Home » Language IDEs » ServerTools (WTP) » deployment to Weblogic 8.1 server
deployment to Weblogic 8.1 server [message #110144] Thu, 09 June 2005 06:56
Originally posted by: osz.gmx.de
Does anybody have experiences with WTP and the deployment to a Weblogic
8.1 server?
I worked through the Simple EJB tutorial. I created the Tiger EJB and
published it to a Weblogic 8.1 server. But during the server startup the
following error occurred:
Unable to deploy EJB:
/home/bea/user_projects/domains/mydomain/applications/Zoobea n.jar from
Zoobean.jar:
weblogic.ejb20.deployer.DeploymentDescriptorException: Unable to load a
class specified in your ejb-jar.xml: com.zoo.TigerHome
The problem seems to be that not all class files are directly included
in the Zoobean.jar file. Instead of that the class files are split to 2
jar files as follows:
Zoobean.jar:
META-INF/
META-INF/MANIFEST.MF
META-INF/ejb-jar.xml
META-INF/weblogic-ejb-jar.xml
ZoobeanClient.jar
com/
com/zoo/
com/zoo/TigerBean.class
com/zoo/TigerSession.class
and the ZoobeanClient.jar which is included int the Zoobean.jar:
com/zoo/Tiger.class
com/zoo/TigerHome.class
com/zoo/TigerLocal.class
com/zoo/TigerLocalHome.class
com/zoo/TigerUtil.class
If I manually include all class files to the Zoobean.jar file the
deployment works fine. Is there a way to configure the publishing
process in eclipse so that all class files are automatically included in
the Zoobean.jar file?
Many thanks in advance.
Oliver
Previous Topic:Environment Command Framework (ECF) and Dynamic Wizard Framework (DWF)
Next Topic:how to modify wsdd file ?
Current Time: Mon Nov 10 05:06:17 EST 2025
Powered by FUDForum. Page generated in 0.36335 seconds
