Home » Eclipse Projects » Equinox » Equinox Embedded within WAS 6.1 in Real Live
Equinox Embedded within WAS 6.1 in Real Live [message #104513] Mon, 28 January 2008 12:04 Go to next message
Salve,
Know someone, whether enterprise-systems exist successful in operating, using Equinox Embedded (Servlet-Container) within WAS 6.1?
Is there some stability and/or performance publications in the net?
Alexander
Re: Equinox Embedded within WAS 6.1 in Real Live [message #104786 is a reply to message #104513] Tue, 05 February 2008 23:24 Go to previous messageGo to next message
Hi Alexander,
We're using WAS 6.1 in conjunction with the equinox servletbridge in several
commercial products.
I'm unaware of any stability / performance publications however, in the past
I've run some informal load tests and found no noticeable overhead or
indication of memory leaks.
I'd be very interested if you're doing any benchmarking.
-Simon
"Alexander Ziegler" <alexander.ziegler@compeople.de> wrote in message
news:fnl209$b5l$1@build.eclipse.org...
> Salve,
> Alexander
Re: Equinox Embedded within WAS 6.1 in Real Live [message #104798 is a reply to message #104786] Wed, 06 February 2008 03:16 Go to previous message
Hi Simon,
Thanks for the information. Our performance/stability tests will start in
april/may. When I have some results I will post it.
Alexander
Simon Kaegi schrieb:
> Hi Alexander,
> -Simon
>> Salve,
>> Regards,
>> Alexander
Previous Topic:Usage of split packages?
Next Topic:Problem running the Equinox P2 Getting Started guide
Current Time: Thu Jul 17 22:33:50 EDT 2025
Powered by FUDForum. Page generated in 0.04965 seconds
