Home » Archived » M2M (model-to-model transformation) » [QVTO] QvtRuntimeException when running by program
[QVTO] QvtRuntimeException when running by program [message #106442] |
Wed, 10 June 2009 03:55  |
I need to call qvto transformations by program in my own plugin.
I am using this code :
QvtInterpretedTransformation transformation =
new QvtInterpretedTransformation(TransformationUtil.getQvtModule (uri));
List<EObject> inObjects = new ArrayList<EObject>();
for ((Map.Entry<InPort, EObject> entry : inputs.entrySet())
inObjects.add(entry.getValue());
TransformationRunner.In input =
new TransformationRunner.In(inObjects.toArray(new EObject[inObjects.size
()]), new Context());
TransformationRunner.Out output = transformation.run(input);
This code works for almost all of my qvto transformations, only one has
trouble.
When I am launching it via Eclipse 'run as' it works, when I am launching
it via my above code I am getting :
org.eclipse.m2m.internal.qvt.oml.evaluator.QvtRuntimeExcepti on:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to
java.lang.Integer
The incriminate qvt line code is like that :
vectorElem := Sequence{1 .. partshape.shapes->size()}->collect (0);
where 'partshape.shapes' is a references collection.
Any idea why this is working with the 'normal' qvto launcher but not with
code ?
Many thanks in advance,
regards
Re: [QVTO] QvtRuntimeException when running by program [message #106456 is a reply to message #106442] |
Wed, 10 June 2009 05:57   |
Hi Alexis,
The actual cause is in how MDT OCL handles invalid values in the last
expression
of a collection range.
In your case, "partshape.shapes->size()" results in invalid
value (of OclInvalid type) because 'partshape' is for some reason null or
invalid.
As I can see the MDT OCL impl, it always casts the range last value to
Integer,
in this case causing "java.lang.ClassCastException:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl"
and should definitely be more tolerant.
You can reproduce the same in a plain OCL like this: Sequence {
1..(1/0).round() }.
Sure you need your transf to continue so you can handle this in your code
explicitly.
As for the difference in launch using Eclipse configuration or Java, I
can't reproduce
this and assume there must be a difference. Perhaps another input model,
configuration properties that might affect the execution flow?
If not, we have something to correct ;)
I can see you use some internals, I would recommend looking at
'org.eclipse.m2m.qvt.oml.TransformationExecutor', in case you do not need
anything special that is not exposed.
Check:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.qvt.oml/examples/org.eclipse.m2m.qvt.oml.econ20 09.tutorial/projects/qvto.ecore2uml.invoke/src/qvto/ecore2um l/invoke/ConvertEcore2UML.java?root=Modeling_Project&vie w=markup
/Radek
On Wed, 10 Jun 2009 09:55:21 +0200, Alexis Muller <Alexis.Muller@inria.fr>
wrote:
> Hello,
> trouble.
> java.lang.Integer
> code ?
> regards
Re: [QVTO] QvtRuntimeException when running by program [message #106484 is a reply to message #106456] |
Thu, 11 June 2009 05:36   |
Hi Radek,
Many thanks, I have solved my issue :)
On Wed, 10 Jun 2009 11:57:50 +0200, Radek Dvorak wrote:
> In your case, "partshape.shapes->size()" results in invalid value (of
> OclInvalid type) because 'partshape' is for some reason null or invalid.
> can't reproduce
Indeed, the input model was not *exactly* the same in both case.
> need anything special that is not exposed.
This Class is available with the new qvto plugin (2.0.0), but not with my
production version (1.0.1).
And, more important, TransformationExecutor is taking Resources as input/
output, I am using EObject.
Again, thanks for your help.
Alexis
Current Time: Sun Aug 31 14:20:47 EDT 2025
Powered by FUDForum. Page generated in 0.08182 seconds
