| Re: Installing GEF correctly [message #110010 is a reply to message #109950] |
Wed, 24 December 2003 06:46  |
Originally posted by: john.rmts.donpac.ru
Pratik Shah пишет:
> 1) See if there are any pending updates (in the Eclipse help menu).
> 2) If you haven't re-started Eclipse after extracting the GEF plug-ins, you
> should.
> 3) See if the GEF (org.eclipse.gef) and Draw2D (org.eclipse.draw2d) plug-ins
> show-up in Help -> About Eclipse -> Plug-in Details. If they don't check
> the plug-ins folder to ensure that you extracted the plug-ins and features
> in the right directory.
> BTW, how do you know that GEF isn't properly installed? Do you have any
> code that uses GEF in your workspace? You should download the GEF examples
> for the 2.1.2 build
> ( http://download.eclipse.org/tools/gef/downloads/drops/R-2.1. 2-200310151343/
> GEF-examples-I20031015.zip), if you haven't already, and see if they work
> properly.
Thanx, the problem was in Eclipse version. In 2.1.2 there are no problems.
FUDForum. Page generated in 0.03848 seconds
