Home » Language IDEs » ServerTools (WTP) » wtp w/ jboss 4.x
wtp w/ jboss 4.x [message #105050] Wed, 18 May 2005 10:30 Go to next message
Originally posted by: mark_lybarger.yahoo.com
just wondering if anyone is using jboss 4.0.x with the wtp. i pulled the
m4, and only see a profile for jboss 3.2.x. i encountered an issue
looking for jboss-boot.jar or somesuch in setting up a 4.x server. (using
the 3.2.3 profile).
Re: wtp w/ jboss 4.x [message #105060 is a reply to message #105050] Wed, 18 May 2005 10:40 Go to previous messageGo to next message
just search for JBoss 4.0.1 solved.
There is a long description.
Regards Johannes.
"mark" <mark_lybarger@yahoo.com> wrote in message
news:a136632480e16ce50d139920fed0673e$1@www.eclipse.org...
> the 3.2.3 profile).
Re: wtp w/ jboss 4.x [message #105078 is a reply to message #105060] Wed, 18 May 2005 14:37 Go to previous messageGo to next message
Johannes Hiemer wrote:
> Regards Johannes.
>> the 3.2.3 profile).
>>it was quite a challenge just to get the 4.0.1 jboss server to show up with
pasting these files in.
currently, it's just hanging when i select that server and select next.
Re: wtp w/ jboss 4.x [message #105109 is a reply to message #105078] Wed, 18 May 2005 15:10 Go to previous messageGo to next message
well, i found a small trouble pasting in the jboss401.serverdef file. the
first line didn't paste in ok.
<tns:ServerRuntime
xmlns:tns="http://eclipse.org/jst/server/generic/ServerTypeDefinition"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation=" http://eclipse.org/jst/server/generic/ServerTypeDefinition/S erverTypeDefinitionSchema.xsd
" name="JBOSS 4.0.1" version="v4.0.1">
i'm still not sure i have it right, but i can select and setup the 4.0.1
jboss instance. now when trying to run i get:
Buildfile:
D:\proj\autodeploy\.metadata\.plugins\org.eclipse.jst.common .launcher.ant\tempAnt.xml
init:
webdoclet:
BUILD FAILED
D:\proj\autodeploy\.metadata\.plugins\org.eclipse.jst.common .launcher.ant\tempAnt.xml:56:
taskdef class xdoclet.modules.web.WebDocletTask cannot be found
Total time: 1 second
maybe we should create a bug in bugzilla to attach the jboss 4.0.x server
config files.
>> Regards Johannes.
>>> the 3.2.3 profile).
Re: wtp w/ jboss 4.x [message #105123 is a reply to message #105109] Wed, 18 May 2005 15:23 Go to previous messageGo to next message
i had to install xdoclet myself per this message, now the xdoclet goes.
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg04 096.html
currently, eclipse won't let me deploy to jboss 4.0.1 because it says it
doesn't support 1.2 web standards. i'm just trying to do a simple web app
deployed to a container.
Re: wtp w/ jboss 4.x [message #105171 is a reply to message #105123] Wed, 18 May 2005 16:26 Go to previous message
ok, i finally am deploying to jboss 4.0.0 (using the 4.0.1 definition). i
get lots of errors in my server startup, some seem to be about locale or
somesuch. i have used the jboss server for other manual deployments prior
to using it with eclipse.
i also could not get eclipse to recognize that jboss 4.0.1 could handle
1.2, 1.3, and 1.4 j2ee apps even after i edited the plugin.xml. i had to
completely start from scratch, with a new workspace and then it would
allow me to deploy a new app to jboss.
finally, i searched the bugs and found this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=90100
Previous Topic:JBoss 4.0.1 Solved - latest plugin.xml
Next Topic:Say hello to the WTP help system
Current Time: Sat Jul 19 11:08:30 EDT 2025
Powered by FUDForum. Page generated in 0.03982 seconds
