Home » Archived » BIRT » Report in a View
Report in a View [message #107736] Wed, 11 January 2006 16:36 Go to next message
Originally posted by: tomasz.gielda.gmail.com
Hello. I'm trying to run Report Engine within one of my aplications'
views, the code is similar to exaples provided by Birt team, everything
seems to be ok, but...
org.eclipse.birt.core.framework.eclipse.EclipseExtensionPoin t.getExtensions(EclipseExtensionPoint.java:48)
org.eclipse.birt.report.engine.extension.internal.ExtensionM anager.loadGenerationExtensionDefns(ExtensionManager.java:21 7)
org.eclipse.birt.report.engine.extension.internal.ExtensionM anager. <init>(ExtensionManager.java:76)
org.eclipse.birt.report.engine.extension.internal.ExtensionM anager.createInstance(ExtensionManager.java:88)
org.eclipse.birt.report.engine.extension.internal.ExtensionM anager.getInstance(ExtensionManager.java:97)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.<init >(ReportEngineHelper.java:62)
org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:80)
org.ebisoft.hectas.GUI.MakeReportView.createPartControl(Make ReportView.java:62)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:305)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:1655)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:930)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:913)
at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.j ava:3148)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3145)
at org.ebisoft.hectas.GUI.MenuView$1.widgetSelected(MenuView.ja va:75)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
Can anybody tell me what caused this error?
Thanks in advance.
Tom
Re: Report in a View [message #107776 is a reply to message #107736] Wed, 11 January 2006 18:36 Go to previous messageGo to next message
Tomasz
What version of BIRT are you using and
can you post your code?
Jason Weathersby
BIRT PMC
"Tomasz Gielda" <tomasz.gielda@gmail.com> wrote in message
news:a325e0f910d69ba1f7d3519eb4cfba98$1@www.eclipse.org...
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance.
> Tom
Re: Report in a View [message #107844 is a reply to message #107776] Wed, 11 January 2006 19:29 Go to previous message
Jason Weathersby wrote:
> Tomasz
> Jason Weathersby
> BIRT PMC
>>at
>>at
>>at
>>at
>>at
>>at
>>org.eclipse.birt.report.engine.api.impl.ReportEngineHelper. <init>(ReportEngineHelper.java:62)
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>Thanks in advance.
>>Tom
Do you have your BIRT_HOME set correctly? Seems that you cannot load
plugins.
Stanley Wang
BIRT Engine
Previous Topic:birt viewer logs
Next Topic:Is it possible to iterate ResultSet rows from report using JS?
Current Time: Tue Jul 22 22:11:07 EDT 2025
Powered by FUDForum. Page generated in 0.41016 seconds
