Home » Eclipse Projects » Subversive » CPU hogging
CPU hogging [message #9757] Thu, 18 October 2007 05:53 Go to next message
Originally posted by: joerg.von.frantzius.artnology.com
<html>
<head>
</head>
Hi,<br>
<br>
I just noticed my CPU peaking due to my Eclipse Java process, and on
taking several thread dumps I always found this one:<br>
<blockquote><tt>"Worker-78" prio=10 tid=0x00002aaaf49a1400 nid=0x28f3
runnable [0x0000000041038000..0x0000000041038d90]</tt><br>
<tt>   java.lang.Thread.State: RUNNABLE</tt><br>
<tt>        at
java.util.regex.Pattern$BmpCharProperty.match(Pattern.java:3 366) </tt><br>
<tt>        at java.util.regex.Pattern$Curly.match(Pattern.java:3737)</tt> <br>
<tt>        at java.util.regex.Pattern$Curly.match0(Pattern.java:3782)</tt ><br>
<tt>        at java.util.regex.Pattern$Curly.match(Pattern.java:3744)</tt> <br>
<tt>        at java.util.regex.Pattern$Start.match(Pattern.java:3055)</tt> <br>
<tt>        at java.util.regex.Matcher.search(Matcher.java:1105)</tt><br>
<tt>        at java.util.regex.Matcher.find(Matcher.java:561)</tt><br>
<tt>        at
org.polarion.team.svn.ui.console.LocalPathMatcher$AddConsole HyperlinkOperation.runImpl(LocalPathMatcher.java:141) </tt><br>
<tt>        at
org.polarion.team.svn.core.operation.AbstractActionOperation .run(AbstractActionOperation.java:70) </tt><br>
<tt>        at
org.polarion.team.svn.core.operation.LoggedOperation.run(Log gedOperation.java:38) </tt><br>
<tt>        at
org.polarion.team.svn.core.utility.ProgressMonitorUtility.do Task(ProgressMonitorUtility.java:105) </tt><br>
<tt>        at
org.polarion.team.svn.core.utility.ProgressMonitorUtility.do TaskExternal(ProgressMonitorUtility.java:91) </tt><br>
<tt>        at
org.polarion.team.svn.ui.utility.DefaultCancellableOperation Wrapper.run(DefaultCancellableOperationWrapper.java:55) </tt><br>
<tt>        at
org.polarion.team.svn.ui.utility.UIMonitorUtility$2.run(UIMo nitorUtility.java:171) </tt><br>
<tt>        at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:49) </tt><br>
<tt>        at
org.polarion.team.svn.ui.utility.UIMonitorUtility.doTaskBusy (UIMonitorUtility.java:168) </tt><br>
<tt>        at
org.polarion.team.svn.ui.utility.UIMonitorUtility.doTaskBusy Default(UIMonitorUtility.java:159) </tt><br>
<tt>        at
org.polarion.team.svn.ui.console.LocalPathMatcher.matchFound (LocalPathMatcher.java:114) </tt><br>
<tt>        at
org.eclipse.ui.internal.console.PatternMatchListener.matchFo und(PatternMatchListener.java:47) </tt><br>
<tt>        at
org.eclipse.ui.internal.console.ConsolePatternMatcher$MatchJ ob.run(ConsolePatternMatcher.java:129) </tt><br>
<tt>        at
org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)</tt ><br>
</blockquote>
I have no clue what it's doing, as there is no SVN operation going on.
When I enable "Show system operations" in the Progress View, I can see
three active jobs: "System: Flush Cache Job", "System: Match Job" and
"System: Task List Saver".<br>
<br>
Restarting Eclipse fortunately resolves this.<br>
<br>
Regards,<br>
Jörg<br>
</body>
</html>
Re: CPU hogging [message #9915 is a reply to message #9757] Tue, 30 October 2007 07:57 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Dear Jörg,
Thank you for reporting the issue. You can track state of your report with
Eclipse Bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=207953
Previous Topic:How do I obtain working copy information?
Next Topic:Subversive / Subclipse Plugin - Pre-commit actions
Current Time: Thu Sep 18 11:10:52 EDT 2025
Powered by FUDForum. Page generated in 0.06418 seconds
