Home » Archived » EPP » How do I create a distributable zip of my plug-in?
How do I create a distributable zip of my plug-in? [message #9973] Fri, 29 August 2008 05:49 Go to next message
I am using Eclipse 3.3.2 (Europa)
I created a distributable zip of my plug-in as folows :
File->Export->Plug-in Development->Deployable Plug-ins and Fragments->Next.
Selected my plug-in in the list 'Available plug-ins and fragments'
Selected the option 'Archive file' in 'Destination' tab.
Provided path using 'Browse' button and pressed Finish.
Eclipse did create a zip file.
I tried to install it as follows :
Help->Software Updates-> Find and Install->Search For New Features To
Install->New Archived Site.
Then I pointed Eclipse to the directory on the file system where my zip is.
I get a dialog with following message :
"Selected archive does not contain an update site. Please select another
archive."
What is it that I am doing wrong?
Is there any other way / procedure to create a distributable zip / jar of
my plug-in?
Thanks.
Re: How do I create a distributable zip of my plug-in? [message #9997 is a reply to message #9973] Fri, 29 August 2008 08:57 Go to previous message
kaprasi wrote:
> Hello,
> I get a dialog with following message : "Selected archive does not
> contain an update site. Please select another archive."
> of my plug-in?
You need to create an update site project and build that; what you
created is just a zip of your feature/plugin, but an update site has
more than just that.
Note that you'll also have to have a Feature, as update sites work based
on features, not plugins directly.
The Eclipse Help has information on doing this under the "Plug-in
Development Environment" chapter.
Hope this helps,
Eric
Re: How do I create a distributable zip of my plug-in? [message #577836 is a reply to message #9973] Fri, 29 August 2008 08:57 Go to previous message
kaprasi wrote:
> Hello,
> of my plug-in?
Hope this helps,
Eric
Previous Topic:How do I create a distributable zip of my plug-in?
Next Topic:EPP/Maynstall and Equinox P2
Current Time: Tue Jul 08 15:44:52 EDT 2025
Powered by FUDForum. Page generated in 0.16886 seconds
