| [ANN] oXygen XML Editor 7.2 [message #9655] |
Fri, 09 June 2006 05:12 |
Originally posted by: george.oxygenxml.com
I am glad to announce that a new release of <oXygen/> XML Editor is
available from
http://www.oxygenxml.com
Version 7.2 of the <oXygen/> XML Editor adds as main features an XML
Schema instance generator, integration with the X-Hive/DB, MarkLogic and
TigerLogic XML databases, editing actions on the diagram and search
references/declarations actions in XML Schema and Relax NG schemata editors.
A summary of the new features can be found below, more details please visit
http://www.oxygenxml.com/index.html#new-version
New in <oXygen/> XML Editor 7.2
Schema Support:
* XML Schema Instance Generator
* XML Schema Regular Expressions Builder
* Flatten an XML Schema
* Rename Component - Schema Refactoring Action
* Find References and Declarations of XML Schema Components
* Show the Diagram of the Selected Schema Component
* Editing Actions on XML Schema and Relax NG Schema Diagrams
* Show Definition Action for elements in XML Documents
* The Content Completion on XML Schema Presents Schematron Information
* Default Schema Association Supports NRL
* Content Completion Based on NRL Schemata
XSLT Refactoring:
* Extract Attribute as xsl:attribute Instruction
XQuery Editor:
* XQuery Documentation
* X-Hive/DB XML Database Support
* MarkLogic XML Database Support
* TigerLogic XML Database Support
* Improvements in XQuery Content Completion
HTML Documentation For XML Schema:
* Clickable Images
* Easier Navigation Between Schema Definitions
* CSS File
* Include Annotations of Local Elements and Attributes
XSLT/XQuery Transformations:
* Configurable Extensions for Each Transformation
* Support for XSLT and XQuery Custom Engines
* XSLT validation using Microsoft Transformers (MSXML 4.0 and .NET)
Other:
* HTML Documentation for WSDL Files
* Pretty Print Option for Preserving Text Nodes
* XPath Expressions Allowed in Pretty Print Lists of Elements
* Use XML Catalogs When Evaluating XPath Expressions
* Allow Both Show Filters and Hide Filters in the Project View
* Scratch Buffer
* Policy for Encoding Errors
* UTF-8 Encoding for Connections with the FTP Server
* Search Filter in the Preferences Dialog
* Dynamic Help View
* Configurable Background Color for Each Type of Token
Component Updates:
* Updated Saxon8B from Saxonica to version 8.7.1
* Included XHTML 1.1 DTD and XML Schema
* Updated DocBook XSL stylesheets to version 1.70.1
Best Regards,
George
George Cristian Bina
<oXygen/> XML Editor, Schema Editor and XSLT Editor/Debugger
FUDForum. Page generated in 0.07870 seconds
