Home » Eclipse Projects » Eclipse Platform » How to change a Dialog button into depressed form
How to change a Dialog button into depressed form [message #110130] Mon, 11 August 2003 23:33 Go to next message
hi all,
I like to know how can I change a button(just like the one on
messageDialog) to a depressed after it has been pressed once by the user
ans it can't be pressed again until and unless it comes out of its
depressed form.
I would apprecaite your help.
Syed
Re: How to change a Dialog button into depressed form [message #110442 is a reply to message #110130] Tue, 12 August 2003 10:49 Go to previous messageGo to next message
You could try using a toggle button (a Button with style constant
SWT.TOGGLE), and then disabling (setEnabled(false)) it when you don't want
the user to change its state.. although it might not look quite like what
you're looking for.
Curt
"Syed Rizvi" <sma_r@hotmail.com> wrote in message
news:bh9n6v$37n$1@eclipse.org...
> hi all,
> depressed form.
> Syed
Re: How to change a Dialog button into depressed form [message #110614 is a reply to message #110442] Tue, 12 August 2003 19:44 Go to previous messageGo to next message
thanks for the idea but I am looking for something like when one is
installing a software you can't click on next until and unless the
regulation and copyright thing is Accepted.I hope this makes it clear/
thanks
Syed
> you're looking for.
> Curt
> > hi all,
> > depressed form.
> > Syed
Re: How to change a Dialog button into depressed form [message #110713 is a reply to message #110614] Wed, 13 August 2003 02:16 Go to previous message
Hi Syed,
the behaviour you described sounds for me like the disabling Curtis said:
button.setEnabled(false);
and when copyright is accepted:
button.setEnabled(true);
Ralf
> thanks
> Syed
>>you're looking for.
>>Curt
>>>hi all,
>>>depressed form.
>>>Syed
Previous Topic:Enable a "Stacktrace"
Next Topic:Missing "New Java files" in Code generation
Current Time: Tue Nov 04 20:48:25 EST 2025
Powered by FUDForum. Page generated in 0.04964 seconds
