>> return;
>>>>>>> if ( flag == 'p' )
>>>>>>> showInfo = true;
>>>>>>> else
>>>>>>> usage( );
>>>>>>> return;
>>>>>>> else
>>>>>>> if ( posn == -1 )
>>>>>>> usage( );
>>>>>>> return;
>>>>>>> [-h|p]\n
>>>>>>> param=value ..." );
>>>>>>> parameters
>>>>>>> and
>>>>>>> as
>>>>>>> the
>>>>>>> // report itself.
>>>>>>> // information.
>>>>>>> app
>>>>>>> configuration
>>>>>>> purpose.
>>>>>>> alternative
>>>>>>> hc );
>>>>>>> to
>>>>>>> run
>>>>>>> try {
>>>>>>> EXCEPTION: "+e);
>>>>>>> if ( showInfo )
>>>>>>> // or PDF.
>>>>>>> // Run the report.
>>>>>>> try
>>>>>>> task.run( );
>>>>>>> engine.destroy( );
>>>>>>> parameters.
>>>>>>> report )
>>>>>>> "\n" );
>>>>>>> unnamed
>>>>>>> // group.
>>>>>>> return;
>>>>>>> else
>>>>>>> String prefix )
>>>>>>> report,
>>>>>>> HashMap values )
>>>>>>> return;
>>>>>>> int xxx = 1;
>>>>>>> continue;
>>>>>>> break;
>>>>>>> report." );
>>>>>>> continue;
| Re: SEVERE: Report engine can not create pdf emitter [message #112093 is a reply to message #111806] |
Fri, 20 January 2006 06:16   |
Jason,
I followed the readme and your example runs fine.
When I tried the example in my project, the error appears again.
I then verified the libs in the WEB-INF directory of my application and
found out that I had some jars left from other version of the report
engine. I removed them and everything works.
I get the EXTENSION_POINT_NOT_FOUND error (which I believe is a known
bug) but the report runs and creates the files.
I want to thank all the patience and the help you gave me.
Humberto Carvalho
> Humberto,
> Thanks
> Jason
>> Jason,
>> this don't work.
>> Thanks
>> Humberto Carvalho
>>> Humberto,
>>> get
>>> BIRT to work.
>>> Copied
>>> axis.jar
>>> axis-ant.jar
>>> jaxrpc.jar
>>> saaj.jar
>>> wsdl4j-1.5.1.jar
>>> Jason
>>>> Jason,
>>>> I'm using:
>>>> Windows XP SP2
>>>> Tomcat 5.5.12
>>>> Eclipse 3.1.1
>>>> BIRT 2.0.0
>>>> EMF 2.1.*
>>>> GEF 3.1.1
>>>> for.
>>>> Humberto
>>>>> Humberto,
>>>>> Thanks
>>>>> Jason
>>>>>> Hello,
>>>>>> same.
>>>>>> file
>>>>>> try
>>>>>> The
>>>>>> Thanks
>>>>>> Humberto Carvalho
>>>>>>> Humberto,
>>>>>>> I
>>>>>>> added iText.
>>>>>>> Jason
>>>>>>>> API.
>>>>>>>> works,
>>>>>>>> the
>>>>>>>> the
>>>>>>>> problem...
>>>>>>>> Thanks
>>>>>>>> Humberto Carvalho
>>>>>>>>> Jason Weathersby
>>>>>>>>> BIRT PMC
>>>>>>>>>> Hello,
>>>>>>>>>> i need some help.
>>>>>>>>>> run failed.
>>>>>>>>>> fails to
>>>>>>>>>> creat
>>>>>>>>>> Windows XP SP2
>>>>>>>>>> Eclipse 3.1.1
>>>>>>>>>> BIRT 2.0.0
>>>>>>>>>> EMF 2.1.*
>>>>>>>>>> GEF 3.1.1
>>>>>>>>>> Thanks
>>>>>>>> basics
>>>>>>>> application.
>>>>>>>> import
>>>>>>>> * -h HTML (default)
>>>>>>>> * -p PDF
>>>>>>>> int i = 0;
>>>>>>>> return;
>>>>>>>> if ( flag == 'p' )
>>>>>>>> showInfo = true;
>>>>>>>> else
>>>>>>>> usage( );
>>>>>>>> return;
>>>>>>>> else
>>>>>>>> if ( posn == -1 )
>>>>>>>> usage( );
>>>>>>>> return;
>>>>>>>> [-h|p]\n
>>>>>>>> param=value ..." );
>>>>>>>> parameters
>>>>>>>> and
>>>>>>>> as
>>>>>>>> the
>>>>>>>> // report itself.
>>>>>>>> // information.
>>>>>>>> app
>>>>>>>> configuration
>>>>>>>> purpose.
>>>>>>>> alternative
>>>>>>>> hc );
>>>>>>>> to
>>>>>>>> run
>>>>>>>> try {
>>>>>>>> EXCEPTION: "+e);
>>>>>>>> if ( showInfo )
>>>>>>>> // or PDF.
>>>>>>>> // Run the report.
>>>>>>>> try
>>>>>>>> task.run( );
>>>>>>>> engine.destroy( );
>>>>>>>> parameters.
>>>>>>>> report )
>>>>>>>> "\n" );
>>>>>>>> unnamed
>>>>>>>> // group.
>>>>>>>> return;
>>>>>>>> else
>>>>>>>> String prefix )
>>>>>>>> report,
>>>>>>>> HashMap values )
>>>>>>>> return;
>>>>>>>> int xxx = 1;
>>>>>>>> continue;
>>>>>>>> break;
>>>>>>>> report." );
>>>>>>>> continue;
| Re: SEVERE: Report engine can not create pdf emitter [message #112272 is a reply to message #112093] |
Fri, 20 January 2006 09:47  |
Glad to hear it is working!
Jason
news:dqqgpk$5tj$1@utils.eclipse.org...
> Jason,
> I get the EXTENSION_POINT_NOT_FOUND error (which I believe is a known bug)
> Thanks
> Humberto Carvalho
>> Humberto,
>> Thanks
>> Jason
>>> Jason,
>>> this don't work.
>>> Thanks
>>> Humberto Carvalho
>>>> Humberto,
>>>> get
>>>> BIRT to work.
>>>> Copied
>>>> axis.jar
>>>> axis-ant.jar
>>>> jaxrpc.jar
>>>> saaj.jar
>>>> wsdl4j-1.5.1.jar
>>>> Jason
>>>>> Jason,
>>>>> I'm using:
>>>>> Windows XP SP2
>>>>> Tomcat 5.5.12
>>>>> Eclipse 3.1.1
>>>>> BIRT 2.0.0
>>>>> EMF 2.1.*
>>>>> GEF 3.1.1
>>>>> asked
>>>>> for.
>>>>> Humberto
>>>>>> Humberto,
>>>>>> Thanks
>>>>>> Jason
>>>>>>> Hello,
>>>>>>> same.
>>>>>>> file
>>>>>>> try
>>>>>>> mine.
>>>>>>> The
>>>>>>> Thanks
>>>>>>> Humberto Carvalho
>>>>>>>> Humberto,
>>>>>>>> Notice I
>>>>>>>> added iText.
>>>>>>>> Jason
>>>>>>>>> engine
>>>>>>>>> API.
>>>>>>>>> works,
>>>>>>>>> the
>>>>>>>>> of
>>>>>>>>> the
>>>>>>>>> problem...
>>>>>>>>> Thanks
>>>>>>>>> Humberto Carvalho
>>>>>>>>>> proper
>>>>>>>>>> Jason Weathersby
>>>>>>>>>> BIRT PMC
>>>>>>>>>> message
>>>>>>>>>>> Hello,
>>>>>>>>>>> i need some help.
>>>>>>>>>>> occurs.
>>>>>>>>>>> run failed.
>>>>>>>>>>> engine
>>>>>>>>>>> fails to
>>>>>>>>>>> creat
>>>>>>>>>>> Windows XP SP2
>>>>>>>>>>> Eclipse 3.1.1
>>>>>>>>>>> BIRT 2.0.0
>>>>>>>>>>> EMF 2.1.*
>>>>>>>>>>> GEF 3.1.1
>>>>>>>>>>> Thanks
>>>>>>>>> basics
>>>>>>>>> application.
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> * -h HTML (default)
>>>>>>>>> * -p PDF
>>>>>>>>> int i = 0;
>>>>>>>>> return;
>>>>>>>>> if ( flag == 'p' )
>>>>>>>>> showInfo = true;
>>>>>>>>> else
>>>>>>>>> usage( );
>>>>>>>>> return;
>>>>>>>>> else
>>>>>>>>> if ( posn == -1 )
>>>>>>>>> usage( );
>>>>>>>>> return;
>>>>>>>>> [-h|p]\n
>>>>>>>>> param=value ..." );
>>>>>>>>> parameters
>>>>>>>>> and
>>>>>>>>> directory as
>>>>>>>>> the
>>>>>>>>> // report itself.
>>>>>>>>> // information.
>>>>>>>>> web
>>>>>>>>> app
>>>>>>>>> your
>>>>>>>>> configuration
>>>>>>>>> directory.
>>>>>>>>> purpose.
>>>>>>>>> alternative
>>>>>>>>> hc );
>>>>>>>>> to
>>>>>>>>> run
>>>>>>>>> try {
>>>>>>>>> EXCEPTION: "+e);
>>>>>>>>> if ( showInfo )
>>>>>>>>> // or PDF.
>>>>>>>>> // Run the report.
>>>>>>>>> try
>>>>>>>>> task.run( );
>>>>>>>>> engine.destroy( );
>>>>>>>>> parameters.
>>>>>>>>> report )
>>>>>>>>> "\n" );
>>>>>>>>> unnamed
>>>>>>>>> // group.
>>>>>>>>> return;
>>>>>>>>> else
>>>>>>>>> String prefix )
>>>>>>>>> report,
>>>>>>>>> HashMap values )
>>>>>>>>> return;
>>>>>>>>> int xxx = 1;
>>>>>>>>> continue;
>>>>>>>>> break;
>>>>>>>>> report." );
>>>>>>>>> continue;
Current Time: Thu Nov 06 05:02:08 EST 2025
Powered by FUDForum. Page generated in 0.08179 seconds
