Home » Eclipse Projects » Equinox » reuse of pre-compiled jsp's
reuse of pre-compiled jsp's [message #105849] Tue, 04 March 2008 08:22 Go to next message
is there any way to change the deployment configuration for the framework
launcher (server side), so that temporary created context directories
(used for compiled jsp's -> "proxytemp/hc_<hashcode of httpcontext>") are
NOT deleted on startup/shutdown. The problem is, that whenever my web
container (Tomcat) gets restarted - could also be a VM crash in connection
with a watchdog - all pre-compiled jsp's are removed by the framework ->
performance issue!
It would be nice to change that behaviour of 'on-the-fly' jsp-compiling
(perhaps externally) - as I found out, the only way to avoid this, is to
change the implementation of 'ProxyContext' in bundle
'org.eclipse.equinox.http.servlet'!? What could be an alternative
solution, so that already compiled jsp's become reusable (Tomcat default
behaviour)?? Besides, I'm aware that these context directories are removed
in terms of changing dependencies between bundles, however in my
environment, there are no bundle structure manipulations or redeploys
while the web container is running!
thanks in advance,
-teos
Re: reuse of pre-compiled jsp's [message #105865 is a reply to message #105849] Tue, 04 March 2008 10:20 Go to previous message
Hi Teos,
For your situation I'd recommend that you precompile your jsps and place the
class files directly in a bundle.
You'd then register them like they were servlets and it should all work.
(sort of similar to the regular jsp precompilation deployment style in
legacy(!) webapps)
With a little work caching jsp comilations between framework restarts seems
doable in static cases as you describe but would require us to look at the
framework state to determine if anything has changed and if we should
trigger a recompile. I'm not currently looking at this but feel free to open
a bug and better still submit any ideas in patches.
-Simon
"teos" <sasa.teofanovic@gmx.at> wrote in message
news:81d67aafca609b8cbcda39db3fa2f4ad$1@www.eclipse.org...
> performance issue! It would be nice to change that behaviour of
> 'on-the-fly' jsp-compiling (perhaps externally) - as I found out, the only
> way to avoid this, is to change the implementation of 'ProxyContext' in
> bundle 'org.eclipse.equinox.http.servlet'!? What could be an alternative
> thanks in advance,
> -teos
Previous Topic:Bundle-NativeCode problem
Next Topic:bundles on first startup are always started automatically!?
Current Time: Tue Nov 04 20:16:50 EST 2025
Powered by FUDForum. Page generated in 0.03592 seconds
