Home » Archived » Test and Performance Tools Platform (TPTP) » possibility to use Hyades/TPTP for testing Eclipse plug-ins?
possibility to use Hyades/TPTP for testing Eclipse plug-ins? [message #9579] Wed, 09 March 2005 12:17 Go to next message
Originally posted by: ssc.entimo.de
I’m evaluating hyades(3.2)/tptp and wonder if I can use it to test
eclipse plug-ins. I would like to have a combination of PDE-JUnit and
Hyades. After browsing through the documentation, I haven’t found any
hint that such function is already built in the framework. This brings
me to my questions:
(1) Is there such feature? Is such feature planed for next releases?
Does anyone know a practical way to test plug-in with hyades? Is there a
source for additional documentation or examples?
(2) If there is no one done this before, it seems to me that I have to
extend the tptp by building a custom test execution environment in a
similar way as described in the EclipseCon 2005 Tutorial for a Perl
execution environment. Would this be the best way or do you know one easier?
Stephan
Re: possibility to use Hyades/TPTP for testing Eclipse plug-ins? [message #9693 is a reply to message #9579] Fri, 11 March 2005 17:57 Go to previous messageGo to next message
Stephan Schroeder Wed, 09 Mar 2005 18:17:53 +0100
>> I'm evaluating hyades(3.2)/tptp and wonder if I can use it to test
>> eclipse plug-ins.
Test what/how? Function? Performance?
>> I would like to have a combination of PDE-JUnit and Hyades. After
>> browsing through the documentation, I haven't found any hint that
>> such function is already built in the framework. This brings me to
>> my questions:
Depending on your what/how, see
http://www.eclipse.org/tptp/home/project_info/featureplans/f eatures.php?source=All&project=All&release=4.0&f ile=TPTPFeatures_4.xml
and scroll way down to
> Bugzilla# Component Priority <snip> In Plan Summary
> --------- --------- -------- <snip> ------- -------
> 74791 Test.UI.JUnit P1 <snip> Committed Support for
JUnit derivative projects such as HTTP Unit, Cactus, Abbot, etc.
>> to extend the tptp by building a custom test execution environment
>> in a similar way as described in the EclipseCon 2005 Tutorial for a
>> Perl execution environment.
Could you send me a pointer to that? I was formerly a perl coder and
would love to see more eclipse perl tooling.
Re: possibility to use Hyades/TPTP for testing Eclipse plug-ins? [message #10312 is a reply to message #9693] Mon, 14 March 2005 04:10 Go to previous message
>>> eclipse plug-ins.
My focus is on functional testing.
>>> my questions:
Thanks, this seems to be the needed feature. But unfortunatly, if I
understand the relase plan right, I have to wait at least for milestone
4.0i4, which will come out somewhere in the summer...
See
http://www.eclipse.org/tptp/test/documents/tutorials/eclipse Con2005/EclipseCon2005_Tutorial6.pdf
for the presentation slides.
Previous Topic:Support for automated UI tests available?
Next Topic:Help with TPTP profiling concepts
Current Time: Wed Nov 05 22:12:40 EST 2025
Powered by FUDForum. Page generated in 0.07278 seconds
