Home » Modeling » GMF (Graphical Modeling Framework) » workaround for bug #147855 (hide compartment if empty) - any hints?
workaround for bug #147855 (hide compartment if empty) - any hints? [message #9761] Tue, 08 August 2006 04:03 Go to next message
I'm looking for a workaround for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=147855
Does anyone has an idea how to make this working?
Any hint is highly appreciated
Michael
Re: workaround for bug #147855 (hide compartment if empty) - any hints? [message #15898 is a reply to message #9761] Fri, 11 August 2006 11:28 Go to previous messageGo to next message
Hi Michael,
As a workaround i've overriden the
ListCompartmentEditPart.refreshVisibility method:
protected void refreshVisibility() {
final View notationView = getNotationView();
final boolean hasChildren = notationView .getChildren().size() > 0;
setVisibility(hasChildren);
This just changes the visibility of the edit part and not of the view.
But when i changed the view visibility i got some transaction related
exceptions! Perhaps someone has a better solution?
You also have to call this method if a children is added or removed,
this can be done by overriding the notifyChanged method of your
comparment edit part.
Matthias
Michael Haeberlen wrote:
> Hello,
> Michael
Re: workaround for bug #147855 (hide compartment if empty) - any hints? [message #15963 is a reply to message #15898] Fri, 11 August 2006 12:56 Go to previous messageGo to next message
Hi ;
Few points to consider:
1- the fact that you got an exception while setting the view visibility,
means that there is no write transaction open
here is a quick sample that shows how to do it :
final View view = getNotationView();
final SetPropertyCommand cmd = new SetPropertyCommand(getEditingDomain(),
new EObjectAdapter(view),
PackageUtil.getID(NotationPackage.eINSTANCE.getView_Visible( )),
DiagramUIMessages.Command_hideLabel_Label,
Boolean.valueOf(view.getChildren().size()>0));
Map options = null;
options =
Collections.singletonMap(Transaction.OPTION_UNPROTECTED,
Boolean.TRUE);
AbstractEMFOperation operation = new AbstractEMFOperation(
getEditingDomain(),
StringStatics.BLANK, options) {
protected IStatus doExecute(IProgressMonitor monitor,
IAdaptable info)
throws ExecutionException {
cmd.execute(null,null);
return Status.OK_STATUS;
try {
operation.execute(new NullProgressMonitor(), null);
} catch (ExecutionException e) {
int i = 0 ;
i++;
2- you have to be careful about setting the view visibility to False,
because as soon as you set it to false the edit part till be removed
completely. This means you will not be able to use the tool to create
the children any more, and you have to provide a different way to do that
Matthias Köster wrote:
> Hi Michael,
> Matthias
>> Hello,
>> Michael
Re: workaround for bug #147855 (hide compartment if empty) - any hints? [message #17015 is a reply to message #15963] Mon, 14 August 2006 03:45 Go to previous messageGo to next message
Hi Mohammed,
So that means it's better to stick with my solution of just hiding the
edit part? Or is it better to hide the view too?
Matthias
Mohammed Mostafa wrote:
> Hi ;
> Map options = null;
> options =
> Boolean.TRUE);
> getEditingDomain(),
> IAdaptable info)
> try {
> int i = 0 ;
> i++;
>> Hi Michael,
>> setVisibility(hasChildren); }
>> Matthias
>>> Hello,
>>> Michael
Re: workaround for bug #147855 (hide compartment if empty) - any hints? [message #17275 is a reply to message #17015] Mon, 14 August 2006 10:09 Go to previous message
Hi Matthias,
setting the visibility on the figure Vs the view depends on your use case.
Setting the view visibility to false is better from the memory
consumption point of view but it require providing a way for creating
elements inside the invisible compartments.
I'd say if memory consumption is a concern (i mean if your diagrams are
big and contain lots of elements on them) then setting the visibility on
the view is better otherwise setting it on the figure will be OK.
> Hi Mohammed,
> Matthias
>> Hi ;
>> visibility, means that there is no write transaction open
>> Map options = null;
>> options =
>> Boolean.TRUE);
>> getEditingDomain(),
>> IAdaptable info)
>> try {
>> int i = 0 ;
>> i++;
>>> Hi Michael,
>>> view. But when i changed the view visibility i got some transaction
>>> related exceptions! Perhaps someone has a better solution?
>>> Matthias
>>>> Hello,
>>>> Michael
Previous Topic:Problem with Validate Menu Option
Next Topic:List of items based on internal list?
Current Time: Mon Jul 07 14:08:54 EDT 2025
Powered by FUDForum. Page generated in 0.12563 seconds
