Home » Archived » Test and Performance Tools Platform (TPTP) » maximizing problem with dual monitor setup
maximizing problem with dual monitor setup [message #109641] Tue, 21 August 2007 05:05 Go to next message
I have a dual monitor setup with Windows Desktop extended to the
secondary monitor.
When I play back AGR test cases, the AUT is started and its window is
maximized. With my setup, it then covers both monitors.
Playback of test cases works well.
However, I would like to see the default maximizing behavior:
When clicking the Maximize button in the title bar the application
window expand to the boundaries of the monitor where it shows up, be it
either the primary or the secondary one.
IMHO, TPTP's maximizing action should cause the same effect.
Matthias
Environment:
- TPTP 4.4.0.2 AllinOne + correspondent AGR
- Windows XP SP2
- dual monitor setup
- JRE 1.5 Update 11
Re: maximizing problem with dual monitor setup [message #109654 is a reply to message #109641] Tue, 21 August 2007 06:36 Go to previous messageGo to next message
Hi Matthias,
Please open a defect against the TPTP Testing product and
Test.Execution.AutoGUIRunner component for this difference in behavior.
Paul
"Matthias Wiskow" <matthias.wiskow@windriver.com> wrote in message
news:fae9ss$9nb$1@build.eclipse.org...
> I have a dual monitor setup with Windows Desktop extended to the secondary
> monitor.
> When clicking the Maximize button in the title bar the application window
> expand to the boundaries of the monitor where it shows up, be it either
> Matthias
> Environment:
> - Windows XP SP2
> - JRE 1.5 Update 11
Re: maximizing problem with dual monitor setup [message #109756 is a reply to message #109654] Tue, 21 August 2007 10:48 Go to previous messageGo to next message
OK. Created Bugzilla Bug #200695.
Matthias
Paul Slauenwhite wrote:
> Hi Matthias,
> Paul
>> monitor.
>> Thanks,
>> Matthias
>> Environment:
>> - Windows XP SP2
>> - JRE 1.5 Update 11
Re: maximizing problem with dual monitor setup [message #109838 is a reply to message #109756] Thu, 23 August 2007 06:24 Go to previous message
Thanks Matthias. We will look into this during the next release (4.5).
news:faeu0i$rdq$1@build.eclipse.org...
> Matthias
>> Hi Matthias,
>> Paul
>>> Hi,
>>> secondary monitor.
>>> Thanks,
>>> Matthias
>>> Environment:
>>> - Windows XP SP2
>>> - JRE 1.5 Update 11
Previous Topic:[AGR, 4.4.0.2] missing information in test suite editor
Next Topic:AGR -Test Execution Harness problem
Current Time: Sun Nov 09 06:54:27 EST 2025
Powered by FUDForum. Page generated in 0.04101 seconds
