Home » Modeling » GMF (Graphical Modeling Framework) » Copy/Paste problems
Copy/Paste problems [message #110224] Thu, 08 March 2007 10:00 Go to next message
I've got some problems with the default copy/paste behaviour : some
information are lost, like the text in the labels. Is it normal ? should
I defined my own copy/paste behaviour ? How ?
Re: Copy/Paste problems [message #110414 is a reply to message #110224] Thu, 08 March 2007 14:34 Go to previous messageGo to next message
Try to use Ids on your domain resource, this might take care of the
issue. if you do not know how to do that search in last week questions i
have told someone on how to do it
Re: Copy/Paste problems [message #111726 is a reply to message #110224] Wed, 14 March 2007 04:16 Go to previous messageGo to next message
Thu, 08 Mar 2007 16:00:05 +0100, Youmm P:
> information are lost, like the text in the labels. Is it normal ? should I
Check this post http://serdom.szn.pl/ser/?p=6
regards,
Seweryn Niemiec
Re: Copy/Paste problems [message #120876 is a reply to message #111726] Thu, 19 April 2007 09:56 Go to previous messageGo to next message
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
I´ve tried this approach, but I still can´t get this to work. I inserted
the two classes suggested and registered the new Factory class for the
notational model file my editor produces in the plugin.xml . I´m using
GMF 2.0 . Does this matter? Would be nice if someone could help me.
Greetings,
Christian
> regards,
> Seweryn Niemiec
Re: Copy/Paste problems [message #121931 is a reply to message #120876] Thu, 26 April 2007 02:49 Go to previous messageGo to next message
Thu, 19 Apr 2007 15:56:18 +0200, Christian Dänekas:
> Hello,
You should enable UUIDs for semantic model.
Seweryn Niemiec
Re: Copy/Paste problems [message #122173 is a reply to message #121931] Fri, 27 April 2007 06:38 Go to previous messageGo to next message
I had tried this, too. I just wanted to check your site again and the
server seems to be down. Could you post your solution here? Then I can
check again if I did it right.
Christian
>> Hello,
> Best regards,
> Seweryn Niemiec
Re: Copy/Paste problems [message #122236 is a reply to message #121931] Fri, 27 April 2007 08:01 Go to previous message
Nevermind,
I´ve got it to work. But this solution is a little strange I think. The
editor I´ve created is able to create diagrams from the semantic model
files, which comply to an xsd I´ve created. Now with the UUIDs enabled
diagram creation doesn´t work anymore for semantic model files created
manually without the UUIDs. Any ideas on that issue?
Greetings,
Christian
>> Hello,
> Best regards,
> Seweryn Niemiec
Previous Topic:Coustmizing properties tab of the editor
Next Topic:hoe to accesss the diagram element
Current Time: Sat Nov 15 13:02:10 EST 2025
Powered by FUDForum. Page generated in 0.05380 seconds
