Home » Eclipse Projects » GEF » Order of entries in property sheet
| Order of entries in property sheet [message #107307] |
Thu, 27 November 2003 23:32  |
Originally posted by: PeterMayne.ap.spherion.com
I have an IPropertySource with "Width" and "Height" properties.
Unfortunately, they display in the property sheet in the order "Height",
"Width", rather than my preferred logical order of "Width", "Height".
A quick trek through the code leads me to believe that properties are
displayed in the current locale's sort order, rather than (say) the
order in which I put them in my IPropertyDescriptor[].
Probably a hopeless question, but can I ensure that my properties are
displayed in an order I insist on (say, the order in which I put them in
my IPropertyDescriptor[]), rather than having them arbitrarily sorted?
Thanks.
PJDM
Peter Mayne
Spherion Technology Solutions
Canberra, ACT, Australia
"Dude, where's my IDE?"
| Re: Order of entries in property sheet [message #107319 is a reply to message #107307] |
Fri, 28 November 2003 00:25   |
Originally posted by: brian.fernandes.codito.com
Hi Peter,
This bug addresses the issue. Indeed, its quite a pain that the property
sheet entries are sorted ... Oh, well.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=1883
Brian.
"Peter Mayne" <PeterMayne@ap.spherion.com> wrote in message
news:bq6j0r$siq$1@eclipse.org...
> Thanks.
> PJDM
> Peter Mayne
| Re: Order of entries in property sheet [message #107459 is a reply to message #107307] |
Mon, 01 December 2003 00:19   |
Check Bug 44800 too.
> Thanks.
> PJDM
> Peter Mayne
| Re: Order of entries in property sheet [message #107697 is a reply to message #107459] |
Tue, 02 December 2003 14:47   |
See http://www.javadude.com/eclipse/ for an example of ordering them
yourself. Not super pretty, but a simple way to fix it...
-- Scott
In article <bqeiq7$4sn$1@eclipse.org>, anotherneatguy@yahoo.com says...
> > Thanks.
> > PJDM
> > Peter Mayne
| Re: Order of entries in property sheet [message #107961 is a reply to message #107947] |
Thu, 04 December 2003 10:14  |
Gotcha -- definitely, the prefix wouldn't be translated.
Of course this is a hack... It would be better to come up with a cleaner
way to do this (such as explicit ordering, perhaps just an option that
allows the sort call to be turned off). I implemented this hack based on
what I could override easily.
- Scott
In article <bqni2b$gaa$1@eclipse.org>, none@us.ibm.com says...
> Meaning when you do i18n on your program, and your !Kung translator goes to
> translate "a1:height", it might be confusing.
> But, you could avoid this by not externalizing the prefix, and adding it
> programmatically at the time when you parse your properties file.
> Thanks for the suggestion!
Current Time: Thu Nov 06 02:57:06 EST 2025
Powered by FUDForum. Page generated in 0.07105 seconds
