Newbie need help to create a standalone java program [message #105520] |
Wed, 28 September 2005 00:50  |
Originally posted by: martinyeh.psu.edu
I need helps on deploying my program to other machines. I have a program
running ok under Eclipse IDE, I want to either create a java web start or
some other ways of distributing my program so that I don't have to worry
about whether other machines have appropriate set up for my program. I
don't use anything but pure java. Please let me know where to find
additional information. Thanks in advance.
Martin
Re: Newbie need help to create a standalone java program [message #109225 is a reply to message #109213] |
Thu, 13 October 2005 14:53   |
Originally posted by: weconsul.ptd.net
Martin Yeh wrote:
> Bheku Terence Msimanga wrote:
>> Hi Martin,
>> I used a plugin to deploy a jar file of a project I worked on. The
>> application was a swing-based database front-end.
>> The only problem I had was with some of the images that I had been
>> using. But otherwise I could execute the jar on the target machine
>> without any problems.
>> The plugin you're looking for is call Fat-Jar. You can find it at
>> ecliplse plugin central.
> Thank you for your help. I downloaded fat-jar and export an jar. But
> there is still one problem left. Here is the structure in my workbench:
> I have 3 folders: src, resources, and images. I have some text file in
> resources folder and images in images folders. All .java files are under
> src. Some jara file will read the text files under resources. All files
> are put into one jar file.
> When I use "jara -jar myprogram.jar", I got error messages complaining
> about "Unknown Source". It seems that jar file does not contain the
> structure. How do I do to keep the folder structure so the java file can
> find those .txt or .png files without problem? I know I could put
> everything under same folder, but I'd prefer retain the structure.
> Cheers,
> Martin
I do not use Fat-Jar. I just use the Eclipse export.
- Select the project
- right click on project and select Export
- select jar file
- select 'Export generated class files and resources'
- select 'Compress the contents of jar file'
- select 'Add directory entries'
- Select finish. 'I take the default for all the next screens'
- I do get warnings but for me they are ok.
I then move the new jar file to where I want to run it.
I do not use the java -jar option. I use the classpath option and invoke
my main class with its package prefix as..
java -classpath ..\lib\test.jar org.hsqldb.util.DatabaseManagerSwing %1
This works for me. All of the files are found
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Newbie need help to create a standalone java program [message #109288 is a reply to message #109263] |
Thu, 13 October 2005 23:59   |
Martin Yeh wrote:
> I will try that just to see how it works. However, my program will be
> used by people who don't know much about computer, not to mention
> command line environment. So I need to make it work just using doubl-click.
>> - select jar file
You can just create a bat file with the Java command to run your
program. You could even create a shortcut and put on their desk top.
Just have them double click the short cut.
An example *example.bat* file would have, in my case, the following..
echo off
Re: Newbie need help to create a standalone java program [message #109328 is a reply to message #109288] |
Fri, 14 October 2005 00:40  |
>> doubl-click.
>>> - select jar file
> echo off
You may want to try this also using Eclipse. That is, create an
executable jar file. Do the same as before..
- select jar file
- HERE do not select FINISH but NEXT
- I select 'export classes with compiler warnings'
- Select NEXT
- Select 'generate Manifest file'
- This is where you make your jar file executable. That is, create a
Manifest file.
- Select 'Browse' for your main class. This is the entry point for
your program. The main class.
- Select FINISH
You now have a jar file that you can exec with the Java -jar command
Hopefully all of your objects .txt or .png files will load.
This is how it is done using Eclipse.
FUDForum. Page generated in 0.40837 seconds
