Home » Archived » Test and Performance Tools Platform (TPTP) » Launching problem
Launching problem [message #9629] Thu, 10 March 2005 18:48 Go to next message
Has anyone else had this problem?
I'm trying to profile an Eclipse Application, and am using Eclipse 3.1M5
with TPTP 3.2 on Linux.
Thanks in advance.
-Dan.
An internal error occurred during: "Launching".
java.lang.NoSuchMethodError:
org.eclipse.pde.internal.ui.launcher.LauncherUtils.createCon figArea(Ljava/lang/String;)Ljava/io/File;
org.eclipse.hyades.trace.ui.internal.launcher.ProfileRuntime WorkbenchDelegate.getConfigDir(ProfileRuntimeWorkbenchDelega te.java)
org.eclipse.hyades.trace.ui.internal.launcher.ProfileRuntime WorkbenchDelegate.launch(ProfileRuntimeWorkbenchDelegate.jav a)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:795)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:993)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:67)
Re: Launching problem [message #9651 is a reply to message #9629] Thu, 10 March 2005 19:32 Go to previous message
Originally posted by: pierre.penguin.none
Hi Dan,
I think 3.2 requires using Eclipse 3.0.1.
If you are using 3.1M5 I think you should use TPTP 4.0 development
stream. You can find it there:
http://eclipse.org/tptp/home/downloads/downloads.html
Pierre-Alexandre
> Thanks in advance.
> Cheers,
> -Dan.
> at
> at
> at
> at
> at
> at
Previous Topic:gla adapter
Next Topic:Profiling with BEA weblogic
Current Time: Mon Jul 14 19:26:46 EDT 2025
Powered by FUDForum. Page generated in 0.02747 seconds
