Ganymede Plug-In Exports don't work in Linux [message #9695] |
Tue, 01 July 2008 19:01  |
Originally posted by: richardepsilonhughes.gmail.com
So, I'm unable to get the Ganymede Plug-in Development Environment to
successfully export a plug-in project - even very basic ones, like the
multi-page XML editor that's produced by the plug-in wizard. It gives me
an IllegalArgumentException while attempting to build it. Even though
Ganymede can run the plug-in as an Eclipse application successfully, it
cannot export it to a deliverable plug-in .jar.
I only have this problem with Ganymede, on Linux. On Windows or Mac OS X,
Ganymede exports plug-ins just fine. Likewise, Europe exports them on
Linux. It's only Ganymede on Linux that presents the problem.
...I don't actually have a specific complaint beyond this. I'm just going
back to Europe for my compiling. I was just wondering if anyone else was
experiencing a similar issue and if they've repaired it somehow.
Re: Ganymede Plug-In Exports don't work in Linux [message #12696 is a reply to message #12676] |
Thu, 17 July 2008 09:15  |
Originally posted by: Marcus.Ilgner.gmail.com
FYI: I just made some changes to my target platform and after that, did a
"Clean & Rebuild All" and suddenly Ant is working fine again.
I have no clue what the problem might have been but maybe it helps someone.
Best regards
Marcus
Re: Ganymede Plug-In Exports don't work in Linux [message #571370 is a reply to message #9695] |
Tue, 01 July 2008 20:29  |
Can you post the full stacktrace here?
~ Chris
Re: Ganymede Plug-In Exports don't work in Linux [message #571624 is a reply to message #10310] |
Thu, 03 July 2008 15:44  |
Never mind, figured it out.
FIRST 'BUILD FAILED'
Exception Stack Trace:
java.lang.IllegalArgumentException
at java.net.URI.create(Unknown Source)
at org.apache.tools.ant.launch.Locator.fromURI(Locator.java:162 )
at org.apache.tools.ant.launch.Locator.getResourceSource(Locato r.java:119)
at org.apache.tools.ant.launch.Locator.getClassSource(Locator.j ava:90)
at org.apache.tools.ant.Project.setAntLib(Project.java:313)
at org.apache.tools.ant.Project.initProperties(Project.java:309 )
at org.apache.tools.ant.Project.init(Project.java:295)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:520)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:456)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
org.eclipse.pde.internal.core.exports.FeatureExportOperation .runScript(FeatureExportOperation.java:355)
org.eclipse.pde.internal.core.exports.FeatureExportOperation .doExport(FeatureExportOperation.java:236)
org.eclipse.pde.internal.core.exports.FeatureBasedExportOper ation.run(FeatureBasedExportOperation.java:46)
org.eclipse.pde.internal.ui.build.FeatureExportJob.run(Featu reExportJob.java:55)
Caused by: java.net.URISyntaxException: Illegal character in path at index
35: file:/home/rhughes/Desktop/Ganymede
Eclipse/plugins/org.apache.ant_1.7.0.v200803061910/lib/ant.j ar
at java.net.URI$Parser.fail(Unknown Source)
at java.net.URI$Parser.checkChars(Unknown Source)
at java.net.URI$Parser.parseHierarchical(Unknown Source)
at java.net.URI$Parser.parse(Unknown Source)
at java.net.URI.<init>(Unknown Source)
... 23 more
Session Data:
eclipse.buildId=I20080617-2000
java.version=1.6.0_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
SECOND 'BUILD FAILED'
org.eclipse.pde.internal.core.exports.FeatureExportOperation .cleanup(FeatureExportOperation.java:633)
org.eclipse.pde.internal.core.exports.FeatureBasedExportOper ation.run(FeatureBasedExportOperation.java:55)
... 22 more
Session Data:
Re: Ganymede Plug-In Exports don't work in Linux [message #573189 is a reply to message #12637] |
Wed, 16 July 2008 10:51  |
> I don't have one, actually. I have two computers - for me, it works on Mac
> OS X, but not Linux, so I just export the plugin to a .zip, sneakernet it
> to my Mac, import it as a project there, then export it as a plugin.
Thanks for the quick reply. Looks like some serious bug to me. If I do a
right-click on build.xml and choose "Run As -> Ant Build" it's working
fine.
But running it during the normal build process, it comes up with an error.
I'll check the bugtracker for the problem.
Best regards
Marcus
FUDForum. Page generated in 0.05881 seconds
