Home » Eclipse Projects » GEF » Installing GEF correctly
Installing GEF correctly [message #109904] Tue, 23 December 2003 06:25 Go to next message
Originally posted by: john.rmts.donpac.ru
Hi, all
How can I install gef into Eclipse Version: 2.1.2 Build id: 200311030802
correctly?
Can I install if from web with site.xml (as
http://jfacedbc.sourceforge.net/update-site/site.xml)?
I tried to extract GEF-SDK-I20031015.zip into eclipse directory, but I
can't to see it in Update Manager.
Eugene Prokopiev
Re: Installing GEF correctly [message #109950 is a reply to message #109904] Tue, 23 December 2003 15:48 Go to previous messageGo to next message
1) See if there are any pending updates (in the Eclipse help menu).
2) If you haven't re-started Eclipse after extracting the GEF plug-ins, you
should.
3) See if the GEF (org.eclipse.gef) and Draw2D (org.eclipse.draw2d) plug-ins
show-up in Help -> About Eclipse -> Plug-in Details. If they don't check
the plug-ins folder to ensure that you extracted the plug-ins and features
in the right directory.
BTW, how do you know that GEF isn't properly installed? Do you have any
code that uses GEF in your workspace? You should download the GEF examples
for the 2.1.2 build
( http://download.eclipse.org/tools/gef/downloads/drops/R-2.1. 2-200310151343/
GEF-examples-I20031015.zip), if you haven't already, and see if they work
properly.
"Eugene Prokopiev" <john@rmts.donpac.ru> wrote in message
news:bs98fc$i9l$1@eclipse.org...
> Hi, all
> correctly?
> Eugene Prokopiev
Re: Installing GEF correctly [message #110010 is a reply to message #109950] Wed, 24 December 2003 06:46 Go to previous message
Pratik Shah пишет:
> should.
> for the 2.1.2 build
> properly.
Thanx, the problem was in Eclipse version. In 2.1.2 there are no problems.
Previous Topic:editable figure
Next Topic:Palette change
Current Time: Thu Nov 06 11:06:48 EST 2025
Powered by FUDForum. Page generated in 0.03886 seconds
