Home » Newcomers » Newcomers » Eclipse on Linux
Eclipse on Linux [message #9722] Thu, 20 January 2005 06:31 Go to next message
Originally posted by: tognac.aliceposta.it
I'm trying to use eclipse on Fedora Core 3 under KDE 3.2.
i've downloaded eclipse GTK version, i've unzipeed it and moved the
unzipped files in a /usr/eclipse folder.
When i launch "./eclipse" or "./eclipse -ws gtk" also (reading that on a
mail on this site) it returns an error and a #.log file.
any help greatly appreciated.
Thanks.
The log file:
!SESSION 2005-01-20 09:58:15.313
eclipse.buildId=I20041216-2000
java.fullversion=GNU libgcj 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 2005-01-20 09:58:15.314
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: while resolving class:
org.eclipse.core.runtime.adaptor.EclipseAdaptor
at java.lang.VMClassLoader.resolveClass(java.lang.Class)
(/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.initializeClass() (/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.forName(java.lang.String, boolean,
java.lang.ClassLoader) (/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.forName(java.lang.String) (/usr/lib/libgcj.so.5.0.0)
at org.eclipse.core.runtime.adaptor.EclipseStarter.createAdapto r()
(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(java .lang.String[],
java.lang.Runnable) (Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[],
at _Jv_CallAnyMethodA(java.lang.Object, java.lang.Class, _Jv_Method,
boolean, boolean, java.lang.Class[], jvalue, jvalue, boolean)
boolean, java.lang.Class[], java.lang.Object[]) (/usr/lib/libgcj.so.5.0.0)
at java.lang.reflect.Method.invoke(java.lang.Object,
at org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.main(java.lang.String[]) (Unknown
Source)
Caused by: java.lang.ClassNotFoundException:
org.xml.sax.helpers.DefaultHandler not found in
[file:/usr/eclipse/plugins/org.eclipse.osgi_3.1.0/core.jar,
file:/usr/eclipse/plugins/org.eclipse.osgi_3.1.0/console.jar ,
file:/usr/eclipse/plugins/org.eclipse.osgi_3.1.0/osgi.jar,
file:/usr/eclipse/plugins/org.eclipse.osgi_3.1.0/resolver.ja r,
file:/usr/eclipse/plugins/org.eclipse.osgi_3.1.0/defaultAdap tor.jar,
file:/usr/eclipse/plugins/org.eclipse.osgi_3.1.0/eclipseAdap tor.jar]
at java.net.URLClassLoader.findClass(java.lang.String)
at java.lang.ClassLoader.loadClass(java.lang.String, boolean)
at _Jv_FindClass(_Jv_Utf8Const, java.lang.ClassLoader)
at _Jv_ClassReader.handleClassBegin(int, int, int)
at _Jv_ClassReader.parse() (/usr/lib/libgcj.so.5.0.0)
at _Jv_DefineClass(java.lang.Class, byte[], int, int)
at java.lang.VMClassLoader.defineClass(java.lang.ClassLoader,
java.lang.String, byte[], int, int, java.security.ProtectionDomain)
at java.lang.ClassLoader.defineClass(java.lang.String, byte[], int,
int, java.security.ProtectionDomain) (/usr/lib/libgcj.so.5.0.0)
at java.security.SecureClassLoader.defineClass(java.lang.String ,
byte[], int, int, java.security.CodeSource) (/usr/lib/libgcj.so.5.0.0)
at _Jv_PrepareCompiledClass(java.lang.Class) (/usr/lib/libgcj.so.5.0.0)
at _Jv_WaitForState(java.lang.Class, int) (/usr/lib/libgcj.so.5.0.0)
at java.lang.VMClassLoader.linkClass0(java.lang.Class)
...12 more
!SESSION Thu Jan 20 09:58:15 GMT-01:00 2005
!ENTRY org.eclipse.core.launcher 4 0 Jan 20, 2005 09:58:15.695
!MESSAGE Exception launching the Eclipse Platform:
!STACK
Source)
Source)
at gnu.gcj.runtime.FirstThread.call_main() (/usr/lib/libgcj.so.5.0.0)
at gnu.gcj.runtime.FirstThread.run() (/usr/lib/libgcj.so.5.0.0)
at _Jv_ThreadRun(java.lang.Thread) (/usr/lib/libgcj.so.5.0.0)
at _Jv_RunMain(java.lang.Class, byte const, int, byte const, boolean)
at __libc_start_main (/lib/tls/libc-2.3.3.so)
Re: Eclipse on Linux [message #9800 is a reply to message #9722] Thu, 20 January 2005 08:19 Go to previous messageGo to next message
Antonio,
note that FC 3's default java executable is a GCJ placeholder, which
won't work for eclipse. You should be running one of the supported vms,
for example the 1.4.2_06 reference implementation. See
http://download.eclipse.org/downloads/drops/S-3.1M4-20041216 2000/java-runtimes.html
-tom
Antonio wrote:
> I'm trying to use eclipse on Fedora Core 3 under KDE 3.2. i've
> downloaded eclipse GTK version, i've unzipeed it and moved the unzipped
> a mail on this site) it returns an error and a #.log file.
> Thanks.
> The log file:
> !STACK 1
> (Unknown Source)
> at
> at
> (Unknown Source)
> Source)
> Source)
> ...12 more
> !STACK
> java.lang.NullPointerException
> at
> (Unknown Source)
> Source)
Re: Eclipse on Linux [message #9916 is a reply to message #9800] Thu, 20 January 2005 10:23 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
I'm using FC3 also, so I downloaded and installed the latest JRE from
java.sun.com, and replaced the /usr/bin/java symlink with a symlink to
/usr/java/j2re1.4.2_06/bin/java
Eclipse works like a charm.
Denis
Tom Eicher wrote:
> Antonio,
> -tom
> Antonio wrote:
>> on a mail on this site) it returns an error and a #.log file.
>> Thanks.
>> The log file:
>> !STACK 1
>> (Unknown Source)
>> at
>> at
>> (Unknown Source)
>> Source)
>> Source)
>> ...12 more
>> !STACK
>> at
>> (Unknown Source)
>> Source)
>> boolean) (/usr/lib/libgcj.so.5.0.0)
Previous Topic:drag and drop text
Next Topic:Server Startup Error using Lomboz w/Eclipse Tomcat 5
Current Time: Thu Nov 13 09:31:20 EST 2025
Powered by FUDForum. Page generated in 0.10630 seconds
