| Plugin.xml changes not recognized [message #106578] |
Thu, 17 June 2004 10:14 |
Originally posted by: ramanand_mandayam.yahoo.com
Hello
I am trying a simple experiment wherein I am trying to get the managed
build to use the gcc compiler as the tool for compiling files with a ".s"
extension. I tried modifying the GNU compiler extension by setting
the value of the sources attribute to "c,s" from the original "c".
I then rebuilt and regenerated the jar file for that plugin and
named it identically as the original jar file "mgdbuildui.jar".
I copied over this newly generated jar file and the updated plugin.xml
file to the "plugins" folder under my eclipse installation.
When I launch eclipse I am expecting it to read the new plugin.xml
and take it from there. When I look at the plugin-registry however,
the extension still shows the value of the sources attribute as "c".
No matter what I do I am unable to get Eclipse/CDT to see the value "c,s".
To make matters worse, this seems to work fine when I am using
Run -> Run as runtime workbench. Therefore I am not sure how to even
proceed ahead with the debug.
I am using Eclipse 3.0RC2 and CDT SDK 2.0M9 (0529).
Thanks for any help...
Cheers
Ramanand
FUDForum. Page generated in 0.02210 seconds
