Problem with latest integration build [message #108550] |
Wed, 01 June 2005 08:04  |
Hello
I am running Eclipse RC1 on WinXP and downloaded and installed all of the
plugins referenced as prerequisites on the downloadpage for the WTP
I20050601 build.
When starting eclipse I get the error message included below. Any triks I
need to do?
Tor
!SESSION 2005-06-01
13:55:37.680 -----------------------------------------------
eclipse.buildId=I20050527-1300
java.version=1.5.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=no_NO
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.update.configurator 2005-06-01 13:55:38.840
!MESSAGE Plugin does not have a valid identifier:
plugins/org.eclipse.jst.doc.isv_1.0.0/
!MESSAGE Plugin does not have a valid version:
!ENTRY org.eclipse.update.configurator 2005-06-01 13:55:39.140
plugins/org.eclipse.wst.doc.isv_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-06-01 13:55:39.150
plugins/org.eclipse.wst.html.ui_1.0.0.jar
!ENTRY org.eclipse.update.configurator 2005-06-01 13:55:40.390
!MESSAGE Could not install bundle plugins/org.eclipse.jst.doc.isv_1.0.0/
Error converting plugin at
c:\tools\eclipse31RC1\eclipse\plugins\org.eclipse.jst.doc.is v_1.0.0.
!ENTRY org.eclipse.update.configurator 2005-06-01 13:55:40.610
!MESSAGE Could not install bundle plugins/org.eclipse.wst.doc.isv_1.0.0/
c:\tools\eclipse31RC1\eclipse\plugins\org.eclipse.wst.doc.is v_1.0.0.
!ENTRY org.eclipse.update.configurator 2005-06-01 13:55:40.620
!MESSAGE Could not install bundle plugins/org.eclipse.wst.html.ui_1.0.0.jar
c:\tools\eclipse31RC1\eclipse\plugins\org.eclipse.wst.html.u i_1.0.0.jar.
Re: Problem with latest integration build [message #109968 is a reply to message #109192] |
Wed, 08 June 2005 03:38  |
On Thu, 02 Jun 2005 15:02:56 -0400, Yogesh Chaudhari <ceeneel@gmail.com> wrote:
>> plugins/org.eclipse.wst.html.ui_1.0.0.jar Error converting plugin at
Just to clarify, this list of problems is not due to the update.configurator
patch (the update.configurator patch is needed to use RC1, but these bugs
are of a different nature. The last (HTML) one indicates you got an early version
of the I-build ... 6/3's a little better. The "doc" ones are related to
how we've been switching to a new way to package our plugins (new to us)
and we haven't quite got the doc ones figured out ... even yet!
But they do no harm ... well, except there would be no doc, if we had any
there to begin with :)
FUDForum. Page generated in 0.04712 seconds
