Home » Archived » M2M (model-to-model transformation) » merging models
merging models [message #104791] Sun, 10 May 2009 12:43 Go to next message
good afternoon,
i have to merge two models (2 PIMs) to transform it to a PSM, I want to
know how should i define the ATL file?
does the ATL file contain the corespondence between concepts of the 2
source metamodels (metamodels of PIMs) and the metamodel of the PSM? or
there is other technic to do this transformation?
thx a lot
Re: merging models [message #104819 is a reply to message #104791] Mon, 11 May 2009 03:59 Go to previous message
you can have a module declaration like this:
module Marte2ATL;
create OUT : PSM from IN1 : PIM1 , IN2 : PIM2;
and then you can have rules like this:
rule ModelElement_A {
from s : PIM1!MetaModelElementA1 , v : PIM2!MetaModelElementD2
(conditionOn{s,v})
to p: PSM!MetaModelElementF
...(Bindings)
Previous Topic:[ATL] get header from .asm or .atl in Java
Next Topic:[ATL] A Problem with atl transformation to Ecore
Current Time: Mon Jul 21 21:55:39 EDT 2025
Powered by FUDForum. Page generated in 2.46819 seconds
