Home » Modeling » OCL » constrain a node to be the only root in a graph
constrain a node to be the only root in a graph [message #836] Thu, 18 January 2007 13:35 Go to next message
I'm very new to OCL and have a few questions, the final one being the one
in the Subject line.
Are there any really good tutorials on OCL? I've had a look at this one
which is alright but are there any someone can recommend?
http://www.sciences.univ-nantes.fr/lina/atl/atldemo/oclturor ial/
What is the purpose of <>, is it not equal to? (java would be !=)
I'm specifically looking at GMF, I presume all OCL situations will
translate to from EMF to GMF?
To write a validation to check that diagram is not empty would it be
something like diagram.self -> isEmpty()
I don't really understand the purpose of 'self', could someone give me a
brief explination?
And finally, how would I write an OCL statement to check in a diagram that
only one node, lets call it A, has no parents (links moving directed away
from it), ie is the root node.
Thanks very much for your help.
Gaff
Re: constrain a node to be the only root in a graph [message #924 is a reply to message #836] Fri, 19 January 2007 16:53 Go to previous messageGo to next message
Hi, Gaff,
See some replies, in-line.
HTH,
Christian
Gaff wrote:
None better that I know of. There is the original Warmer & Kleppe book,
which should do pretty well as OCL 2.0 isn't *so* much different from OCL
1.x.
Exactly. Like Basic.
Yes. The usage of OCL in the GMF project is on EMF models.
More like
self.children->isEmpty()
where "self" represents the diagram (the constraint being defined in the
context of the Diagram class).
> brief explination?
Self is very much like 'this' in Java. It represents the element being
constrained by your OCL constraint, on which that constraint is applied at
run-time. It is called the "context variable" and its type is the "context
classifier" in which context the constraint is parsed. Typically the
context is declared in text via, e.g.,:
package notation context Diagram
inv myConstraint: ... your constraint here ...
endpackage
or by the placement of the constraint in the model (e.g., owned by the
Diagram class).
Perhaps something like:
self->closure(children)->one( child : View |
child.targetEdges->isEmpty() )
For simplicity, I am here using the "closure" iterator that our OCL
implementation defines as an addition to the language. This follows the
closure of the View::children association, which is (transitively) all of
the descendent views of the diagram (which is the "self" object).
The "one" iterator is defined by the OCL specification to query whether
there is exactly one element in the source collection:
for which the body expression:
is true.
> Gaff
Re: constrain a node to be the only root in a graph [message #954 is a reply to message #836] Fri, 19 January 2007 17:25 Go to previous message
Originally posted by: bezivin.univ-nantes.fr
Hi Gaff,
The original intention in the facility accessible through the URL you
mention below
was to demonstrate how a QVT-like
language like ATL could be used to provide a pedagogical
and interactive OCL evaluation service.
It is not really an OCL "tutorial" in the classical meaning.
"Gaff" <conorgaff@hotmail.com> a
Previous Topic:Re: OCL link constraint queries
Next Topic:Re: Problem with Interactive OCL Console used with Sample Ecore Editor
Current Time: Thu Jul 10 10:35:23 EDT 2025
Powered by FUDForum. Page generated in 0.26143 seconds
