Home » Eclipse Projects » Commercial » LogicLibrary Logidex re-validated to Ready for Rational Software
LogicLibrary Logidex re-validated to Ready for Rational Software [message #9497] Fri, 21 April 2006 10:42
Originally posted by: bennetme.us.ibm.com
This is a multipart message in MIME format.
--=_alternative 0050C35588257157_=
Content-Type: text/plain; charset="US-ASCII"
LogicLibrary Logidex AnySource Asset Adapter for ClearCase/ClearQuesthas
successfully re-validated to the requirements of Ready for IBM Rational
software V3.0.2 The plug-in met the requirements for the Software
Development Platform level of the program. For more information on this
validation, see the Plug-In Central website on developerWorks:
http://www-128.ibm.com/developerworks/websphere/downloads/pl ugin/
Detailed Solution Description:
Logidex AnySource Asset Adapter for ClearCase/ClearQuest assembles
consolidated asset metadata across ClearCase and ClearQuest based on
ClearCase triggers (e.g. mark a stream/baseline as RELEASED). This allows
Logidex to create and maintain by-reference artifacts to specific elements
within the ClearCase baseline and associated ClearQuest changesets.
Logidex also converts intercomponent dependencies within a ClearCase
baseline to-asset-to-asset relationships within Logidex metadata. For
example, ClearCase may be configured to define src and out subdirectories
on a per component basis, where the out subdirectory is used to maintain
build output such as Javadoc and jar files.
Logidex ASAA for UCM transforms each ClearCase component into a Logidex
asset, and navigates ClearCase directory structures to automatically build
Logidex artifact references to relevant files (e.g., Javadoc and jar)
within ClearCase. In parallel, Logidex uses the UCM infrastructure to
build references to ClearQuest changesets; these change sets document why
the component was created or changed. Logidex also establishes
asset-to-asset versioning relationships (e.g., REL1 vs. REL2
streams\baselines for the same component) based on ClearCase foundation
baseline dependencies.
For more information on how your company can partner with IBM Rational,
send an email to rfrs1bus@us.ibm.com or visit the Ready for IBM Rational
Software website on PartnerWorld:
http://www-304.ibm.com/jct09002c/isv/rational/readyfor.html.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">LogicLibrary Logidex AnySource Asset
Adapter for ClearCase/ClearQuesthas successfully re-validated to the requirements
of Ready for IBM Rational software V3.0.2 &nbsp;The plug-in met the requirements
for the Software Development Platform level of the program. &nbsp;For more
information on this validation, see the Plug-In Central website on developerWorks:
http://www-128.ibm.com/developerworks/websphere/downloads/pl ugin/</font>
<br>
<br><font size=2 face="sans-serif">Detailed Solution Description:</font>
<br><font size=2 face="sans-serif">Logidex AnySource Asset Adapter for
ClearCase/ClearQuest assembles consolidated asset metadata across ClearCase
and ClearQuest based on ClearCase triggers (e.g. mark a stream/baseline
as RELEASED). This allows Logidex to create and maintain by-reference artifacts
to specific elements within the ClearCase baseline and associated ClearQuest
changesets. Logidex also converts intercomponent dependencies within a
ClearCase baseline to-asset-to-asset relationships within Logidex metadata.
For example, ClearCase may be configured to define src and out subdirectories
build output such as Javadoc and jar files.</font>
<br>
<br><font size=2 face="sans-serif">Logidex ASAA for UCM transforms each
ClearCase component into a Logidex asset, and navigates ClearCase directory
structures to automatically build Logidex artifact references to relevant
files (e.g., Javadoc and jar) within ClearCase. In parallel, Logidex uses
the UCM infrastructure to build references to ClearQuest changesets; these
change sets document why the component was created or changed. Logidex
also establishes asset-to-asset versioning relationships (e.g., REL1 vs.
REL2 streams\baselines for the same component) based on ClearCase foundation
baseline dependencies.</font>
<br>
<br><font size=2 face="sans-serif">For more information on how your company
can partner with IBM Rational, send an email to rfrs1bus@us.ibm.com or
visit the Ready for IBM Rational Software website on PartnerWorld: http://www-304.ibm.com/jct09002c/isv/rational/readyfor.html.</font>
--=_alternative 0050C35588257157_=--
Previous Topic:Secure CLASP Plug-In announces Ready for Rational Software Validation
Next Topic:LogicLibrary Logidex re-validated to Ready for Rational Software
Current Time: Fri Jul 18 09:47:01 EDT 2025
Powered by FUDForum. Page generated in 0.19390 seconds
