Home » Archived » IMP » Experiences; custom parser?
| Experiences; custom parser? [message #9961] |
Tue, 16 October 2007 11:00  |
Originally posted by: L.C.L.Kats.tudelft.nl
At Delft University we're very much interested in the IMP Project. In
the future, we may be interested in integrating it with the SDF2
parser and Stratego/XT program transformation suite. At the moment
though, I have just been playing around with the current
implementation a bit, creating an IDE for an experimental language
developed here. First, a list of some things I ran into, which I hope
is useful:
* The wizards seem to be very picky about the inputs. (Something
common to most early implementations of Eclipse plugins...)
- They require the project to be in the workspace _directory_, not
just imported into the workspace from a different location.
- For LPG to work, I had to place Eclipse in a directory without
spaces in the path (i.e., outside "Program Files" under Windows)
- Not all wizards correctly convert the package name to lowercase.
* The editors don't seem to fully support multiple instances of the
same file (right click "new editor" on any editor pane). Quickly
pasting content into a duplicated editor seems to break it.
* The LPG editors are very helpful with their support for
hyperlinking and inline error reporting. It is a bit strict about
rules that are unused though, shouldn't those result in a warning
rather than an error?
* Finally, one issue came up when I was rewriting our existing grammar
to use LPG. In our grammar we currently have a comment block in the
form of "description { ... }". This caused a conflict with the
"define" keyword, even with backtracking enabled, apparently because
they share a common prefix. I was finally able to work around this
by placing the "define" keyword in the regular lexer rather than in
the keyword lexer...
Other than these issues, it seems the current implementation already
provides some really nice, time-safing abstractions over the regular
Eclipse API, mainly thanks to the AST-based approach. What took the
most time when creating my editor, of course, was writing the
grammar. I had an existing SDF2 grammar as a basis (that is,
scannerless generalized LR; SGLR), which included quite a few nasty
language features that were hard to translate to LPG. (Such as the
comment blocks and - at the moment - a complete lack of reserved
keywords.)
As I understand from the documentation, the current implementation
isn't quite ready yet for custom parsers, due to the use of concrete
types rather than interfaces. Other than that, are there any current
hurdles that may be inhibiting the use of a custom parser? Does the
fact that the SGLR parser doesn't employ a separate lexer form any
problem?
Lennart Kats
Software Engineering Research Group,
Department of Software Technology,
Delft University of Technology.
| Re: Experiences; custom parser? [message #10054 is a reply to message #9961] |
Tue, 16 October 2007 17:34   |
Hello Lennart,
I have posted some Bugzilla reports regarding the problems you observed.
I have a few questions of clarification on some of the points (in-lined
below).
Thanks for your help,
Stan Sutton
Lennart Kats wrote:
> is useful:
Are you talking about your Eclipse installation or about your Eclipse
workspace?
Can you cite some examples? What do you regard as the correct lowercase
conversion? (I've seen different approaches.)
I tried to replicate this error in a level 3 workspace but did not see
it. That is, I had defined an IDE in a level 2 runtime workbench, and
then run a runtime workbench from that. I was able to run the "New
Editor" command without pasting with no problems, and when I ran the
command and immediately pasted some text into the new editor I again did
not see any problems. I was using just the LEG grammar and IDE that is
provided as an example in our templates, so no special programming of
the grammar or IDE service implementations.
> keywords.)
> problem?
> Lennart Kats
| Re: Experiences; custom parser? [message #10099 is a reply to message #9961] |
Wed, 17 October 2007 06:15   |
Originally posted by: olegm.gmail.com
--------------040304070409040703040407
> problem?
I've managed to integrate Beaver
http://beaver.sourceforge.net/
into IMP (see attachment).
OM
Content-Type: text/x-java;
name="PicoJavaParseController.java"
Content-Disposition: inline;
filename="PicoJavaParseController.java"
package picojava.parser;
import java.io.IOException;
import java.io.StringReader;
import java.util.ArrayList;
import java.util.Collections;
import java.util.List;
import lpg.runtime.IMessageHandler;
import lpg.runtime.IPrsStream;
import lpg.runtime.IToken;
import lpg.runtime.LexStream;
import lpg.runtime.Monitor;
import lpg.runtime.ParseErrorCodes;
import lpg.runtime.PrsStream;
import org.eclipse.core.runtime.IPath;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.Path;
import org.eclipse.imp.model.ISourceProject;
import org.eclipse.imp.parser.IASTNodeLocator;
import org.eclipse.imp.parser.ILexer;
import org.eclipse.imp.parser.IParseController;
import org.eclipse.imp.parser.IParser;
import AST.ASTNode;
import AST.PicoJavaParser;
import AST.PicoJavaScanner;
import AST.Program;
import AST.PicoJavaParser.Terminals;
import beaver.Parser;
import beaver.Scanner;
import beaver.Symbol;
import beaver.Parser.Context;
public class PicoJavaParseController implements IParseController,
IPicoJavaParseController {
private IMessageHandler handler;
private ISourceProject project;
private IPath filePath;
private LexStream lexStream;
private PrsStream prsStream;
private Program currentAst;
private IParser parser = new IParser() {
public PrsStream getParseStream() {
return prsStream;
public int getEOFTokenKind() {
return Terminals.EOF;
public Object parser(Monitor monitor, int error_repair_count) {
throw new UnsupportedOperationException(
"This method should really not be exposed in IParser");
private ILexer lexer = new ILexer() {
public int[] getKeywordKinds() {
return new int[0];
public LexStream getLexStream() {
return lexStream;
public void initialize(char[] contents, String filename) {
"This method should really not be exposed in ILexer");
public void lexer(Monitor monitor, IPrsStream prsStream) {
private IASTNodeLocator locator = new IASTNodeLocator() {
public Object findNode(Object node, int startOffset, int endOffset) {
ASTNode astNode = (ASTNode) node;
int nodeStartOffset = pos2offset(astNode.getStart());
int nodeEndOffset = pos2offset(astNode.getEnd());
if (!(nodeStartOffset <= startOffset && endOffset <= nodeEndOffset))
return null;
for (int i = 0; i < astNode.getNumChild(); i++) {
Object result = findNode(astNode.getChild(i), startOffset,
endOffset);
if (result != null)
return result;
return astNode;
public Object findNode(Object node, int startOffset) {
return findNode(node, startOffset, startOffset);
public int getStartOffset(Object node) {
return pos2offset(((ASTNode) node).getStart());
public int getEndOffset(Object node) {
return pos2offset(((ASTNode) node).getEnd());
public int getLength(Object node) {
return getEndOffset(node) - getStartOffset(node);
public IPath getPath(Object node) {
return new Path("");
public void initialize(IPath filePath, ISourceProject project,
IMessageHandler handler) {
this.filePath = filePath;
this.project = project;
this.handler = handler;
// doParse(new
// FileReader(project.getRawProject().getLocation().append(file Path).toOSString()));
public IParser getParser() {
return parser;
public ILexer getLexer() {
return lexer;
public ISourceProject getProject() {
return project;
public IASTNodeLocator getNodeLocator() {
return locator;
public IPath getPath() {
return filePath;
public Object getCurrentAst() {
return currentAst;
public boolean hasErrors() {
// TODO:
return false;
public List getErrors() {
// TODO:
return Collections.EMPTY_LIST;
public Object parse(String contents, boolean scanOnly,
IProgressMonitor monitor) {
currentAst = null;
if (doPrepare(contents))
doParse(contents);
return currentAst;
public boolean isKeyword(int kind) {
switch (kind) {
case Terminals.CLASS:
case Terminals.WHILE:
case Terminals.EXTENDS:
case Terminals.BOOLEAN_LITERAL:
return true;
default:
return false;
public char[][] getKeywords() {
return new char[0][0];
public String getSingleLineCommentPrefix() {
"This method should not be here");
public int getTokenIndexAtCharacter(int offset) {
int index = getParser().getParseStream().getTokenIndexAtCharacter(
offset);
return (index < 0 ? -index : index);
public IToken getTokenAtCharacter(int offset) {
return prsStream.getTokenAtCharacter(offset);
private static List problemMarkerTypes = new ArrayList();
public List getProblemMarkerTypes() {
return problemMarkerTypes;
public void addProblemMarkerType(String problemMarkerType) {
problemMarkerTypes.add(problemMarkerType);
public void removeProblemMarkerType(String problemMarkerType) {
problemMarkerTypes.remove(problemMarkerType);
private boolean doPrepare(String contents) {
// Initialize lex stream
lexStream = new LexStream();
lexStream.initialize(contents.toCharArray(), filePath
.toPortableString());
lexStream.setMessageHandler(handler);
// Initialize parse stream
prsStream = new PrsStream();
prsStream.setLexStream(lexStream);
prsStream.makeToken(0, -1, 0);
boolean result = true;
try {
PicoJavaScanner scanner = new PicoJavaScanner(new StringReader(
contents));
Symbol symbol;
for (symbol = scanner.nextToken(); symbol.getId() != Terminals.EOF; symbol = scanner
.nextToken()) {
prsStream.makeToken(pos2offset(symbol.getStart()),
pos2offset(symbol.getEnd()), symbol.getId());
} catch (Scanner.Exception e) {
int offset = lexStream.getLineOffset(e.line - 1) + e.column;
int[] location = lexStream.getLocation(offset, offset);
handler.handleMessage(ParseErrorCodes.NO_MESSAGE_CODE, location,
location, lexStream.getFileName(), new String[] { e
.getMessage() });
result = false;
} catch (IOException e) {
throw new RuntimeException(e);
prsStream.makeToken(lexStream.getStreamLength(), lexStream
.getStreamLength(), Terminals.EOF);
prsStream.setStreamLength(prsStream.getSize());
return result;
private void doParse(String contents) {
// Do the parsing
try {
PicoJavaParser parser = new PicoJavaParser();
contents));
parser.setContext(new Context() {
public void reportError(String message, int start, int end) {
int startOffset = pos2offset(start);
int endOffset = pos2offset(end);
// If unexpected EOF
if (startOffset >= lexStream.getStreamLength()
&& lexStream.getStreamLength() > 0)
startOffset = lexStream.getStreamLength() - 1;
int[] location = lexStream.getLocation(startOffset,
endOffset);
location, location, lexStream.getFileName(),
new String[] { message });
currentAst = (Program) parser.parse(scanner);
} catch (Parser.Exception e) {
if (e.start != -1) {
.getLocation(lexStream.getStreamLength() - 1, lexStream
.getStreamLength() - 1);
new String[] { e.getMessage() });
public int pos2offset(int pos) {
return lexStream.getLineOffset(Symbol.getLine(pos) - 1)
+ Symbol.getColumn(pos);
--------------040304070409040703040407--
| Re: Experiences; custom parser? [message #10122 is a reply to message #10054] |
Wed, 17 October 2007 09:03   |
Hi Stan,
Thanks for your reply, my response follows below.
Stanley Sutton wrote:
> Hello Lennart,
> below).
> Stan Sutton
> workspace?
This is about my Eclipse installation. With Eclipse in the directory
"C:\Program Files\Eclipse3.2", I get the following error about an argument
passed to LPG:
"Files/Eclipse3.2/plugins/lpg.runtime_2.0.7/templates/" is an invalid
option
I tried adjusting the path in the preferences pages, adding quotes etc.,
but the only thing that seemed to fix it was to move the Eclipse
installation.
Correct would be that all wizards generate the same package names, at
the moment I don't really care about what naming convention is used ;)
Right now, if I call my language "DemoDSL", the Token Colorer and
Source Folding Updater will try to create a "demoDSL" package rather
than use the existing "demodsl" package.
Let me clarify that: This happens when repeatedly hit paste, with two
LPG editors opened next to each other in a level 1 workbench. Just
holding the paste key for a couple seconds reproduces this for
me. After that it fails with a NullPointerException or a "Unhandled
event loop exception" (no stack traces are provided), causing both
editors to stop working.
Lennart Kats
| Re: Experiences; custom parser? [message #530916 is a reply to message #9961] |
Sun, 02 May 2010 14:43   |
I tried to use in IMP my own, ANTLR-generated parser, so I implemented IParseController, ISourcePositionLocator and some in-code interfaces; then I added token-coloring (by wizard), just to check if parser works, but when I open file with my language's extension, error window occurs: "Unable to instantiate parser for language '%LangName%'; parser-related services will be disabled."
I tried to set breakpoints at the IParseController's constructor, but it looks like IPaseController doesn't even invoked.
Any suggestions? How can I find more information on such error, or, may be, what class invokes IParseController?
| Re: Experiences; custom parser? [message #567432 is a reply to message #9961] |
Hello Lennart,
below).
Stan Sutton
Lennart Kats wrote:
> is useful:
workspace?
> keywords.)
> problem?
> Lennart Kats
| Re: Experiences; custom parser? [message #567482 is a reply to message #9961] |
> problem?
OM
import AST.ASTNode;
import AST.Program;
return prsStream;
return new int[0];
return lexStream;
return null;
endOffset);
if (result != null)
return result;
return astNode;
// doParse(new
return parser;
return lexer;
return project;
return locator;
return filePath;
return currentAst;
// TODO:
return false;
// TODO:
currentAst = null;
doParse(contents);
return currentAst;
switch (kind) {
return true;
default:
return false;
offset);
try {
contents));
Symbol symbol;
.nextToken()) {
.getMessage() });
result = false;
return result;
// Do the parsing
try {
contents));
endOffset);
| Re: Experiences; custom parser? [message #567519 is a reply to message #10054] |
Hi Stan,
> Hello Lennart,
> below).
> Stan Sutton
> workspace?
passed to LPG:
option
installation.
Lennart Kats
| Re: Experiences; custom parser? [message #577775 is a reply to message #9961] |
| Re: Experiences; custom parser? [message #578199 is a reply to message #578185] |
Thu, 16 September 2010 06:49  |
Thanks, Margus.
Frankly speaking, I don't remeber, what causes my problem, but when I asked this question by IMP-dev mailing list, I'v got solution. So, if anybody would ran into such problem, he should check imp mailing list for nearly spring-summer of 2010.
Current Time: Thu Nov 20 14:52:16 EST 2025
Powered by FUDForum. Page generated in 0.06779 seconds
