Home » Modeling » GMF (Graphical Modeling Framework) » How should I approach this problem?
How should I approach this problem? [message #108856] Mon, 05 March 2007 07:31
Hello all...
I would like to model a device that is made up of multiple components,
the components within the device are presented in a horizontal list.
The components have position within the device and it should be possible
to select a component and drag it to a new position in the list.
I have so far generated the model and used the tooling to map the
components into a devices one and only 'compartment' - I have also
managed to align the components horizontally... so far so good. However
I now need pointers as I am stuck and do not know how to proceed from here.
How can I make the components selectable, so that they can be dragged
and dropped into different positions? Should I even be using a list?
Should I be using a compartment?
What is the best approach to take?
Any and all help appreciated.
Kristian.
Previous Topic:use "new" string externalization mechanism
Next Topic:Problems opening a persisted extension of Diagram
Current Time: Wed Nov 05 20:20:01 EST 2025
Powered by FUDForum. Page generated in 0.04978 seconds
