Home » Newcomers » Newcomers » "Add to .cvsignore" greyed out, Ignore Resources broken
"Add to .cvsignore" greyed out, Ignore Resources broken [message #104919] Mon, 26 September 2005 13:15 Go to next message
Originally posted by: eclipse.t.jvance.xoxy.net
Hi all,
I'm trying to get Eclipse Synchronise perspective to ignore my .classpath.
So I added it to my .cvsignore file. No effect. Well, not entirely true
- .cvsignore now shows up as an outgoing change :-/
I tried right-click | Add to .cvsignore, but that menu option is greyed
out - for every file I've examined. I tried adding .classpath to the
Ignore Resources list (Window | Preferences | CVS | Ignore Resources) and
it does indeed ignore .classpath - for about three seconds. Then the
Synchronise view refreshes and .classpath shows back up in my conflicts
list.
Anyone have a clue as to why Eclipse is ignoring .cvsignore, greying out
"Add to .cvsignore" and studiously not ignoring Ignore(d) Resources?
John Vance
Re: "Add to .cvsignore" greyed out, Ignore Resources broken [message #105165 is a reply to message #104919] Tue, 27 September 2005 04:23 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
John Vance schreef:
> Hi all,
> .classpath. So I added it to my .cvsignore file. No effect. Well, not
> entirely true - .cvsignore now shows up as an outgoing change :-/
> and it does indeed ignore .classpath - for about three seconds. Then
> the Synchronise view refreshes and .classpath shows back up in my
> conflicts list.
Maybe because you edited it yourself? You could try deleting (moving
out of the workspace) .cvsignore and see whether a new one gets made.
Hendrik Maryns
www.lieverleven.be
http://aouw.org
Re: "Add to .cvsignore" greyed out, Ignore Resources broken [message #105938 is a reply to message #105165] Thu, 29 September 2005 01:21 Go to previous messageGo to next message
Originally posted by: eclipse.t.jvance.spamgourmet.com
Hendrik Maryns wrote:
> John Vance schreef:
>> Hi all,
>> .classpath...
Dank u!
Most likely that's the problem. It appears that once CVS has seen a file,
it can't be ignored through .cvsignore. It may need to be purged from CVS
using an admin command. Right now this is a low priority, but if I find
out the exact solution, I may submit a FAQ and answer for it.
Met vriendelijke groeten,
John
Re: "Add to .cvsignore" greyed out, Ignore Resources broken [message #106267 is a reply to message #105938] Thu, 29 September 2005 17:50 Go to previous message
That is definitely the case. And note it is a CVS limitation not an
Eclipse thing. You will have to purge the file from your CVS server in
order to be able to ignore it properly.
HTH,
Eric
Previous Topic:How to make eclipse use default javac compiler to build
Next Topic:How To Install Java Help Within Eclipse 3.0
Current Time: Tue Oct 21 07:06:54 EDT 2025
Powered by FUDForum. Page generated in 0.10789 seconds
