possibility to use Hyades/TPTP for testing Eclipse plug-ins? [message #9579] |
Wed, 09 March 2005 12:17  |
Originally posted by: ssc.entimo.de
I’m evaluating hyades(3.2)/tptp and wonder if I can use it to test
eclipse plug-ins. I would like to have a combination of PDE-JUnit and
Hyades. After browsing through the documentation, I haven’t found any
hint that such function is already built in the framework. This brings
me to my questions:
(1) Is there such feature? Is such feature planed for next releases?
Does anyone know a practical way to test plug-in with hyades? Is there a
source for additional documentation or examples?
(2) If there is no one done this before, it seems to me that I have to
extend the tptp by building a custom test execution environment in a
similar way as described in the EclipseCon 2005 Tutorial for a Perl
execution environment. Would this be the best way or do you know one easier?
Stephan
Re: possibility to use Hyades/TPTP for testing Eclipse plug-ins? [message #10312 is a reply to message #9693] |
Mon, 14 March 2005 04:10  |
Tom Roche wrote:
> Stephan Schroeder Wed, 09 Mar 2005 18:17:53 +0100
>>> I'm evaluating hyades(3.2)/tptp and wonder if I can use it to test
>>> eclipse plug-ins.
> Test what/how? Function? Performance?
My focus is on functional testing.
>>> I would like to have a combination of PDE-JUnit and Hyades. After
>>> browsing through the documentation, I haven't found any hint that
>>> such function is already built in the framework. This brings me to
>>> my questions:
> Depending on your what/how, see
> http://www.eclipse.org/tptp/home/project_info/featureplans/f eatures.php?source=All&project=All&release=4.0&f ile=TPTPFeatures_4.xml
> and scroll way down to
>> Bugzilla# Component Priority <snip> In Plan Summary
>> --------- --------- -------- <snip> ------- -------
>> 74791 Test.UI.JUnit P1 <snip> Committed Support for
> JUnit derivative projects such as HTTP Unit, Cactus, Abbot, etc.
Thanks, this seems to be the needed feature. But unfortunatly, if I
understand the relase plan right, I have to wait at least for milestone
4.0i4, which will come out somewhere in the summer...
>>> to extend the tptp by building a custom test execution environment
>>> in a similar way as described in the EclipseCon 2005 Tutorial for a
>>> Perl execution environment.
> Could you send me a pointer to that? I was formerly a perl coder and
> would love to see more eclipse perl tooling.
See
http://www.eclipse.org/tptp/test/documents/tutorials/eclipse Con2005/EclipseCon2005_Tutorial6.pdf
for the presentation slides.
FUDForum. Page generated in 1.80430 seconds
