Home » Archived » Visual Editor (VE) » VE only shows ContentPane
VE only shows ContentPane [message #106853] Fri, 16 September 2005 20:28 Go to next message
The visual editor appears to be functional, but it is only showing the
JFrame. All the components that are assigned to the JFrame's contentPane do
not appear. This occured after I reverted back to a previous eclipse
configuration because the JBoss Workflow IDE doesn't get along with
MyEclipse. That is a long story.
When I put the mouse over the displayed JFrame, I get a message (I wish it
would stay up). The message is:
contentPane:java.lang.IllegalArgumentException(IWAV0167E access by method
name(getContentPane) (not by Proxy) requires a receiver.)
I don't think I ever saw this message before, so I assume it is telling what
the problem is. The GUI compiles and runs. I just can't get the VE editor
back. Can someone suggest how I might get the visual editor of this JFrame
back?
Bud Curtis
Colorado Springs, CO
Re: VE only shows ContentPane [message #106928 is a reply to message #106853] Sat, 17 September 2005 10:39 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Try it in a config with only Eclipse SDK 3.1, VE 1.1.0.1, EMF 2.1, and
GEF 3.1. MyEclipse is often different levels of these projects and
causes conflicts.
> back?
Rich Kulp
Re: VE only shows ContentPane [message #106953 is a reply to message #106928] Sat, 17 September 2005 10:54 Go to previous messageGo to next message
Is there a way to have multiple configurations for Eclipse, or do I need
separate (eclipse root) folders for each configuration?
Bud Curtis
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:dgh9qc$fpu$1@news.eclipse.org...
> causes conflicts.
contentPane do
it
method
what
editor
JFrame
> > back?
> Rich Kulp
Re: VE only shows ContentPane [message #106967 is a reply to message #106953] Sat, 17 September 2005 12:21 Go to previous messageGo to next message
AS far as I know you need separate roots. There are probably some
complex way of doing it, but I myself have at least five different
configurations for my work.
Rich Kulp
Re: VE only shows ContentPane [message #107076 is a reply to message #106967] Sun, 18 September 2005 16:10 Go to previous messageGo to next message
I created an eclipse with just the Visual Editor and the Maven IDE. This
was working fine. I tried the same project and got the exact same error.
Is there anyway to interpret the error. The Initialize code is elementary:
private void initialize() {
this.setSize(516, 395);
this.setName("jarSearchFrame");
this.setDefaultCloseOperation(javax.swing.JFrame.EXIT_ON_CLO SE);
this.setContentPane(getJContentPane());
this.setTitle("Archive Searcher");
this.addWindowListener(new java.awt.event.WindowAdapter()
public void windowClosing(java.awt.event.WindowEvent
evt)
exitForm(evt);
* This method initializes jContentPane
* @return javax.swing.JPanel
private JPanel getJContentPane() {
if (jContentPane == null) {
jContentPane = new JPanel();
jContentPane.setLayout(new BorderLayout());
jContentPane.add(getStatusPanel(), java.awt.BorderLayout.SOUTH);
jContentPane.add(getSplitPane(), java.awt.BorderLayout.CENTER);
return jContentPane;
When I run the program I get the expected JFrame with all the components
showing.
Bud Curtis
news:dghfqb$lg3$1@news.eclipse.org...
> Rich Kulp
Re: VE only shows ContentPane [message #107147 is a reply to message #107076] Mon, 19 September 2005 10:02 Go to previous messageGo to next message
What is Maven? Could you try just Eclipse 3.1 SDK, GEF 3.1, and EMF 2.1?
> evt)
> exitForm(evt);
> showing.
Rich Kulp
Re: VE only shows ContentPane [message #107288 is a reply to message #107147] Mon, 19 September 2005 23:32 Go to previous messageGo to next message
I reinstalled with just Eclipse 3.1 SDK, GEF 3.1, and EMF 2.1. The same
problem persists.
Bud Curtis
news:dgmgdb$bq1$2@news.eclipse.org...
This
error.
elementary:
> > evt)
> > exitForm(evt);
> > showing.
> Rich Kulp
Re: VE only shows ContentPane [message #107410 is a reply to message #107147] Mon, 19 September 2005 23:42 Go to previous messageGo to next message
I got it to work by deleting the project from Eclipse, and then importing
the project back into Eclipse. There must be something in the workspace
that needed to be reset before it would interpret the code. Any ideas?
Bud Curtis
This
error.
elementary:
> > evt)
> > exitForm(evt);
> > showing.
> Rich Kulp
Re: VE only shows ContentPane [message #107551 is a reply to message #107410] Tue, 20 September 2005 10:38 Go to previous message
Sorry, no ideas.
Rich Kulp
Re: VE only shows ContentPane [message #610788 is a reply to message #106853] Sat, 17 September 2005 10:39 Go to previous message
causes conflicts.
> back?
Rich Kulp
Re: VE only shows ContentPane [message #610790 is a reply to message #106928] Sat, 17 September 2005 10:54 Go to previous message
Bud Curtis
> causes conflicts.
contentPane do
it
method
what
editor
JFrame
> > back?
> Rich Kulp
Re: VE only shows ContentPane [message #610791 is a reply to message #106953] Sat, 17 September 2005 12:21 Go to previous message
Rich Kulp
Re: VE only shows ContentPane [message #610799 is a reply to message #106967] Sun, 18 September 2005 16:10 Go to previous message
evt)
exitForm(evt);
showing.
Bud Curtis
> Rich Kulp
Re: VE only shows ContentPane [message #610804 is a reply to message #107076] Mon, 19 September 2005 10:02 Go to previous message
> evt)
> exitForm(evt);
> showing.
Rich Kulp
Re: VE only shows ContentPane [message #610815 is a reply to message #107147] Mon, 19 September 2005 23:32 Go to previous message
problem persists.
Bud Curtis
This
error.
elementary:
> > evt)
> > exitForm(evt);
> > showing.
> Rich Kulp
Re: VE only shows ContentPane [message #610816 is a reply to message #107147] Mon, 19 September 2005 23:42 Go to previous message
Bud Curtis
This
error.
elementary:
> > evt)
> > exitForm(evt);
> > showing.
> Rich Kulp
Re: VE only shows ContentPane [message #610826 is a reply to message #107410] Tue, 20 September 2005 10:38 Go to previous message
Sorry, no ideas.
Rich Kulp
Previous Topic:Create my own dialog
Next Topic:Creating Wizard Pages using VE (Newbie)
Current Time: Sat Jul 19 14:07:38 EDT 2025
Powered by FUDForum. Page generated in 0.09616 seconds
