Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Ecore Tools] Search references popup menu
[Ecore Tools] Search references popup menu [message #107770] Tue, 22 January 2008 06:00 Go to next message
In the Ecore editor, I have tried to use the search references on an EClass.
It seems this ability is available and similar both througth the
graphical area and the outline, but the icons are not the same.
Regards, Cyril.
Cyril Faucher
IRISA-INRIA - Rennes, France
[Breathe life into your metamodels www.kermeta.org]
Re: [Ecore Tools] Search references popup menu [message #107784 is a reply to message #107770] Tue, 22 January 2008 08:41 Go to previous messageGo to next message
Cyril,
This action is currently brought by the EMFT Search Component, but that
is true we need to think of a better/similar way of letting the user
searching/navigating along the existing EReference related to a given
EClass. This action and the References View developed as part of the
Ecore Tools project provide same functionality using two ways.
Cyril Faucher a écrit :
> EClass.
> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #107798 is a reply to message #107784] Tue, 22 January 2008 09:41 Go to previous messageGo to next message
Ok, Jacques. All these shortcuts are very useful with large and unknown
metamodels.
Another question, maybe it is a "EMF Search" topic, but I think the
search exec is very long (15s) with my metamodel.
Cyril.
Jacques LESCOT a écrit :
> Cyril,
>> EClass.
>> Regards, Cyril.
Cyril Faucher
Re: [Ecore Tools] Search references popup menu [message #107813 is a reply to message #107798] Tue, 22 January 2008 10:06 Go to previous messageGo to next message
Yes, this is an EMFT Search related question. When you perform the
search request on your large metamodel, did you restricted the Search
scope on the metamodel only ? If your metamodel loads external
Resources, this might be a reason of the slow search process.
> metamodels.
> Cyril.
>> Cyril,
>> that is true we need to think of a better/similar way of letting the
>> user searching/navigating along the existing EReference related to a
>> given EClass. This action and the References View developed as part of
>> the Ecore Tools project provide same functionality using two ways.
>>> Hi,
>>> EClass.
>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #107827 is a reply to message #107813] Tue, 22 January 2008 13:33 Go to previous messageGo to next message
did you discriminate your search participants to the sole EClass meta
element ?
If it is the case I would be more than happy grabbing an ecore model
example to find the cause of such slowish execution.
I also maybe have to explore efficiency about EMFT Search model loading
which is a not optimized for large models for the moment.
cheers,
>> unknown metamodels.
>> Cyril.
>>> Cyril,
>>> of the Ecore Tools project provide same functionality using two ways.
>>>> Hi,
>>>> EClass.
>>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #108050 is a reply to message #107827] Thu, 24 January 2008 05:53 Go to previous message
Hi Lucas,
Comments below.
> element ?
You can download the famous Kermeta metamodel at:
http://gforge.inria.fr/plugins/scmcvs/cvsweb.php/kermeta_pro jects/fr.irisa.triskell.kermeta.model/build/ecore/kermeta_ja va.ecore?cvsroot=kermeta
A detail: this problem has been detected during the search launched by
the EReferences search feature from the Ecore Tools Ecore editor
(right-clic on an EClass) and not directly via the classical Eclipse Search.
I guess this feature discriminates the search participants to the sole
EReference meta-element...
Cyril.
> cheers,
>>> unknown metamodels.
>>> Cyril.
>>>> Cyril,
>>>>> Hi,
>>>>> an EClass.
>>>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #614055 is a reply to message #107770] Tue, 22 January 2008 08:41 Go to previous message
Cyril,
> EClass.
> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #614056 is a reply to message #107784] Tue, 22 January 2008 09:41 Go to previous message
metamodels.
Cyril.
> Cyril,
>> EClass.
>> Regards, Cyril.
Cyril Faucher
Re: [Ecore Tools] Search references popup menu [message #614057 is a reply to message #107798] Tue, 22 January 2008 10:06 Go to previous message
> metamodels.
> Cyril.
>> Cyril,
>>> Hi,
>>> EClass.
>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #614058 is a reply to message #107813] Tue, 22 January 2008 13:33 Go to previous message
element ?
cheers,
>> unknown metamodels.
>> Cyril.
>>> Cyril,
>>>> Hi,
>>>> EClass.
>>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #614074 is a reply to message #107827] Thu, 24 January 2008 05:53 Go to previous message
Hi Lucas,
Comments below.
> element ?
Cyril.
> cheers,
>>> unknown metamodels.
>>> Cyril.
>>>> Cyril,
>>>>> Hi,
>>>>> an EClass.
>>>>> Regards, Cyril.
Previous Topic:EMFT - Mint - Build Announcements
Next Topic:JUnit Test on JET Transform
Current Time: Tue Jul 15 04:13:56 EDT 2025
Powered by FUDForum. Page generated in 0.15974 seconds
