Home » Eclipse Projects » Remote Application Platform (RAP) » Browser.execute() issue
Browser.execute() issue [message #105543] Thu, 18 September 2008 05:42 Go to next message
The Browser.execute() is not working for me. It always returns false and
no script is executed. I'm running Ubuntu with Firefox. I've noticed this
while porting our RCP application. But even the simplest scenario (
browser.execute("alert('Hello world')" call in RAP Workbench demo )
produces the same result.
Regards, Martin Schmied
Re: Browser.execute() issue [message #105557 is a reply to message #105543] Thu, 18 September 2008 08:09 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Martin,
here are a few ideas what you could investigate in order to narrow
the problem:
* try to run a different browser and see if it also fails
* are there any add-ons that might prevent the Javscript execution
* what version of RAP are you using?
* if working against RAP CVS HEAD, you could write
"this.debug( e );" in line 29 of Browser.js to see if
a Javascript error occurs
HTH
Rüdiger
Martin Schmied wrote:
> this while porting our RCP application. But even the simplest scenario (
Re: Browser.execute() issue [message #105597 is a reply to message #105543] Thu, 18 September 2008 11:44 Go to previous messageGo to next message
I also feel some problem with Browser widget. I was looking for a way to
refresh browser. I've tried to do it via execute("document.location =
document.location") and via setUrl method. Both methods are not stable,
so now I just dispose Browser and create new one and set old url.
Re: Browser.execute() issue [message #105624 is a reply to message #105557] Thu, 18 September 2008 16:21 Go to previous messageGo to next message
Hi Rüdiger,
thanks for responding. My original setup uses RAP 1.1 I've tried Firefox
and Opera with the same negative result. Then (already at my laptop
running Windows Vista) I switched to CVS bundles as you proposed, added
some JS debugging code and here's the result:
On Firefox and Opera the 'this.getContentWindow()' statement returns null
causing the subsequent evaluation to throw a NPE
On IE7 the context window is indeed returned, but "Permission denied"
exception is thrown from the evaluation.
One way or another, the Browser.execute() always fails.
Re: Browser.execute() issue [message #105640 is a reply to message #105624] Fri, 19 September 2008 02:42 Go to previous messageGo to next message
Hi Martin,
thanks for your investigation. When using the Browser widget please
bear in mind that it is represented by an IFRAME element on the
client-side. Therefore its general use is limited by implementation
details that vary on different browsers and security restrictions.
Plus user-specific security settings may restrict its features further.
It seems to be a bug that 'this.getContentWindow()' returns null.
Feel free to open a bugzilla if you have a code snippet to reproduce
the behavior.
The 'permission denied' exception, to me looks like a security
restriction that cannot be overcome, except maybe by altering the
client-side security settings.
Rüdiger
> Hi Rüdiger,
> null causing the subsequent evaluation to throw a NPE
Re: Browser.execute() issue [message #106010 is a reply to message #105640] Tue, 23 September 2008 11:18 Go to previous messageGo to next message
Hi Rudiger,
I've found that to reproduce the issue in RAP Workspace Demo you have to
call execute() right after (or close enough) an URL change - when the page
is still loading. The following code should do that:
browser.setUrl("http://times.com");
browser.execute("alert('hello world');")
This might be a browser issue you can do nothing about. However, in our
original application where I encountered the error for the first time,
there's no URL change directly preceding the execute() call. The page
loaded in browser contains UI of a streaming map application
(http://www.openstreetmap.org/). Every time the execute() call fails, it's
because this.getContentWindow() in Browser.js returns null.
Re: Browser.execute() issue [message #106094 is a reply to message #106010] Wed, 24 September 2008 03:16 Go to previous messageGo to next message
Hi Martin,
this seems to be a problem related to qooxdoo and its queuing
mechanisms. It certainly has nothing to do with the way setUrl() and
execute() are called.
When the client-side Browser object is created, its respective DOM
nodes (namely the IFRAME) aren't created immediately. All DOM
operations are queued and executed 'sometime' later. This is the
reason why getContentWindow() (returns the actual DOM node)
sometimes returns null.
It seems possible to work around this in RAP. Please file a Bugzilla
to track progress on this.
Rüdiger
Rüdiger Herrmann
Innoopract
http://innoopract.com
delivering eclipse technology
> Hi Rudiger,
> page is still loading. The following code should do that:
> it's because this.getContentWindow() in Browser.js returns null.
Re: Browser.execute() issue [message #106121 is a reply to message #106094] Wed, 24 September 2008 09:43 Go to previous messageGo to next message
Hi Rüdiger,
Looking on RAP 1.1.1 I've found a resolved bug #234683
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=234683). My problems are
most probably caused by security restrictions (this is covered by the bug)
- because the execute() method works fine with pages created via setText()
and fails when a page from an external URL is loaded in the browser.
Mozilla/Opera do not throw any Exceprtion (IE does) but iframe DOM is not
accessible in them (using CVS HEAD revision of RAP). If there's a
workaround to execute JS in Browser object with loaded external page, then
it might be posted as comment to #234683
Cheers, Martin
Re: Browser.execute() issue [message #106148 is a reply to message #106121] Wed, 24 September 2008 11:37 Go to previous messageGo to next message
--------------060708020907020708050804
Hi Martin,
if it turns out be actually be a security restriction, I don't think
that we can do much about it.
Still, I wonder, why the IFRAME returned by getContentWindow() is
null. Even if security settings apply, the page is displayed and
thus there must be an IFRAME element. The IFRAME may or may not
execute Javascript, but it should be there at least.
Attached is a Browser.js with the workaround mentioned in the
earlier post.
Note 1: this workaround is *not* to circumvent security issues.
Note 2: it is untested as I cannot reproduce the problem.
You may replace the existing org/eclipse/swt/browser/Browser.js in
the js source folder with this file and see if it works.
HTH,
R
Re: Browser.execute() issue [message #106254 is a reply to message #106148] Thu, 25 September 2008 06:58 Go to previous message
Hi Rüdiger,
first of all - thank you very much for your help. Unfortunately the script
you've attached to your last post worked exactly the same as the original
one. I think the problem is really a security issue and not a problem of
delayed DOM creation - when I run RAP controls demo, then with custom HTML
page (via setText()) inside the browser everything works fine -> load page
from URL -> run the JS -> script execution fails with the mentioned NPE.
The inaccessible iframe DOM element is confusing, but still I do think
it's a security issue you can do nothing about. Thanks again for your
thoughts :)
Regards, Martin
Previous Topic:RAP 1.2 plan
Next Topic:Checkboxes, Buttons in Table
Current Time: Tue Jul 22 02:37:38 EDT 2025
Powered by FUDForum. Page generated in 0.07534 seconds
