Home » Eclipse Projects » Linux Tools Project » Can't install Linux Tools
Can't install Linux Tools [message #9971] Tue, 09 June 2009 12:06 Go to next message
Hi, guys!
I try to install Linux tools from archive I downloaded from the internet.
I instruct Eclipse update manager with the location of the archive and
then start the installation process but I get error. I decided to install
autotools for starters but for some reason update manager thinks that some
other plugin that autotools relies on is missing. Error message is this:
Cannot complete the install because one or more required items could not
be found.
Software being installed: Autotools Feature (Incubation)
1.0.3.200905251648
(org.eclipse.linuxtools.cdt.autotools.feature.feature.group
1.0.3.200905251648)
Missing requirement: Autotools Feature (Incubation) 1.0.3.200905251648
1.0.3.200905251648) requires 'org.eclipse.cdt.make.core [5.0.0,6.0.0)' but
it could not be found
I looked at the list of installed plugins and it says that it has:
org.eclipse.cdt.make.core (6.0.0.200905061052) "C/C++ Standard make Build
Core" [Active]
Is there any way to manually override this?
I have Eclipse 3.5RC3 and CDT 6.0 (installed from latest CDT 6.0 master
archive!) on my computer.
Re: Can't install Linux Tools [message #9994 is a reply to message #9971] Tue, 09 June 2009 17:18 Go to previous messageGo to next message
> master archive!) on my computer.
Our update site is for Ganymede (CDT 5) dependencies. You can install
from a zip of our Galileo builds instead. Grab the latest one here:
https://build.eclipse.org/hudson/job/cbi-linuxtools-Galileo/
After adding the zip as an archive in the update dialog, if you see
nothing listed in main pane it's because we have no categories.
Un-check the "group by categories" option at the bottom.
Our forth-coming (July) 0.3 release will target Galileo.
HTH,
Andrew
Re: Can't install Linux Tools [message #478841 is a reply to message #9994] Fri, 07 August 2009 04:28 Go to previous messageGo to next message
Hi.
I download the latest Galileo build as archive.zip. In Eclipse 3.5 I go
to Preferences/"Install/Update"/Available Software Sites and click Add.
I then click "Archive..." and selects the archive.zip file I downloaded.
The site is added with the following URL:
jar:file:/home/micke/dev/galileo/update-sites/linux-tools/ar chive.zip!/
The URL looks exactly like this. It looks a bit strange to me. Is this
correct?
When I try to install anything from this site in the install dialog I
get an error saying "No repository found at
jar:file:/home/micke/dev/galileo/update-sites/linux-tools/ar chive.zip!/. "
What am I doing wrong?
Regards, Micke.
> HTH,
> Andrew
Re: Can't install Linux Tools [message #479038 is a reply to message #9994] Sat, 08 August 2009 09:55 Go to previous messageGo to next message
this version does not seem to be available yet (see also my thread
"autotools in Galileo")
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Can't install Linux Tools [message #479867 is a reply to message #478841] Wed, 12 August 2009 15:41 Go to previous messageGo to next message
We're readying our 0.3 release with a plan of releasing it one week from day (the 19th of August). If you want to try it now, with an Eclipse SDK 3.5, use this update site:
http://download.eclipse.org/technology/linuxtools/updates-ni ghtly
If you can't use the update site, you can grab a zip of the latest build from here:
https://build.eclipse.org/hudson/job/cbi-linuxtools-Galileo/ lastSuccessfulBuild/artifact/
Click on build/<the directory with the big name including 200908something>
Download linuxtools-Update-incubation-<same big date-string as above>.zip
Use it as an archive as you've tried with the update manager
The URI will indeed look funny with the jar and the ! but it is correct
Please let us know if it doesn't work.
Thanks and sorry for the delay,
Andrew
Re: Can't install Linux Tools [message #481527 is a reply to message #479867] Fri, 21 August 2009 08:07 Go to previous messageGo to next message
> from here:
> Andrew
I downloaded the zip, and extracted it in the dropins folder, but
eclipse does not seem to detect it...
dropins/
linuxtools/
eclipse/
<plugins> contents
<features> contents
where am I going wrong?
thanks in advance
Lorenzo
Re: Can't install Linux Tools [message #494404 is a reply to message #481527] Fri, 30 October 2009 10:33 Go to previous message
Dropins isn't the best way to install things, but I suggest you ask the p2 team as they are experts in this area. i suggest using the UI to install from our update site or from a zip.
Re: Can't install Linux Tools [message #566405 is a reply to message #9971] Tue, 09 June 2009 17:18 Go to previous message
HTH,
Andrew
Re: Can't install Linux Tools [message #566867 is a reply to message #9994] Fri, 07 August 2009 04:30 Go to previous message
Hi.
correct?
Regards, Micke.
> HTH,
> Andrew
Re: Can't install Linux Tools [message #566875 is a reply to message #9994] Sat, 08 August 2009 09:55 Go to previous message
Re: Can't install Linux Tools [message #566884 is a reply to message #566867] Wed, 12 August 2009 15:41 Go to previous message
Andrew
Re: Can't install Linux Tools [message #566915 is a reply to message #566884] Fri, 21 August 2009 08:07 Go to previous message
> from here:
> Andrew
dropins/
linuxtools/
eclipse/
<plugins> contents
<features> contents
thanks in advance
Lorenzo
Re: Can't install Linux Tools [message #567364 is a reply to message #481527] Fri, 30 October 2009 10:33 Go to previous message
Previous Topic:ubuntu launching Eclipse
Next Topic:linux-tools oprofile x64
Current Time: Thu Jul 17 19:45:11 EDT 2025
Powered by FUDForum. Page generated in 0.11092 seconds
