Home » Modeling » GMF (Graphical Modeling Framework) » Using another data source for semantic model than xml-file
Using another data source for semantic model than xml-file [message #109668] Wed, 07 March 2007 12:01 Go to next message
I have a question about changing the data source of the EMF model:
I want to use a remote data source in form of a proprietary repository.
Instead of the EMF xmi-file I want to connect to a remote repository, a
procedure my semantic model is able to. I want to implement the load
process only as the semantic model reacts on changes of the repository
already and vice versa.
What is the typical way to achive this? The size and possibilities of
the framework are overhelming me once again :-)
Is it simply implementing my own DocumentProvider oder do I have to look
more closely at the Resource-Framework of EMF?
Greetings,
Alexander
Re: Using another data source for semantic model than xml-file [message #110321 is a reply to message #109668] Thu, 08 March 2007 11:43 Go to previous messageGo to next message
Alexander,
You'll want to implement a derived ResourceImpl and override doLoad and
doSave.
> Greetings,
> Alexander
Re: Using another data source for semantic model than xml-file [message #110875 is a reply to message #110321] Mon, 12 March 2007 05:46 Go to previous message
Hi Ed,
thank you very much.
Alexander
Ed Merks schrieb:
> Alexander,
> doSave.
>> Greetings,
>> Alexander
Previous Topic:Reference Based Link with a Type Based Link as target
Next Topic:where can i get org.eclipse.gmf.runtime.lite?
Current Time: Wed Nov 05 05:51:02 EST 2025
Powered by FUDForum. Page generated in 0.04677 seconds
