Home » Language IDEs » ServerTools (WTP) » trouble configuring a server
trouble configuring a server [message #110444] Fri, 10 June 2005 10:17
Originally posted by: mark_lybarger.yahoo.com
i'm having some troubles working with a j2ee server. here's the steps.
1. install bundled win eclipse wtp M4.
2. grab the jboss extension pack from
http://www.projst.com/eclipse/updates/
3. create a new workspace.
4. launch j2ee perspective.
5. servers view -> new server.
6. jboss 4.0.1 -> next -> specify directories -> next -> next -> finish.
7. my server needs environment variables defined and memory
parameters,etc. i go to run -> run... I expect to see the Jboss
4.0.1(Generic) server there, but do not. If i select the generic server,
and click new, the jboss srever isn't availabe in the drop down server
list.
Expected results: the newly added jboss server shows up in the runtime
configuration.
8. i go back to the servers view and add a tomcat server instance. then
i go to the runtime configuratoin (run -> run...) and though i don't see
my newly added tomcat server. i select the Apache Tomcat configuration and
click new, then the 4.1 tomcat server that i created shows up on the drop
down list.
9. back to the server tab, i start the jboss server with the "Start the
server" button. i then stop the server with the stop button.
10. click run -> run... now i see a JBOSS 4.0.1 (Generic) server under the
"generic server launch configuration type" now i can add my VM Arguments.
i would like to be able to right click on a server in the servers tab and
configure the runtime environment for that server. outside of that, when
i add a new server, it should show up in the runtime environment without
having to start/stop the server first.
Previous Topic:Cannot deploy ear by adding to server
Next Topic:web service style and use
Current Time: Mon Dec 01 12:28:23 EST 2025
Powered by FUDForum. Page generated in 0.03133 seconds
