Home » Language IDEs » C / C++ IDE (CDT) » Sending GDB command through CDT. What command do I need from CommandFactory?
Sending GDB command through CDT. What command do I need from CommandFactory? [message #109900] Thu, 08 July 2004 17:29 Go to next message
I am trying to send a "set hw-cycles 1" command to GDB, but I can't figure
out what type of command I need from the CommandFactory. I tried MIGDBSet,
but it doesn't work.
Any help would be appreciated.
Re: Sending GDB command through CDT. What command do I need from CommandFactory? [message #109908 is a reply to message #109900] Thu, 08 July 2004 17:39 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
That's what you need. What exactly happens when you use it?
"Bruno" <bvais@ti.com> wrote in message news:cckebp$8gg$1@eclipse.org...
Re: Sending GDB command through CDT. What command do I need from CommandFactory? [message #110044 is a reply to message #109908] Fri, 09 July 2004 11:00 Go to previous message
Hi Mikhail,
I get the following message in the console window:
"need to have malloc statement in project".
Perhaps I'm not using the right way to get a MISession. Here's what I do
in the plugin's "run" function:
public void run(IAction action) {
IDebugTarget
targets[]=DebugPlugin.getDefault().getLaunchManager().getDeb ugTargets();
ICDebugTarget target=(ICDebugTarget) targets[0].getDebugTarget();
ICDITarget cdiTarget=(ICDITarget)target.getAdapter( ICDITarget.class );
Session session=(Session) cdiTarget.getSession();
MISession mi=session.getMISession();
CommandFactory factory = mi.getCommandFactory();
MIGDBSet gdbSet=factory.createMIGDBSet(new String[] {"hw-cycles 1"});
mi.postCommand(gdbSet);
Bruno
Previous Topic:Code browsing...
Next Topic:How to make Code Assist work?
Current Time: Tue Jul 22 01:55:47 EDT 2025
Powered by FUDForum. Page generated in 0.05010 seconds
