Home » Eclipse Projects » DTP » Making connection profile or Database programatic
Making connection profile or Database programatic [message #9554] Sat, 18 March 2006 01:58 Go to next message
Is it possible and if yes is there some documentation or start point.
I have tried make database instance like this
Database database = new JDBCDatabase(connection);
but it fail in this code (JDBCDatabase#loadSchemas line 91)
ConnectionInfo connectionInfo =
DatabaseConnectionRegistry.getInstance().getConnectionForDat abase(this);
ConnectionFilter filter =
connectionInfo.getFilter(this.getName()+"::"+ConnectionFilter.SCHEMA_FILTER); //$NON-NLS-1$
if (filter == null) { //if schema filter is null, then get default filter
filter = connectionInfo.getFilter(ConnectionFilter.SCHEMA_FILTER);
maybe this is better :
if (connectionInfo != null) {
Best
Peco
Re: Making connection profile or Database programatic [message #9690 is a reply to message #9554] Fri, 24 March 2006 14:04 Go to previous messageGo to next message
Hello Peco,
Sorry for the lack of documentation. It is one of the things we will be
working on as we move towards the Callisto release. Hopefully, the
following example will help.
The SQL model can be accessed through a connection factory associated with
connection profile you are using. You should use the connection factory
ID'd by the ConnectionInfo class.
For example,
IConnection connection =
someConnectionProfile.createConnection(ConnectionInfo.class. getName());
(ConnectionInfo)connection.getRawConnection();
Database db = connectionInfo.getDatabase();
Connection jdbcConnection = connectionInfo.getSharedConnection();
Alternately, if you wish to use the shared model associated with the
connection profile... (this assumes the connection profile is in a
"connected" state; someConnectionProfile.connect())
IManagedConnection managedConnection =
someConnectionProfile.getManagedConnection(ConnectionInfo.cl ass.getName());
IConnection connection = managedConnection.getConnection();
ConnectionInfo ....<same as above from here on>
Hope that helps you along. Please let me know if you need more
information.
Sincerely,
Rob
Re: Making connection profile or Database programatic [message #10225 is a reply to message #9690] Fri, 24 March 2006 18:52 Go to previous messageGo to next message
Rob,
I have java.sql.Connection (connected to database) and i want
make Database instance (for using sql parser in non-datatools
editor).I haven't ConnectionInfo (and i needn't it)
It work fine except part of code in my example:
datatools check if filter is null, but doesn't check if
ConnectionInfo is null.
I don't want make connection profile from existing datatools
connection profile - i have nothing except raw datatools plugin
and want use parser part only
PS
Can datatools handle databases wich supports catalog and schema
like MS SQL and Sybase (i see getSchemas method, but don't see
getCatalogs or similar)
Rob Cernich wrote:
> Hello Peco,
> For example,
> information.
> Sincerely,
> Rob
Re: Making connection profile or Database programatic [message #20051 is a reply to message #10225] Tue, 25 July 2006 15:48 Go to previous message
Peco,
I've created a BZ entry for this,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=151747.
Rob
Re: Making connection profile or Database programatic [message #571707 is a reply to message #9554] Fri, 24 March 2006 14:04 Go to previous message
Hello Peco,
For example,
information.
Sincerely,
Rob
Re: Making connection profile or Database programatic [message #571770 is a reply to message #9690] Fri, 24 March 2006 18:52 Go to previous message
Rob,
PS
Rob Cernich wrote:
> Hello Peco,
> For example,
> information.
> Sincerely,
> Rob
Re: Making connection profile or Database programatic [message #581289 is a reply to message #10225] Tue, 25 July 2006 15:48 Go to previous message
Peco,
Rob
Previous Topic:DTP going to follow UI guidelines?
Next Topic:DTP Connectivity Features for 0.9.1 and 1.0
Current Time: Thu Nov 06 01:14:43 EST 2025
Powered by FUDForum. Page generated in 0.05769 seconds
