Re: [ANN] GEF and Eclipse 3.0M5 [message #109798 is a reply to message #109791] |
Fri, 19 December 2003 20:01  |
Originally posted by: jpl.remotejava.com
chhil wrote:
> Hello Jan,
> I got the latest working integration build and the latest GEF
> integration build. GEF did not show up in the config manager.
> The only way I could get around this was to delete the .config folder
> and started eclipse and this time GEF showed up in the config manager.
Thanks for the reply.
It turned out to be simpler in my case: the feature, for some reason,
was installed in "disabled" state. So I had to click on the "Show
disabled features" icon in configuration manager and manually "Enable"
the GEF feature. After that, the usual "Do you want to restart?" dialog
appeared - which in 2.1.x normally pops up at the first startup when
Eclipse detects new features. Perhaps this procedure was changed in 3.0.
-JPL
FUDForum. Page generated in 0.04204 seconds
