| Can't run agains source code of 1.11 [message #109492] |
Fri, 17 October 2008 02:45  |
Originally posted by: qwan.actuate.com
I tried to check out the source code with the team set file from RAP
website.
All the projects compile all right, but when I tried to launch a new
eclilpse application, which should include all these source code projects,
the lauch terminated without any message.
What's the right way to lauch the RAP platform against the source code?
I'd like to trace the source code of the RAP platform, not only use the
RAP for ajax application.
Cheers
Qiangsheng
| Re: Can't run agains source code of 1.11 [message #109666 is a reply to message #109656] |
Fri, 17 October 2008 07:42   |
Hi Rüdiger,
Thanks for the reply. I can run the demo code with the binary (RAP
tooling).
I just want to try if I can run with the source code directly. I mean just
like you're developing a plug-in project, you can lauch another instance
of eclipse, and then get the
feature of the developing feature. Are there a way to do this for RAP?
BTW, the RAP is very cool! Thanks for the great jobs.
Cheers
Qiangsheng
On Fri, 17 Oct 2008 18:47:16 +0800, Rüdiger Herrmann
<rherrmann@innoopract.com> wrote:
> Qiangsheng,
> the recommended way of launching RAP applications is to use the launcher
> that comes with RAP Tooling (update site and zipped download here:
> http://www.eclipse.org/rap/downloads)
> Your problem might be caused by using the wrong target platform.What
> bundles are in your target platform?
> Is the list of bundles that should run in your launch config valid?
> HTH
> Rüdiger
>> website.
>> projects, the lauch terminated without any message.
>> Cheers
>> Qiangsheng
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
| Re: Can't run agains source code of 1.11 [message #110125 is a reply to message #109867] |
Tue, 21 October 2008 20:15   |
Hi Rüdiger,
yes, I have checked out the plug-ins by uisng the team set. After having
these plug-ins in my workspace, I assume I should start up a new instance
of eclipse by lauching -> eclipse application. Then I can using this new
instance of eclipse application for running RAP. Is this process right?
Cheers
Qiangsheng
On Mon, 20 Oct 2008 16:15:36 +0800, Rüdiger Herrmann
> Qiangsheng,
> I am still not sure if I understand what you want to achieve. If your
> goal is to use the RAP plug-ins from CVS instead of those provided by
> the target, please see this post:
> http://www.eclipse.org/newsportal/article.php?id=4620&gr oup=eclipse.technology.rap#4620
> HTH
> Rüdiger
>> Hi Rüdiger,
>> tooling).
>> just like you're developing a plug-in project, you can lauch another
>> instance of eclipse, and then get the
>> Cheers
>> Qiangsheng
>>> Qiangsheng,
>>> launcher that comes with RAP Tooling (update site and zipped download
>>> here: http://www.eclipse.org/rap/downloads)
>>> HTH
>>> Rüdiger
>>>> website.
>>>> code? I'd like to trace the source code of the RAP platform, not only
>>>> use the RAP for ajax application.
>>>> Cheers
>>>> Qiangsheng
FUDForum. Page generated in 0.05240 seconds
