Home » Language IDEs » C / C++ IDE (CDT) » Are the builds still good?
Are the builds still good? [message #107018] Mon, 21 June 2004 10:28 Go to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
The CDT download page lists hundreds of unit test failures on the latest
CDT2.0 stream. Do these indicate a problem in the code or the tests?
Ed
Re: Are the builds still good? [message #107032 is a reply to message #107018] Mon, 21 June 2004 14:51 Go to previous messageGo to next message
Originally posted by: ddaoust.ca.ibm.com
The failures are with the test environment on the build machine. The builds
are still good.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=67804
Note, the update site for the nightly builds is not functioning correctly.
You should use the zip files directly
- Dave
"Ed Burnette" <ed.burnette@REMOVE.THIS.sas.com> wrote in message
news:cb6r97$hu2$1@eclipse.org...
> Ed
Re: Are the builds still good? [message #107552 is a reply to message #107032] Fri, 25 June 2004 12:57 Go to previous message
> are still good.
Well, but even downloading the zip-files is very slow. Most time it gets
down to 3..4kB/s, but I'm on a 2Mbit line.
Also, it would be nice, if someone could strip down the download site,
showing only the e.g. last ten daily builds. I don't think someone still
will download daily builds before e.g 2.0M9.
> - Dave
>>Ed
Previous Topic:CDT 2.0 M9 - C/C++ Make Project tab
Next Topic:CDT2.0M9/Eclise3.0RC1: Standard Make C++ Project doesn't save Project Properties
Current Time: Sat Nov 08 20:37:31 EST 2025
Powered by FUDForum. Page generated in 0.03603 seconds
